09-19-2018, 04:58 PM | #23 | |
2630
Rep 2,141
Drives: 2011 E92 M3
I will try some different gas and check with a scope. Running with a tune would just make this a little worse because the tune is a bit more aggressive? Cheers,
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
09-19-2018, 05:07 PM | #24 |
Rep 3,988
sounds like if a tune is not adjusting to lower quality gas by pulling timing and a stock tune is, wouldn't that mean knock sensitivity is being reduced in the tune? That also makes it less safe, and i'd be very skeptical running that tune if that is the case.
09-19-2018, 06:34 PM | #25 | |
Rep 413
So, if the knock is a result of pre-ignition, by definition, the DME can not detect nor correct for it. Additionally, since it's *pre*ignition, pulling timing won't make a difference anyway. Now, there some other maps than can be adjusted, that can feed into the conditions which set a CC with heavy carbon deposition up for pre-ignition to occur, and those are often modified without much understanding of what they do. There are also differences in some of those maps from one OEM calibration file to another as well as the for fuel quality. Along with knowing what program version (241, etc), it's good to know what OEM calibration your tune is based off of. I suspect a lot of tuners don't actually modify the base file that should be in your car or was read from your car, but copy and send one from a stash of already modified files. |
09-19-2018, 08:05 PM | #27 | |
Rep 466
09-19-2018, 10:10 PM | #28 |
2630
Rep 2,141
Drives: 2011 E92 M3
Coils are original, 44,000KM.
Only 94 octane I can get here is Husky. So, I have a full tank of Husky 94, with a can of SeaFoam in there. Hope to have a buddy help me put a can of SeaFoam through the intake in the next couple days. Then I will do some more testing with the tune. Cheers and thank you for all the help. This forum rocks!!
09-20-2018, 06:50 PM | #29 |
Rep 3,140
Drives: 2014 M5 6MT
How about don't lug the engine......... just a thought.
Engines designed to make peak power at 8k+ rpm's are not designed to produce alot of torque low in the rpm range. Try driving around in a lower gear for lower speeds.
2014 M5 6MT
09-20-2018, 07:00 PM | #30 |
274
Rep 2,664
Drives: Goggomobil
I had the same issue and the car was not enjoying driving it. The more you floor and pre-detonation starts and finally it threw a code and went to limp mode. I suspected it to be ignition coil because the code came from cylinder 2. When I removed the spark plugs were bad and especially on cylinder 2 they were touching through carbon build up. New plugs and Liqui Moly fuel system cleaner and RON98 fixed the problem. The cars in now like new - driving experience is like day and night.
F86 X6///
09-20-2018, 08:20 PM | #31 | |
Rep 413
True, peak BSFC won't be found when lugging, but max fuel economy is. If he hadn't, he wouldn't have heard the sound and been warned of a potentially problematic internal condition in the engine. Carbon deposits reduce heat transfer to the piston and valves and create hotspots in the engine as well as reducing air flow on the intake stroke. This last point is problematic as the DME runs open loop fueling on full throttle and relies on the VE map entirely to set fueling properly. What's interesting is that one DME calibration may allow it to happen and one won't. |
09-20-2018, 08:58 PM | #32 | ||
Rep 3,140
Drives: 2014 M5 6MT
I agree to the point the preignition is bad and fixable. But lugging the engine is just bad practice.
2014 M5 6MT
09-20-2018, 09:42 PM | #33 | |
2630
Rep 2,141
Drives: 2011 E92 M3
I do not choose to lug, but when I make a right hand turn on the city, I typically stay in second gear. The engine may not perform well, but it should not ping...
09-21-2018, 09:27 AM | #34 | |
Rep 1,144
I changed my spark plugs recently, no plugs showed excess signs of wear. My next move is O2 sensors, then possibly a fuel system cleaner as I don't trust the NJ gas. I only put 93 in my car. Keep me posted if you find a resolution. |
09-21-2018, 09:46 AM | #35 |
Rep 5,483
This happens sometimes on mine, it's pretty inconsistent. Sometimes you can just crank along at low rpm and load it up and it doesn't care, sometimes you get a ping or two, and it doesn't seem to amtter how warm or cold out it is. One thing I've noticed is that as soon as you back out of the pedal from "WFO" or "requesting WFO" or whatever it's actually giving you when you floor it, even just a little, it goes away. When we ask for wide open throttle at low rpm, are we actually getting it or are the throttles partially shut with the stock tune, and open all the way with aftermarket tunes? Would it even matter when the car's still ramping up to peak torque down there in the 2-3k range?
I scoped my pistons last time I did plugs at 104,000 or so, and everything looks pretty good though I didn't look at the valves and couldn't see the piston edges very well, so that's not all that conclusive one way or another. It hasn't gotten appreciably worse over the life of the car though. Evolve Tune, on the car for like 100,000 miles. It's done this for as long as I can remember, again intermittently, regardless of whether I had flashed back to stock etc. I'm almost always filling with BP 93. Fwiw, I can't recall this ever happening in 2nd gear. Usually 3rd 4th 5th at city speeds, rolling up to intersections and leaving in gear as lights change, that kind of thing. Maybe I'm just not noticing it because it's a transient and the car moves through the revs quickly in 2nd, but it seems to pull cleanly from low rpm in 2nd every time Interesting thread
09-21-2018, 09:49 AM | #36 | |
Rep 1,489
What does it stand for? |
09-21-2018, 11:17 AM | #38 |
2630
Rep 2,141
Drives: 2011 E92 M3
Just ran a can of sea foam through the intake. Pita to hold the car at 1800rpm without help. Thankfully I have some construction clamps that worked!!
I will re-flash to 91 octane stage 1 soon. Going to run a full tank of 94 with sea foam to give it a good chance to clean the tops of the chambers. Here is hoping. Cheers,
09-21-2018, 06:10 PM | #39 |
2630
Rep 2,141
Drives: 2011 E92 M3
And then this happens. FFS.
09-21-2018, 07:57 PM | #41 | |
134
Rep 272
I will say tho, putting in brand new coil packs all around and running Chevron Techron Concentrate Plus (in separate instances, not done at the same time) made the most dramatic improvement, especially the former as it instantly restored the urge/eagerness to rev on my aging S65, it was to the point where I could dial back my throttle input a little to achieve the same, or if not stronger, pace of acceleration as before. And the latter allowed the engine to run notably smoother and quieted down the (old) injectors. But nothing lasted, the det always slowly creeps back. Like some of the guys here have mentioned, my main tech firmly believes it's octane induced given the lowly 91 premium fuel we get in CA. The one thing I never did remember to try was to run octane booster or mix in some race fuel to bring up the octane and run that for an extended period of time. My latest attempt to address this seemed to have worked well so far - I replaced all of the injectors. And the past couple months have truly been knock free, especially in low rpm instances where sometimes I was caught being in one gear higher than where I needed to be in. Was supposed to send my old injectors out to get flow tested, just to see what kind of shape they were in, but i think the shop lost them... Maybe with the crappy 91 gas being the only option available my injectors will eventually wear and develop the pre-det again, but just wanted to share my experience as the car has been a blast to drive the last 3 months without me ever thinking/worrying about triggering this noise
~ S65 + Harrop Love ~
Scharbag2629.50 Assimilator1594.00 |
09-21-2018, 08:18 PM | #42 | |
2630
Rep 2,141
Drives: 2011 E92 M3
Cheers,
09-22-2018, 09:47 AM | #43 |
Rep 5,483
Injectors are on my PM preemptive send off to somebody to get checked list next time I have the manifold off. Too many stuck injector horror stories
09-22-2018, 10:58 AM | #44 | |
2630
Rep 2,141
Drives: 2011 E92 M3
Cheers,
