BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Issues with coding
ARMA SPEED
      03-21-2018, 11:37 AM   #1
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Drives: '13 328i Msport 6MT
Exclamation Issues with coding
Hey guys, forum member came to me to get his larger nav screen coded but the car was not playing nice with Bimmercode
HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display
Was coded with the new screen but it kept failing. Tried to restore it back but that didn't work. We installed the old smaller screen, restore didn't work so we disconnected the battery for a few min. After the battery reset the radio buttons did not work. All fuses were checked and checked out fine. Looks like a lot of the settings on the headunit screen are gone (sports display, etc). Also the passenger airbag light came on which I cleared but I'm baffled why it even came on.
Any idea why this is happening and what can be done? Vgate Icar2 WIFI was used. Car is 2017 330i sport package
Tensioner/belt DIY | Side skirt extension DIY
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes
Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC
      03-21-2018, 12:25 PM   #2
Littlebear
Drives: ...the Mods crazy.
Hello BMW Experts!
Jake was kindly working on my car, so I want to add a few probs.
-No parking cameras
-No TPMS
-No radio
-The clock will not stay set, but the date will.
TIA! Murf
      03-21-2018, 03:10 PM   #3
larrylam646
larrylam646's Avatar
371
Drives: 2020 M340i xDrive
Originally Posted by Littlebear View Post
Hello BMW Experts!
-No parking cameras
-No TPMS
-No radio
TIA! Murf
Do you have access to ISTA+/Rheingold? You can use Rheingold to identify the errors and generate/run a test plan to try to fix things.
I think you may have to use both E-sys (VO/FDL Coding) and Rheingold to get your car back to factory (starting point).
Larry
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold
Littlebear3509.50
      03-22-2018, 05:31 PM   #4
MarkoSK
Drives: BMW G20 330eX
I wouldn't code anything over WiFi, it's just not stable enough. Maybe it wasn't the issue, but I would recommend coding only via an ethernet cable + ENET adapter.
Anyway, shawnsheridan could you please help?
      03-22-2018, 08:13 PM   #5
shawnsheridan
General
shawnsheridan's Avatar
Help with what?
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      03-23-2018, 11:54 PM   #6
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Coding over wifi is fine, though unless you have ICOM, not many wifi ENET.
I would not recommend programming over ICOM.
If you mean via Bimmercode, then I would recommend user has E-sys ready if things go wrong.
      03-24-2018, 09:55 AM   #7
MarkoSK
SolidJake mentioned BimmerCode.
      03-24-2018, 09:56 AM   #8
MarkoSK
Originally Posted by shawnsheridan View Post
Help with what?
Getting the car working as from factory, via eSys I guess.
      03-24-2018, 09:57 AM   #9
shawnsheridan
General
VO Code all ECU's you need to reset. PM sent.
      03-24-2018, 10:00 AM   #10
Kingpin4
Kingpin4's Avatar
Drives: 2018 X3 M40i/2019 M2C
Did you try contacting the support department (Stephen Gauch) in bimmercode?
I had issues before and contacted then and they quickly responded and sorted out the issue.
      03-25-2018, 09:41 AM   #11
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Not yet. I will do that later today thanks.
      03-28-2018, 05:41 AM   #12
Littlebear
Hello BMW Experts!
Jake has a call in to Bimmercodes, & I am going to try to make time to learn Esys. Will keep begging for help here also....
The car works fine except that with no radio I had to listen, I mean speak with, my wife for the 5-6 hr trip to & from the mountains.
Murf
      03-28-2018, 11:02 AM   #13
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
From Bimmercode
I am afraid you will not be able to restore using this adapter. This seems to happen from time to time with the iCar 2 WiFi adapters and I am not sure what could causes this, since they work fine initially and at some point these problems arise. The newer devices like the iCar Pro WiFi do not have this problem, so replacing the adapter and restoring using backup will fix this.
so if you have the icar 2 i would replace it with the Pro version before the same thing happens. I messaged the seller on amazon to see if they can upgrade to the newer one and just pay the difference
      03-30-2018, 10:35 AM   #14
Kevin_Trxn
Drives: '17 340i
From Bimmercode
Interesting naming scheme.
I bought the iCar 2 thinking it was the newer version. It also has a more modern look.
The iCar Pro looked more dated and more expensive.... welp. lost $5 in return fees but no biggie
      04-21-2018, 08:27 AM   #15
Littlebear
OK You Muggs,
Went down this morn to see if car had for some reason re-set itself. NOT.
I did the 30sec-vol-knob reset, which does, but the screen & functions were still dead.
So because it is easy, and sort of could be the prob, I switched screens from 2626 (which BMWoem said use) to the 7453(?). EVERYTHING, IN THE WHOLE CAR, WORKS! I even get the Rolls Royce start pics & chimes! Radio, TPMS, PDC, mirrors fold with FOB... all good.
So why? I switched the screen from a 2626 to the 7453. I tried an older 2248, and all worked. I did not put the 2626 back in to see if it would kill everything!
Thanks to all, especially Ibo24 who really stuck with me with PMs.
Best, Murf
PS: Thread from Coding section here(only 6 entries):
http://f30.bimmerpost.com/forums/sho...4#post23088894
      10-05-2018, 04:17 PM   #16
tonmily
Wales
Drives: BMWX435D
trouble guys HEEEEEEELLLPP!!
Hi fellas, Ive been following this thread for months now ( Before buying my car) and have planned to retrofit the 8.8'' screen since i first decided to buy the car, its a 2015 X435D with HU_entrynav.
I bought my first 8.8 '' screen off the Bay part:- 6822625 fitted and coded with ESYS -HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480
and had 'No signal'
I sent this screen back and bought another (same part no) and it did the same- No signal. Have any of you seen this before? any advise would be appreciated.
Thanks in advance
      10-06-2018, 03:42 AM   #17
atzebmw
Germany
588
Drives: Tesla Model 3
Thanks in advance
By the change from NBT to NBTEvo (07/2015) the output voltage from HU to Display changed from 12V to 9V.
NBT Evo has a smaller output voltage.
The display with the number 6822625 was produced from 03/2016.
So it probably needs a smaller voltage than your head unit will output.
So you can put a voltage converter between it or buy the right display (e.g. 9292248).
      03-19-2024, 09:09 PM   #18
Xusb
Drives: E90 f25
Nbt evo apix2 screen will never work with nbt head unit apix1.
      03-19-2024, 10:15 PM   #19
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
