BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > 2- STEP/ NLS for MHD Users
      08-03-2017, 01:13 PM   #1
ihernandez7910
Drives: 08 E90 335i 6 spd MT
2008 BMW 335  [0.00]
Modern Performance sells a cool Wot Box that enables 2- Step and NLS for us with MHD.
https://www.modernperformance.com/pr...-4-electronics
Install DIY PDF Is attached.
If you have a MT - this is must... loosing boost between shifts makes your a slow SNOWFLAKE!
      08-03-2017, 01:16 PM   #2
suspenceful
suspenceful's Avatar
Drives: 2015 M3, 2008 135i, 2009 335i
Gonna have to bookmark this to reference if I get rid of JB4. Thanks!
750whp 135i Build | Budget 335i Build | F80 M3 Build
🎬 YouTube channel (35K+ subs): youtube.com/jakespence135
📷 Follow me on Instagram: instagram.com/jakespence
🏁 Shop BMW merchandise: bimmerstreet.com
      08-04-2017, 02:09 AM   #3
TheAllOriginal
TheAllOriginal's Avatar
Drives: 2013 e92 335is
Wot box is old news lol, something to note is MHD is working on NLS and 2-step.
      08-04-2017, 09:03 AM   #4
ihernandez7910
2008 BMW 335  [0.00]
Yes it is. It's been around for a while. Not many people in this platform know about it.
MHd has been working on a lot of features for a long time.. we've seen maybe 20% of them
Bluetooth adapter for example...
I sure as hell won't wait
      08-04-2017, 09:35 AM   #5
TEC
Drives: 355
It has been noted elsewhere that this device cuts power to the coils and may case misfires and other serious issues (read: engine failure).
jc335i0.00
      08-04-2017, 09:49 AM   #6
ihernandez7910
2008 BMW 335  [0.00]
Shitty installs
      08-04-2017, 02:40 PM   #7
TEC
Drives: 355
Originally Posted by ihernandez7910 View Post
Shitty installs
Yeah, I'm sure that was the reason.
To quote someone on another forum discussing the same piece of hardware:
I certainly wouldn't say works perfectly. As I said earlier anything that cuts (or interrupts) the primary charge will fire that coil early.
To give you an example, the factory coils charge about 2.5ms. An engine running at 7k rpms rotates 42 deg every ms. If you interrupted that coil charge a ms early you advance that cylinder by 42 degrees. That's enough to cause pre ignition type damage, and certainly detonation even with good fuel. With this platform moving to move powerful coils with longer charge times the effects will be even more pronounced.
The 2 step has a little less effect because of less loads and lower rpm but the same thing is still happening
You'll probably ask why we haven't "seen" a bunch of motors blown up from them, the answer is we probably have and it's blamed on other things like port injection or the tune ect.
I know of two local cars that have blown motors that were using NLS.
      08-04-2017, 02:57 PM   #8
ihernandez7910
2008 BMW 335  [0.00]
Doesn't the JB4 2-Step/ NLS also cut power to the coils?
      04-15-2024, 02:44 PM   #9
jc335i
Drives: bmw 335i n54
Can I have your help setting up my wotbox if you don’t mind could you check my post?
