06-23-2020, 06:28 PM | #1 |
21
Rep 314
Brake caliper rebuild kit problems
Hey guys, I'm wanting to rack your brain to see what I am missing here.
I have a 2016 F30 340i and am in progress of doing the hybrid brake upgrade of putting M235i/M240i rear calipers on. Ive purchased the calipers and had them powder coated already. Here is where I am having issues. I disassembled them and brought them to the powder coat place. promptly threw out the old packings and dust boots because I had new ones already on order. Upon reassembly the new o rings and dust boots are not fitting. Ive now purchased 2 different sets of caliper rebuild kits and they just are way to big. Here is the part numbers I am using Caliper: 20.b433.02 and 20.b434.02 rebuild kit: 15441 from Carlson as well as 15441 from auto-zone (duralast i think) Anyone have any input on why none of these rebuild kits are working? I've got 2 more kits coming from Rock Auto (RAYBESTOS WK3318) tomorrow that I will try. Here are some pictures
'16 340i M-Sport F30 Estoril blue, Oyster, Bootmod3, CTS high flow cat, CTS intake
Sold:'07 335i E90 Montego Blue on black leather, Navi, premium, sirius, sport pkg, CA, logic7 Sold: '07 328i E92, SG, Saddle Brown, Gray Poplar, ZSP, CA, Heated Seats, BMW Performance Exhaust, BMW performance SSK, Valentine1, european delivery - Military Sales |
06-23-2020, 09:02 PM | #2 |
51
Rep 94
So you're going to the 370mm front / 345mm rears?
If so, I purchased the following rebuild kits just last week and can verify that they fit perfectly: Manufacture: Centric Front: 143.34039 (40mm pistons) Rear: 143.34040 (40mm pistons) https://www.zeckhausen.com/catalog/i...5096_5774_6220 I'd also pick up a bottle of brake caliper assembly lube if you haven't already. |
Polo088161616.00 |
06-23-2020, 09:05 PM | #3 |
21
Rep 314
on https://www.zeckhausen.com/, I noticed that the M235i has a rebuild set that is for a 40mm piston and the 340i has 44mm rear pistons.
I can only think of two conclusions about my issue. 1: maybe the caliper was mislabeled and is actually for a different vehicle. I dont think this is the case as the seller is selling a ton of parts from a flooded 2015 M235i (I do have the VIN) 2: BMW changed the internals of the caliper from 40 to44mm pistons at some point and it hasn't been noticed. by the general public. I doubt these get rebuilt that often so this could be the case. Anyway i found some other part numbers. Centric 143.34040 should be for the 44mm piston rears on the 340i https://www.zeckhausen.com/catalog/p...ducts_id=16887 Centric 143.35031 should be the 40mm pistons on the rear of "?? SOME ??" M235i vehicles Caliper rebuild kit - rear (40mm pistons) to rebuild one 2-piston caliper It seams that Zeckhausen has the correct info even though getbmwparts.com shows the same part number for the M235i and the 340i caliper. Jason
06-23-2020, 09:10 PM | #4 | |
21
Rep 314
That part number for the rear shows 44mm pistons here https://www.zeckhausen.com/catalog/p...ducts_id=16887 I just measured my rear pistons and they are 40mm so ive got 3 different kits on order. hoping one works since im headed out of town next week and would like to get it finished before i leave. Here is what i ordered: Centric Parts 143.35031 Centric Parts 143.42041 RAYBESTOS WK3318 Thanks for the information.
06-23-2020, 09:19 PM | #5 | ||
51
Rep 94
orangepeelforest21.00 |
06-23-2020, 09:21 PM | #6 |
51
Rep 94
06-23-2020, 09:48 PM | #7 | |
21
Rep 314
06-23-2020, 09:58 PM | #8 | |
Rep 5,404
06-23-2020, 10:17 PM | #9 | ||
21
Rep 314
06-23-2020, 11:51 PM | #10 |
51
Rep 94
My front 370mm and rear 345mm caliper piston diameters with o-ring and gasket rebuild kit parts.
06-24-2020, 05:06 AM | #11 | |||
Rep 5,404
06-24-2020, 09:47 AM | #12 | |
21
Rep 314
the part number of the M235i rear brake caliper with the 40mm piston is: 01 Caliper housing left 1 11/2012 34216860737 01 Caliper housing right 1 11/2012 34216860738 and for the 340i they are: 06 Caliper housing left 1 34216799461 06 Caliper housing right 1 34216799462
06-24-2020, 04:00 PM | #13 | ||
Rep 5,404
06-24-2020, 04:13 PM | #14 | |||
21
Rep 314
I am hopeful but not optimistic that they will actually work with my car
06-26-2020, 12:39 PM | #15 |
21
Rep 314
just in case anyone is following this or runs into the same problem as me, M235 brakes will fit the f30.
I used an f30 345x24 rear rotor and m235i rear calipers. you can find the part numbers in my post above.
06-26-2020, 04:16 PM | #16 |
Rep 1,079
I've been lurking around on the 2addicts forum lately, looking for the same rear calipers to match the front brembos.
08-18-2020, 10:06 PM | #17 |
Rep 1,934
So was anyone able to confirm the reason bmw went with a new part number for the 2piston rear Brembos? Is it real y'all just a color change?
08-18-2020, 10:31 PM | #18 | ||
Rep 3,958
08-20-2020, 11:51 AM | #19 | |||
51
Rep 94
10-10-2020, 10:48 AM | #20 |
Rep 1,934
OP did the RAYBESTOS WK3318 kit work for you? I want to get bleeder caps in the set as well. Everywhere I look this reybestos part number lists the M3 and M4 so I know it should fit the 2pot Brembos with 44mm pistons. Just want to make sure.
brakes, brakes calipers |
