Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      08-13-2015, 03:58 PM   #45
M4GTS
66
Drives: Car
Is it true that EU spec. cars don't have the Charcoal filters installed?
      08-13-2015, 05:07 PM   #46
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
ETK says no charcoal liner on EU models. If you can follow up to verify, that would be great!
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      08-13-2015, 05:16 PM   #47
M4GTS
66
Drives: Car
Will do, I plan to fit my BMC filters tomorrow.
      08-27-2015, 02:51 PM   #48
M4GTS
66
Drives: Car
Finally got round to doing this and can confirm there are no charcoal filters on my UK spec. car.
One point, the DIY guide suggests just 7NM/16NM for the Strut brace bolts. This seems a little low as that's barely hand tight.
iatacs19458.50
      08-28-2015, 07:25 AM   #49
Who's on first
Who's on first's Avatar
Drives: A-10C
Great T.O. !
Definitely second the advice of a long T-handle for the T25. Also are the 10 mm screw is shorter than the others so be aware of that you can easily be dropped.
21 minutes, hood open to hood closed.
      08-30-2015, 04:12 PM   #50
335iFFM
23
Drives: 335i Performance
Tried to delete charcoal filters on EU-spec model. They aren't there. Seems like they are deleted from factory. Bought car brand new.
Xtabi1701.50
      08-31-2015, 12:22 PM   #51
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Originally Posted by I hate picking user names View Post
Great T.O. !
Bolts are 6mm and 8mm shank, they don't need to be torqued much.
Thanks for the feedback on the EU side, appears the charcoal liners are a US thing only.
      09-08-2015, 11:31 AM   #52
C-Mu
Drives: 2016 M4
I'm in CA and for emissions purposes and to keep the car as stock as possible, I'd like to keep the charcoal filters but would love to hear the turbos a bit more. Can anyone comment if there is an audible difference by installing the BMC and keeping the charcoal? Thanks.
      09-08-2015, 11:32 AM   #53
Who's on first
Drives: A-10C
I hear zero difference, even with the charcoal filters removed.
      09-08-2015, 09:55 PM   #54
SSIMPS
SSIMPS's Avatar
Drives: 2018 X3 M40i
Great write up , install was super easy and I actually thought it was kind of fun removing the strut brace and feeling how light it is! I can hear a slight increase in spool sound in the higher gears as others have said. Not sure if the new filters or removing the charcoal though. Excited to hear how it sounds with the JB4 when it comes in.
2018 X3 M40i - JB4 / BMS Billet Intake
2015 M4 6MT - JB4 / Gintani DPs
2005 M3 6MT - VF Engineering S/C / KW / StopTech / Dinan / HPF Stage III (removed)- Track Toy
      11-25-2015, 11:11 AM   #55
sh55
sh55's Avatar
Drives: %E2%80%9805 E46 ZCP 6MT and '9
tom @ eas Just want to say thanks for the great guide! I just used it to remove my charcoal filters
______________________________
?05 E46 M3 ZCP 6MT
?06 C55 AMG
'97 911S 6MT
      11-25-2015, 12:50 PM   #56
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Glad to help guys!
      12-04-2015, 03:46 PM   #57
AlphaOmega4
Drives: YMB M4
did you add BMC or K&N filters as well ....
or just remove your charcoal filters and kept the stock air filters?
In all your ways acknowledge Him, And He shall direct your paths.
      12-04-2015, 04:43 PM   #58
M4GTS
66
Drives: Car
I didn't have any charcoal filters, but I did hear a marked difference when I installed the BMC ones. It was amplified much further with the addition of JB4.
      12-04-2015, 05:00 PM   #59
Who's on first
Drives: A-10C
Added BMC as well.
      01-30-2016, 07:07 PM   #60
Xerxes480
Xerxes480's Avatar
130
Drives: 2018 Porsche Macan GTS
Thanks for these excellent instructions. Just removed my charcoal filters and put in BMC filters. Strangely enough the only difficult step was step 1. The head popped off one of the compression rivet pins - was a pain in the ass to get out! The rest was smooth sailing.
I skipped steps 5 and 13.
-X-
      02-03-2016, 05:44 PM   #61
F30MSport
F30MSport's Avatar
Drives: 2016 Alpine White M3 6MT
A panel air filter is commonly referred to as a replacement air filter. It is installed in the vehicle's original airbox to replace the OEM air filter. It is made of high performance materials that allow for an increase in air flow along with more efficient filtration. These BMC filters guarantee containment of all impurities from as small as 7 microns, as compared to the OEM's 10 microns.
BMC air filters are produced using a full molding system that enables the characteristic red filter to be realized from a single mold with no welded joints, thus avoiding easy breakage. The rubber used in BMC air filtering systems has a long life, is very durable and has optimum adhesion characteristics to all shapes of airboxes. BMC filters are made of a multi-layered cotton gauze soaked with low viscosity oil covered with an epoxy coated alloy mesh to ensure protection from petrol fumes and oxidization due to air humidity. All BMC air filters are pre-oiled, and they can be washed and regenerated by using an appropriate regeneration kit.
Installation
BMC High Performance Replacement Air Filter (set of 2)
http://europeanautosource.com/bmc-hi...nt-air-filters
Tools needed
T25 Torx driver
Pocket screwdriver
10mm & 13mm Wrench (socket)
Trim Removal Tool
Installation
1. Remove compression rivet from trim cover
2. Remove plastic nuts from right bank cowl cover, note these are twist-lock design (90-degree twist)
3. Remove compression rivet from trim cover
4. Remove plastic nuts from left bank cowl cover, note these are twist-lock design (90-degree twist)
5. Remove compression rivet from strut tower brace trim cover
6. Remove Bolts securing strut tower brace (13mm), nut on coolant reservoir is 10mm.
7. Carefully remove strut tower brace and admire BMW's craftsmanship.
8. Remove bolts on right airbox with T25 torx driver to reveal filter
9. Remove filter lid
10. Remove charcoal liner with small pocket screwdriver to release tabs
11. Drop new BMC oiled filter in place. filter comes pre-oiled from factory. Reinstall filter lid
12. Pinch plastic securing mount and lift on right filter housing to move out of place
13. Pinch/remove PCV hose and remove. Remember to reinstall after filter is installed.
14. Remove bolts on left airbox with T25 torx driver to reveal filter
15. Remove filter lid
16. Remove filter lid
17. Reinstall left filter lid
Torque Specs
Airbox: Snug to fit/hand tighten
Strut tower brace
13mm: 10-12lb-ft.
10mm: 3-5lb-ft
Enjoy! Feel free to respond to the thread with any questions.
When re-installing the carbon brace can you hand tighten? Is the torque wrench truly necessary? Also did the lb/ft you reference OEM spec?
Thanks!
Alpine White '16 M3 6MT
      02-03-2016, 05:49 PM   #62
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Thanks!
Hand tighten to snug will be fine, most shops (including ours) will verify with torque wrench.
Basic torque wrench is about ~$75 at your local Sears/Craftsman, always a good investment.
      02-18-2016, 03:06 PM   #63
j09333
58
Drives: F80 M3
Thank you for this guide
      02-18-2016, 06:58 PM   #64
Arnold_Powers
that M guy
Arnold_Powers's Avatar
Drives: F82 M4
The vehicle does need to be in the air on the lift correct ?
F82 M4 6MT
      02-18-2016, 07:56 PM   #65
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
A lift isn't required for filter swap. Very simple DIY.
      02-18-2016, 08:30 PM   #66
Arnold_Powers
that M guy
Drives: F82 M4
Someone was telling me that I should not remove or reinstall the strut bar when car is on the floor... I told him he is wrong and he argued that "it should be on a lift with wheels off the ground" ... This is why
F82 M4 6MT
bmc, charcoal, eas, filter, intake
f80post
