BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY - Blackvue Dashcam Hardwire - ALL with the fusebox, no sketchy wiring
proTUNING Freaks
      11-05-2018, 11:27 PM   #89
bryanl0
Drives: 2016 328d xDrive
Always-on fuse?
Hi guys,
Sorry to revive an old thread. I've followed all of the instructions in the OP by smithf80 to wire my DR750S-2CH + Power MagicPro. But for some reason, the PMP stops getting power (the LED on it turns off and the dashcam itself also turns off) within a few minutes after the engine is turned off. Everything seems to work fine with the engine running though.
I've also tried the entire column of fuses where 161 is located and none of them seem to stay live for more than a few minutes after ignition is switched off. Any ideas? Did they change the fuse configurations for the LCI cars?
Thanks in advance!
      11-27-2018, 07:40 PM   #90
BulsaraF36
BulsaraF36's Avatar
142
Drives: F36 435i M-Sport
Originally Posted by bryanl0 View Post
Hi guys,
Thanks in advance!
did you get this resolved? if not can you post a pic of the fuse box? want to check the wiring.
2016 435i M-Sport | Carbon Black | 20" 624M Wheels | MPPK | MPE | M Performance Brakes | M Performance Steering Wheel II with Display | xHP | Dinan Stage 4 | Dinan Big Turbo | Dinan High Performance Intercooler | Dinan Intake | Dinan Shockware | Fabspeed Sport Cat Downpipe | Custom Quad Tips | Autotecknic Red Paddle Shifters
      12-04-2018, 01:20 PM   #91
bryanl0
Resolved!
Got it resolved. Turns out the problem was that I had the PMP set to shut off at 12.5V and fuse 161 wasn't supplying that voltage without ignition. Changed the setting on the PMP to 12V and everything works fine now. Only thing left to figure out is if I should be concerned that the fuse drops below 12.5V without ignition.
Cheers!
      03-12-2019, 08:20 AM   #92
vooonoo
¯\_(ツ)_/¯
vooonoo's Avatar
537
Drives: f30 328
2014 f30 328i  [0.00]
commenting so i can find this later
jbeer154.50
      04-18-2019, 04:50 PM   #93
hanzzll
Netherlands
Drives: BMW 420i coupe F32
Hardwiring dashcam in rear fusebox 4 series F32 F36
Anyone with experience hardwiring a dashcam using the 4 series fusebox in the trunk..?
I have installed a Mini9606 dual channel cam and hardwire kit with parking guard and batt drain protection.
I have routed the hw power cable together with the rear cam cable to back of my F32LCI, and am struggling tapping power from the rear fusebox.
Issue I have is that the cam switches off on ignition off and start/stop, and can't get parking guard mode to work..
Tried various fuses, and direct battery connection , but can't get it to work properly.
Anyone who can advise how to properly wire the hardwirekit to the rear fusebox on 4-series...?
      04-18-2019, 05:16 PM   #94
bryanl0
Is there a voltage setting on your parking guard? Sounds like you might be having the same issue I had with the PMP from blackvue. Read my update from 3 posts up and see if that helps.
      04-19-2019, 12:19 PM   #95
BulsaraF36
BulsaraF36's Avatar
142
post picture of your current wire setup for the fusebox in the trunk. also make sure wires are secured properly.
      10-01-2019, 07:00 PM   #96
YEET82
Lurker
26
Drives: BMW 135i
Im using a Blackvue magic box pro with the exact same set up and it doesn't seem to be working for me. My set up is exactly as OP except for ground.
For the BATT+ you'll use an add a fuse on fuse #161.
For ACC+ you'll use an add a fuse on fuse #143
For ground you'll just attach to the bolt on the car's where 3G connection receiver WOULD be.
The magic box is not getting power to it and thus the webcam does not have power either. The fuses still have power as my tail light / accessories are still working. Could it not be grounded properly? I plugged the blackvue back into the cigarette lighter and it is working fine so I'm not sure why the fuses arent supplying power correctly..
      10-04-2019, 12:19 PM   #97
BulsaraF36
BulsaraF36's Avatar
142
make sure your fuse is not blown. Also try to move ground to a different location by the battery and see if that help.
      10-09-2019, 01:57 PM   #98
sd_dracula
141
Drives: 2020 G20 330e
Anyone tried this in a G20 fusebox? Would love to get my blackvue hooked up like in my F30
      10-15-2019, 12:11 PM   #99
sd_dracula
141
Got this sorted in my G20 so hopefully it will help others:
BATT to fuse #29
ACC to fuse #59
Ground to any metal chassis around the fusebox (there's an M10 bolt right beside the front right fusebox)
smithf802808.50
      10-19-2019, 12:03 AM   #100
smithf80
smithf80's Avatar
Drives: G80 M3 6MT
2022 G20 330i  [9.00]
2018 F80 M3  [9.75]
I've seen many Power Magic Pro's be DOA. Did an install on a friends X3 and his PMP was DOA.
      08-07-2020, 09:05 AM   #101
tward182
Drives: 2014 BMW 328 (F30)
RE: hard wiring F30
any issues or changes to original fuse wiring?
      08-03-2021, 08:35 AM   #102
tafakasam
Drives: 2017 F30 330e
Originally Posted by Alan_Tan View Post
this is not a good idea, is too far and messy too,
i just bought original bmw socket and diy make a wiring hardness (add a fuse for safety purpose) grab power supply from the rain sensor.
simple and easy, 5 minute done.
where can this be bought from? seems neat and tidy? any part no?
      01-06-2023, 10:38 PM   #103
Danpaulyyz
Drives: 2018 F30 328D
Bumping this thread as I’m hardwiring a BlackVue Battery (130) in the trunk of my 2018 328d.
Seems I need to use one of the 10A, and I have two options:
1: The one that goes on and off with the ignition, but is tied to engine things
2: The other one stays on for 6-10 minutes after you turn the car off and drains your car battery
Does this sound accurate to the situation?
Anyone else here running a battery in the trunk and have experience to share?
Thanks!
      01-14-2023, 12:09 PM   #104
Randy Johnson
M340i
Randy Johnson's Avatar
Drives: BMW M340i
2021 BMW M340i  [10.00]
There are many options to tap into. Does your dashcam have parking mode and use a 3 wire harness? The fuses the OP stated in the 1st post should work. My 2015 435i has a very similar fuse box. This is how I setup my dashcam with 3 wire kit. I did not use the extra battery protector thingamajig. Pic is from OP.
      04-26-2023, 05:14 PM   #105
GENAU
16
Drives: 2018 BMW 440i GC
Dumbfounded on this one. I feel like I took the right route with this but I'm getting nothing from the camera whether or not the car is on. My car is a 2018 F36 440i gran coupe. Parking mode and whatever else appear to be right with the camera too. I've tried every setting on the hardwire kit to no avail. I have:
A119 V3
https://www.amazon.com/dp/B07JQ1JYPJ...roduct_details
BATT+ I used an add a 5A fuse on 20A fuse #161.
ACC+ I used an add a 5A fuse on 5A fuse #143
It works fine with the cig lighter but not with the hardwire kit.
      04-26-2023, 06:03 PM   #106
jbeer
jbeer's Avatar
155
Drives: 320i M Sport Shadow Edition
A couple of checks to do…..
Have you made sure your ground is attached to the bodywork which is non painted?
When adding the fuse taps do you have these the correct way round so that the live side of the fuse goes up and through the fuse? As per the below?
Current: F30 2018 320i M Sport Shadow Edition
Accessories: BMW OEM Roof Bars & Bike Carriers, Dashcam - Blackvue 590W-2CH
      03-27-2024, 01:52 PM   #107
Blackcross
Blackcross's Avatar
17
Drives: Estoril Blue 2014 335i xdrive
Meaning of the hard to read fuse pictograms
Giving back to the group (6 years of Blackvue ownering)
My printed copies of the earlier posted fuse diagrams are a tad hard to interpret. THis hand site explains what all the pictograms mean:
https://www.servicetutorials.com/202...ols-explained/
2014 Estoril 335i xdrive 6sp: M Sport, m perf power/brakes/sound kit, AA8 400 hp/ 420 ft-lbs. 10/15mm spacers. Dinan 3/4" spring kit, Misc coding. Mud flaps.
Racing/tuning/teaching since 1997. Long list of clubs as Chief, classroom and in-car instructor.
