BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Changing NBT Country Coding
GetBMWParts
      12-06-2023, 10:03 AM   #133
shawnsheridan
General
shawnsheridan's Avatar
Originally Posted by MetalMic View Post
Appreciate the speedy feedback shawnsheridan. I just checked the FA, looks like the regions is still set to 812 i.e. Great Britain and Ireland but the map is Southeast Asia. I reckon the map has been added via FI?
Most likely so.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      12-06-2023, 10:06 AM   #134
MetalMic
Malaysia
Drives: F30 LCI
Originally Posted by shawnsheridan View Post
Most likely so.
Many thanks mate, will get back to you when I need a new FSC for the SEA map.
      12-16-2023, 08:25 PM   #135
Ukldn95
Drives: BMW 335i
Hi guys need some help I have a BMW 335i hybrid that I have imported from Japan to the uk I am having some trouble with trying to convert the Japanese maps to the euro/uk can anyone guide me in the right direction? I have
Managed to convert the radio frequency’s thanks.
      12-17-2023, 01:54 AM   #136
TheNine90
Drives: bmw
Which headunit do you have?
Most likely will need to patch the unit to change region. PM me i can provide patch.
      12-19-2023, 11:01 AM   #137
Ukldn95
Drives: BMW 335i
Hi, I also have a BMW X1 late 2017 I am also trying to convert the maps from Japanese to Euro/UK the head unit in the BMW X1 is
Japan
BMW group
11.13.2100
(JAPAN EVO 2020-2)
I have also attached some pictures if that helps
Can some point me in the right direction, or give me some advice please that would be much appreciated, and it doesn’t let me directly PM people thanks.
      12-19-2023, 12:22 PM   #138
TheNine90
Drives: bmw
Japan
BMW group
11.13.2100
(JAPAN EVO 2020-2)
You will need to patch the unit to change region. You can use feature installer. PM sent.
      12-19-2023, 01:04 PM   #139
Ukldn95
Drives: BMW 335i
Hi thenine90 can you give me your email so I can contact you it doesn’t let me PM or reply back to you directly thanks.
      01-17-2024, 04:56 AM   #140
fedotenkoi
Drives: BMW G12 740Li
Hi all. Could you help me with changing the region? A car from the USA arrived in Ukraine. BMW G12 2016. NBT EVO installed. I updated the all car to the latest software using the ESIS through the factory FA. I did all the coding and everything works great. Also change via coding language to russian, but FSC codes to activate Carplay and EU navi. But one problem. Since the firmware is still for the US market, it does not have voice navigation prompts or voice control. I need to flash the version for Europe as i know. Tell me if I want to do it right? I calculated FA, changed the configuration Typschlüssel=7E23 to Typschlüssel=7E21 and calculated TAL. This is what Esis suggests me to flash. Will there be a black screen radio after flashing the firmware? Thank you. Thanks for every hint.
      01-17-2024, 05:50 AM   #141
TheNine90
Drives: bmw
Make sure hwel is black using the hw id button. If you do correct region change patch it will also do region change fix
      01-17-2024, 08:36 AM   #142
fedotenkoi
I don't quite understand what you mean. Can you write in more detail? Thank you.
      01-17-2024, 09:28 AM   #143
TheNine90
Drives: bmw
Before flashing you have to make sure the HWEL in nbt is balck or it will fail in flash. Use Hw id from svtactual button to make it black.
If you have done region change patch you will have to do it again and this should also fix region change lock
      01-17-2024, 04:16 PM   #144
fedotenkoi
I'll try to describe it in more detail with screenshots. Perhaps this information will be useful for others who have encountered this problem.
Here is my stock FA, read direct from car.Typschlüssel=7E23. In this FA config i update all the car modules to last istep 22-11-540
After updating the firmware, if I calculate TAL from the updates, I am offered only two parameters in the NBT block
but when i try to make update there is no firmware update avialable, so all is good in this step.
Now I read FA from car, then edit it in FA editor and change only Typschlüssel from 7E23 to 7E21. Than i make procedure as usual, calculate TAL, SVT, SVT_soll and Esys offer to flash ATM, DME, EGS and HU_NBT.
And here is the most important step. I read that with such flashing, in the FA line I must select an unmodified file. And choose to read the FA with the VCM, not my moded FA. Right?
Also, what checkboxes should I select in the NBT line? Won't this firmware lead to the NBT becoming bricked, with the subsequent impossibility of flashing it? Thanks in advance everyone, sorry for the long post.
      01-18-2024, 01:15 AM   #145
TheNine90
Drives: bmw
You cant flash ENTD and NAVD with esys.
Changing Typschlüssel will bring up different firmware thats why you are getting the new update available. The loaded fa doesnt really matter, its used for cddeploy which is vo coding.
Whatever you do dont select hwinstall and hwdeinstall. Also before calculating tal make sure the HWEL in NBT ot any module you want to flash is black or it will fail in flash. Use Hw id from svtactual button to make it black.
      01-18-2024, 09:47 AM   #146
fedotenkoi
I try make a video step by step what i will do in Esys. Please look and tell me what I'm doing right or wrong. Thank you in advance.
      01-18-2024, 10:22 AM   #147
TheNine90
Drives: bmw
You can try flash
      01-18-2024, 02:30 PM   #148
fedotenkoi
You can try flash
Thank you very much!!! Everething is done.
      01-18-2024, 03:50 PM   #149
fedotenkoi
The only thing you need to do is remove two checkboxes in the settings (I highlighted them with red arrows), otherwise you will get an error when starting flash: a vcm-update after a tal-execution is not possible without a proper fa
and check Read VIN from FA, do not Enter vin, otherwise you will get an error:
serialization of ncd object......
And switch only HU_NBT2 sw Deploy, cd deploy, iba deploy. Other ECU's like DME, EGS etc. don't switch on, ignore it! Flash only NBT Evo.
That's all.
      03-24-2024, 04:14 AM   #150
tonnG
Drives: bmw series 4
Originally Posted by kiwidecal View Post
Cool. Ill try this now then.
Thanks
Is there any guide how to do this?
