12-19-2019, 01:03 PM | #1080 |
2948
Rep 21,783
PM coming your way
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
12-24-2019, 02:20 PM | #1082 |
Rep 27
Kevin, looking for a quote for a 15/12 setup and a 12/10 setup. I'll be lowered on M Performance HAS. Zip code 19701. Thanks.
Also - I saw someone else post about this recently but didn't see an answer - does this require new lug bolts? |
12-26-2019, 06:56 PM | #1083 |
2948
Rep 21,783
PM coming your way
12-31-2019, 11:38 PM | #1086 |
Rep 7
Hey Kevin can I get a quote one 15mm front and a 12mm rear shipped to 44113. I saw that is still the "normal" fitment for OEM 19" 437Ms right? Still stock suspension with 255/275, but I also plan on going 265/285 after the OEM tires are gone.
01-04-2020, 11:16 PM | #1088 |
Rep 1,988
Can you PM me a quote for an extended wheel lug for 10mm spacers shipped to 11360? Just noticed that I'm missing one somehow...
Thanks!
2022 X5 45e : AW/Tartufo
2018 M3 Competition : AW/SO 2016 340i xDrive : AW/CR (sold) |
02-03-2020, 02:25 AM | #1089 | |
17
Rep 139
2015 M4 NON-ZCP I've got 20x9 et25 front and 20x10 et34 rear wheels. Im running Michelin PSS 265/30/20 front and 295/30/20 rear. Im not lowered yet but planning to do a verrrry modest drop with KW HAS. What size spacers should i run to get a truly flush fitment for my M4 |
02-03-2020, 01:31 PM | #1090 | |
2948
Rep 21,783
02-08-2020, 10:41 AM | #1091 |
91
Rep 76
Hi there,
I’ve read the 10 first pages but generally do not find set up in line with the one I want. I have a F80 M3 with 763M wheels (same size as CS 285/30 rear and 265/35 front). I foresee a drop with Swift Spec R Springs, and I don’t know what spacers to use. I am located in Luxembourg / France and I am using the car on WE mostly to drive fast on little roads. What size would you recommend ? I thought about 12 front and 10 rear in order to be sure no to rub on big compression. Thanks a lot ! Gaël |
02-08-2020, 03:10 PM | #1092 | |
2948
Rep 21,783
02-09-2020, 01:25 PM | #1093 | ||
91
Rep 76
02-18-2020, 03:58 PM | #1094 |
34
Rep 305
@kevin, please PM me best size and quote for two cars-
M4 Comp 666M with Pilot SS, but will be switching to PS4S shortly 265/30/20 Front & 295/30/20 Rear Lowered just over an inch on KW HAS M3 Stock 19 in wheels with stock Contis 255/35/19 Front & 275/35/19 Rear Lowered just over an inch on KW HAS Shipping to 94582 |
02-18-2020, 04:24 PM | #1095 | |
2948
Rep 21,783
02-18-2020, 05:11 PM | #1096 | ||
34
Rep 305
02-27-2020, 12:58 AM | #1097 |
66
Rep 54
Looking for a quote:
15/12 for M3 on H&R springs adaptive suspension, 437s stock tires Also a set of 15/20 for a F15 X5 if available. both sets shipped to 97124 Thanks! Last edited by JetdaCorg; 02-27-2020 at 01:34 PM.. |
02-27-2020, 01:18 PM | #1098 |
Daily Driver
29
Rep 71
Quote for 12/10 with lugs to 97205
Sounds like that's the 'proven' set up for 666M and modest drop? Have a 2020 F83 (Comp pkg) coming for my wife. Will lower 20-25mm on KW HAS and plan to run the 666Ms with PS4S in OE sizes. If it's not slammed, would 15/12 be a better option? Thanks
2012 E93 M3 Convertible : Alpine White / Black : KW V3 : Akra Ti : HRE : ModeCarbon GTS V2
02-27-2020, 01:36 PM | #1099 | ||
2948
Rep 21,783
03-08-2020, 07:48 AM | #1100 |
Rep 10
Not seen many posts for 20s and lowered on m4
Advice and quote on following set up please 20x9 et35 with 265/30 tyres front 20x10 et40 with 285/30 tyres rear Also car is lowered 40mm all round with HR springs Thinking 20 or 25 front and 12 or 15 back Wanting something aggressive but no rubbing Last edited by kcjo57; 03-08-2020 at 08:05 AM.. |
aggressive, eas, extended lug, lugs, macht schnell, offset, spacers |
