BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Oil change interval coding
GetBMWParts
      04-07-2023, 05:54 AM   #45
irzayev
Drives: BMW X5 F15
Originally Posted by TheNine90 View Post
After coding reset oil service.
I have reset it via Service menu on 6WB.
I think I maybe need to reset it via Reinghold?
      04-08-2023, 08:05 AM   #46
TheNine90
Drives: bmw
Its the same.
      05-14-2023, 04:14 PM   #47
OvYdiu16
Drives: BMW F30 328i 2015
Just did this on my 2015 328i, it worked.
I followed atzebmw`s instructions and coded VO from 8KL to 8KP. At first, I coded as he said, change VO and code KOMBI, but that did not work for me, I tried CBS reset but the 16000km/12 month was still there. After that I saw Discordia`s message in which he coded also the DME and HU-NBT and FEM_BODY, the last 2 are kind of optional. After I coded the DME the interval went down to 8000km/12 months. Thank you!
      10-22-2023, 05:07 AM   #48
jboban
jboban's Avatar
Serbia
Drives: 2006 BMW e90 320d
Smile Oil change interval coding
Originally Posted by deusexe View Post
Why there is no 10.000km I must have.
There is a way to have 10.000km / 12m.
DME, 3701 OHNE_ZEITLIMIT, OWI_NEU, Werte=28, 32
      10-29-2023, 12:56 AM   #49
Dragoss91
Drives: F10
sorry for asking already answered questions, is it possible without coding vo or fa ?
      10-29-2023, 02:21 AM   #50
TheNine90
Drives: bmw
Yes. Fdl code in DME and kombi
      10-29-2023, 03:31 AM   #51
jboban
jboban's Avatar
Serbia
Why KOMBI? I have coded only DME with given key values.
      10-29-2023, 12:54 PM   #52
TheNine90
Drives: bmw
One of these values change depending on the option choosen. Sometime it remains same.
CBS_WEG_FAKTOR_FZG_CHECK_DEPEND
Comment=A multiplier for motor oil for the path component of the fzg_check. This factor indicates how often the forecast is added to the remaining path.
CBS_ZEIT_FAKTOR_FZG_CHECK_DEPEND
Comment=A multiplier for motor oil for the time component of the fzg_check.
      10-29-2023, 05:03 PM   #53
jboban
jboban's Avatar
Serbia
I see... Default values for these keys are 5 and 4, but somewhere I saw 2 and 2. How to know what values to use for eg. 10k / 12m?
      10-30-2023, 03:00 AM   #54
TheNine90
Drives: bmw
There is no option for 10k so it hard to know unless someone does it manually.
      03-24-2024, 05:57 AM   #55
DomasF
Drives: BMW F01, E83
I just made it working as needed. Below meaning of the wert. For oil interval change needed only to change one parameter.
DME
3701 OHNE_ZEITLIMIT
OWI_NEU
wert_1 78,64 - 30 tkm 24 m
wert_2 64,64 - 25 tkm 24 m
wert_3 60,4B - 24 tkm 18 m
wert_4 00,00 -
wert_5 30,64 - 12 tkm 24 m
wert_6 78,32 - 30 tkm 12 m
wert_7 64,32 - 25 tkm 12 m
wert_8 50,4B - 20 tkm 18 m
wert_9 3C,4B - 15 tkm 18 m
wert_10 3C,32 - 15 tkm 12 m
wert_11 30,32 - 12 tkm 12 m
wert_12 28,32 - 10 tkm 12 m
wert_13 20,32 - 8 tkm 12 m
wert_14 3C,64 - 15 tkm 24 m
