Go Back   7Post - 7 Series Forum > BMW 7-Series Forums > (F01) 7-series General Discussions
      12-07-2010, 03:21 PM   #1
BMW Alpina
BMW Alpina Enthusiast
BMW Alpina's Avatar
Drives: Alpina B7
Dinan tune Alpina B7 to 573 horsepower !
http://www.dinancars.com/shop/D900-4...ve.aspx#page=1
D900-44TB
The top of the line just moved up a notch.
This item is worth 2 point(s) towards your Dinan Badge.
Price: $3,499.00
Special Product Notes
Not applicable for xDrive. See required products.
Product Description
Propelling it up that notch is the Dinan Stage 1 Performance Engine Software. As always, Dinan matches the new car warranty coverage for up to 4 years or 50,000 miles, including the possibility of consequential damages. No one offers better performance or backs it up with such comprehensive warranty coverage.
The Dinan Performance Engine Software safely increases turbo-boost pressure from the stock 14.0 to 18.0 psi, along with properly retuned fuel mixtures, ignition timing and full map rescaling. In fact, over 2000 lines of code have been addressed, producing substantial increases in power output while maintaining the civility and reliability expected of a Dinan performance product.
Top Speed Governor Removed. With Dinan’s software, the B7 will be capable of achieving its natural top speed as the governor has been removed.
The results of Dinan’s tuning are nothing short of breathtaking, with the added boost and related recalibration producing maximum output of 573 horsepower at 5500 rpm and 644 lb-ft torque at 3500 rpm.
Note: When programmed, the pressure sensors in both intercoolers must be replaced with 2x BMW #13 62 7 585 494. Refer to TIS procedures 1362591 and 1362592. These sensors are not included with the software, and must be purchased separately from your BMW dealer.
Specifications
Labor Hours 1.5
Emission Status This product is in compliance with U.S. EPA Memorandum 1A, or this product has not been found, nor is believed to be, unlawful for use under the provisions of the Clean Air Act. Currently: This product is legal in California only for racing vehicles, which may never be used upon a highway.
Max HP Gain 573 hp @ 5500 rpm
Max Torque Gain 644 lb/ft @ 3500 rpm
Peak HP 68 hp @ 6500 rpm
Peak Torque 100 lb-ft @ 3500 rpm
Required Products Note: When the car is programmed, the pressure sensors in both intercoolers must be replaced with 2x BMW #13 62 7 585 494. Refer to TIS procedures 1362591 and 1362592. These sensors are not included with the software, and must be purchased separately from your BMW dealer.
      12-07-2010, 10:35 PM   #2
Cocodrilo
Cocodrilo's Avatar
Drives: 2011 BMW activeHybrid7 beast
Can we get one for the activehybrid 7?
2010 activehybrid 7 (DD)
2011 458 Italia
2011 Porsche 911 Turbo S (SOLD) -amazing car-
      12-08-2010, 03:45 AM   #3
BMW Alpina
BMW Alpina's Avatar
Drives: Alpina B7
I am sure you can tune your AH7, but
you need to contact Dinan and be willing to have your car as the first "experimental" car to developed the tune.
unless someone else have volunteered with their AH7.
      12-12-2010, 05:01 PM   #4
lifesgud2
16
Drives: 2013 MCB M5
dyno numbers please..573 hp means nothing without truly knowing the WHP numbers..
alpina b7, boost, chip, dinan, ecu
7post
