BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > General BMW News and Cars Discussion > Has anyone experienced this noise from rear?
proTUNING Freaks
      08-14-2021, 04:45 PM   #1
BM-Dollar
Drives: BMW 528i
Question Has anyone experienced this noise from rear?
Hi Guys/Gals,
Has any of you experienced this kind of clicking noise from the rear?
Youtube Link:
it seems to be from the passenger side and it becomes more prominent when I turn left (so putting weight on the passenger rear)...What do you think is causing it? Any thoughts on tests I could do to figure it out?
2015 BMW 528i F10 (Base)
Thank you so much every one
Last edited by BM-Dollar; 08-14-2021 at 04:51 PM.. Reason: ask more clarifying questions so community can better help :)
      08-14-2021, 05:13 PM   #2
overcoil
Drives: M235i 6spd
sounds like an incorrect, too long, lug bolt tapping against the emergency brake hardware inside the hub.
sometimes happens when you get new wheel and wheel hardware.
if it has just starting occurring with no new changes to car I don't know.
      08-14-2021, 06:30 PM   #3
BM-Dollar
Drives: BMW 528i
Caravaggio
thank you for your feedback. I actually changed the wheel bearing there recently.
any suggestions for making the noise go away or fix it properly?
Best,
      08-14-2021, 07:20 PM   #4
overcoil
Drives: M235i 6spd
Originally Posted by BM-Dollar View Post
Caravaggio
Best,
You need to deconstruct down to the wheel bearing. Not sure but are you supposed to use a dial gauge to confirm the bearing is seated ?
You could find you forgot to tighten a caliper bolt properly, or whatever.
But definitely remove the wheel inspect and if you are able to lift the rear safety with the transmission in neutral rotate the wheel and listen.
Obviously when up a garage lift this would probably be a quick diagnosis.
      08-14-2021, 09:15 PM   #5
BM-Dollar
Drives: BMW 528i
I also found these two guys whose noise sounds super similar. Looks like their issue went away after they thoroughly cleaned the mating surfaces of wheel inside and rotor.
      08-17-2021, 12:34 PM   #6
JasonDot
JasonDot's Avatar
581
Drives: M4, X3 and 330e
This thread isn't about farts?
nerdogray1301.50
      08-25-2021, 05:36 PM   #7
Fuzzuki
Drives: BMW 335i Porsche Boxster Honda
Sounds like your buddy tapping two wrenches together as you drive past....LOL
