BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Disabling Cold temp warning
ARMA SPEED
      12-13-2020, 01:21 PM   #1
mazen222
28
Drives: BMW 435i
Hi there,
So before I start I just want to confirm that I have googled this and I was mostly able to find posts about people complaining about cold weather.
That said I also found that I can disable it by coding
CC_TEMPERATUR_WARNUNG
But I have Bimmercode... how do I get to that command? Which module do I go in?
Thx!
Maz
      12-13-2020, 01:34 PM   #2
atzebmw
Germany
588
Drives: Tesla Model 3
You can find it in Kombi under
3000 Anzeige_Konfiguration, 3C
But i'm not sure if it will work.
I just checked the coding values from my old F30 and my current F30 and on both cars this value was set to nicht_aktiv although i get this warning under 3 degrees.
      12-14-2020, 06:34 PM   #3
mazen222
28
Drives: BMW 435i
Thanks I'll try it out.
It's winter here so I get that warning every day! Lol
      11-18-2022, 09:22 PM   #4
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
Instrument Cluster > Expert Mode > 3000 > CC_TEMPERATURWARNUNG > aktiv
      11-19-2022, 05:26 AM   #5
NxTH
AH3 Owner
NxTH's Avatar
201
Drives: BMW 335i ActiveHybrid 3
This is correct. aktiv turns off the chime and message when starting the car. nicht aktiv enables the warning. It's reversed. Will still chime during a drive if temperature lowers past the threshold, but this will get rid of the initial gong.
      11-19-2022, 10:54 AM   #6
AndrewC1989
Know of anyway to disable that too? Haven't found anything in my searches.
      11-19-2022, 04:15 PM   #7
NxTH
AH3 Owner
NxTH's Avatar
201
Nobody has yet to figure it out.
      11-25-2022, 07:11 AM   #8
mazen222
28
Drives: BMW 435i
So annoying…
Did anyone try to contact the Bimmercode guy?
      03-27-2024, 06:57 AM   #9
farhad561
Drives: F97
My 2020 F97 had the following option in bimmercode that turned off the temperature warning completely but also the outside temperature sensor with it. It is now showing 59F permanently. Not sure if that's only gonna happen in Temps under 37F or at all temperatures from now on.
Here is what I did:
Instrument Cluster > Expert Mode > 3000 > TEMPERATURWARNUNG > nicht_aktiv
My Bimmercode did not have the CC_TEMPERATURWARNUNG option at all, but had the above setting instead.
