BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F80 cluster on f30 100% functional
GetBMWParts
      10-31-2022, 06:22 AM   #1
joweed
joweed's Avatar
23
Drives: 2015 340i
Finally fitted a f80 cluster to my f30. All functions work 100% including gear, drive mode changes, m-hud and m shift lights. It's very easy to remove cluster only 2 t20 torx bits and 2 or 3 connectors depending if you have hud. The f80 cluster fits exactly the same as the f30 cluster.
Things you will need:
F80 cluster virginized (you will have a tamper dot if it's not virginized)
Gear adapter: this will convert the signal so it will display gears correctly, not needed for manual gearbox cars. I've used a bimmer ecu adapter but they don't ship outside of the US. I can help with getting a adapter for people outside of the US. You can also use XHP to show gears but it will be set out like a manual f80 on your cluster.
Enet cable for coding
Coding was done by https://instagram.com/bimmerretrola?igshid=YmMyMTA2M2Y=
I've uploaded a video to show the cluster working with all the features on YouTube.
https://youtube.com/shorts/brYTwbwYRWU?feature=share
Appreciate 4
      12-06-2022, 04:35 PM   #2
richsvo
9
Drives: BMW 435Xi Gran Coupe
Just saw this...very cool mod!
Can you share a site to obtain the ecu adapter you mention above and where it goes, or what it takes to install? Would like to do this mod as well.
Thanks in advance!
Estoril Blue 2015 BMW 435i X-Drive Gran Coupe
      12-07-2022, 05:24 AM   #3
NxTH
AH3 Owner
NxTH's Avatar
201
Drives: BMW 335i ActiveHybrid 3
Does an F30 speed limit emulator hooked up to my OEM Kombi work with the F80 Kombi? I also didn't quite understand what the difference is if you only use xHP and ignore getting the gear adapter.
      12-07-2022, 07:41 AM   #4
dangerus_car
Drives: F30
i wonder if you can fit 6wb to F80? if you have 6wa, what makes you want to switch to F80 cluster as it looks similar (hybrid digital/analog) with exception of the grey gauge?
      12-24-2022, 06:26 AM   #5
modalita
Drives: 2014 BMW 328i
So to confirm...if I have a manual transmission F30, really then install the F80 cluster virginized, have it coded and I am good to go?
      12-24-2022, 08:44 PM   #6
eff32fl
eff32fl's Avatar
1052
Drives: 2019 440i M Sport THP MPPSK
I've never seen an F8x car with a 6WB so not sure if it supports M cars and their functionality. I'd be eager to see someone try it lol.
Installing an F8x cluster in an F3x car provides the M HUD plus the cluster looks cooler than the standard 6WA F3x cluster. I'm assuming the dynamic "red line" LED's work as intended that raise as the engine warms, showing your current gear (emulator required apparently), having the "M" on the cluster and like you mentioned the gray gauge is just a little more aesthetically pleasing.
      01-07-2023, 06:52 PM   #7
joweed
joweed's Avatar
23
Drives: 2015 340i
Thanks in advance!
Hi got mine from bimmer ecu
https://www.bimecu.com/f80-cluster-retrofit-adapter
I know there is coke Chinese ones as well. The adapter is connected to the wiring that is on the gague cluster from the car. The install is very simple 2 t20 screws to remove cluster and coding.
      01-07-2023, 06:56 PM   #8
joweed
joweed's Avatar
23
Drives: 2015 340i
No it will not work sadly, the gear adapter emulates signal from dct to cluster so the gears display properly. If you use xhp instead on the adapter, it will show gears on the cluster like a manual f80, you can see neutral, reverse and 1-8 gears. No park and sport mode display.
      01-07-2023, 06:57 PM   #9
joweed
joweed's Avatar
23
Drives: 2015 340i
I prefer the look of the white led at night, better bottom screen, shift lights on cluster, m hud working as well.
      01-07-2023, 06:58 PM   #10
joweed
joweed's Avatar
23
Drives: 2015 340i
Yes pretty much, only need gear adapter for automatics.
      02-27-2023, 12:36 PM   #11
modalita
What about the HUD? Did you have to swap out the HUD unit to a F80 one or were you able to reuse your F30 one?
      02-27-2023, 12:51 PM   #12
toxik
toxik's Avatar
Drives: 2017 340i xDrive 6MT
the HUD data/graphics are generated by the gauge cluster.
      02-28-2023, 05:38 AM   #13
modalita
Thank you so much. One last question. Did all F80s have HUD? I would hope at that price point the answer is yes.
toxik2454.50
      02-28-2023, 08:37 AM   #14
toxik
toxik's Avatar
I believe so yes. fun fact even when I installed my 6WB cluster, some of my HUD graphics were updated, I noticed some of the highway signs on the HUD navigation graphics were different.
      03-04-2023, 08:34 AM   #15
joweed
joweed's Avatar
23
Drives: 2015 340i
I used the hud from my f30, all the mhud info is send from cluster. All you need to do is change cluster to get m hud. I would still double check if m3 cluster has the hud port cos some m3 don’t have hud.
      03-13-2023, 11:22 AM   #16
UN55EXY_F3O
UN55EXY_F3O's Avatar
Drives: 2011 BMW 335i, 2014 BMW 335i
2014 bmw 335i  [0.00]
Trying to get 7 posts. Don’t mind me
      06-01-2023, 11:57 AM   #17
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
Can someone explain what coding is needed after you have the adapter and cluster?
2016 F31 328iX | Alpine White | Black | ///MSport | iND | Eventuri | AC Schnitzer | MPerformance | 513M | Michelin PS4 |
2005 | 330CiC | Sparkling Graphite | Black | 6MT | ZHP
Purchase your W///AGON Stickers Here: https://f30.bimmerpost.com/forums/sh....php?t=1930190
      08-24-2023, 04:10 PM   #18
WagonHo
WagonHo's Avatar
554
Drives: BMW 330i Sport Wagon
I'll add my voice to this request. Installed my F80 gauge cluster today. It was virginized and coded, and I have the BIMECU adapter. I don't get the tachometer in the HUD and the display in the lower part of the tach and lower center display in the cluster isn't showing modes, etc. Also, the Bimecu adapter is supposed to get the current gear displayed in the cluster, but I get an M1, C1, etc., *when the shift is made* but not persistently (reaching out to bimecu about this). These features are visible in Joweed's video at the top of this thread. The cluster is a HUD-ready F80 6WA, so I'm confident it's not the cluster itself.
Did my coder miss something?
All advice, tips, taunts, sympathis, etc., are welcome.
W///AgonHo FB - @WagonHo | IG - @wagon_ho
2019 F31 330i SportWagon | M-Sport | Black Sapphire Metallic over Black Dakota
2016 F31 328i SportWagon | Sport Line | Alpine White over Beige Sensatec (sold - 2019)
2004 B5.5 Volkswagen Passat GLS Wagon | Northern Green | 5-Speed Manual (sold - 2016)
BMW CCA | National Capital Chapter since 2019 - SCCA | Washington DC Region since 2021
      08-24-2023, 11:52 PM   #19
TheNine90
Drives: bmw
It depends on how the cluster was coded. Maybe need coding as f80.
      08-25-2023, 07:18 AM   #20
JDAURIA
JDAURIA's Avatar
725
Drives: F31 MSport
2005 BMW  [0.00]
2016 BMW  [0.00]
Talk with BimmerRetroLA (bimmerretrola.com) he seems to know his stuff and I was planning on using him for coding of F80 cluster when I do the mod as well.
      08-25-2023, 08:46 AM   #21
WagonHo
WagonHo's Avatar
554
Great minds. Seems everyone recommends Will. I reached him last night. He responded very quickly, and he is going to help me sort it out.
      08-27-2023, 12:57 AM   #22
Justin Gang
Justin Gang's Avatar
Austria
Drives: F30 320i 2013
Originally Posted by WagonHo View Post
Great minds. Seems everyone recommends Will. I reached him last night. He responded very quickly, and it's going to help me sort it out.
Were you able to handle with?
