BMW M3 Forum (E90 E92)
  TireRack
      01-15-2024, 02:00 PM   #1
acole75
Drives: bmw 328i
Lightbulb Will these wheels fit my 2010 bmw 328i?
I have a 2010 bmw 328i coupe with the m sport package. My standard fit is 225/40r18 for fronts and 255/35r18 for rear. Can I put 245/40/r18 snow tires on for all four?
      01-15-2024, 05:57 PM   #2
pirategenes
21
Drives: E90 M3
This is the exact setup I have on my E90 M3 and it works great. Also what Apex Wheels recommends:
https://apexwheels.com/fitment-guide...t-guide#winter
      01-15-2024, 07:58 PM   #3
M3SQRD
M3SQRD's Avatar
2164
OP has a 328, not M3. M3 fitments are way too aggressive for non-Ms.
OP - this is the e9x M3 forum. Post your question in the wheels/tires forum on the non-m e9x forum:
https://www.e90post.com/forums/forumdisplay.php?f=12
S65Hunter1187.50
      01-15-2024, 10:46 PM   #4
pirategenes
21
Drives: E90 M3
Looks like Apex Wheels recommends the same winter setup for OP’s car:
https://apexwheels.com/fitment-guide...-fitment-guide
      01-15-2024, 11:19 PM   #5
M3SQRD
M3SQRD's Avatar
2164
Not sure what I’m looking for specifically. However, all of the offsets for 8.5” and 9.5” wheels were less aggressive (higher offsets) than stock e9x M3 wheels. If there’s a specific fitment then please list the wheel width, offset and tire sizes. I’m curious to see what winter setup Apex recommends for both M and non-M e9x.
      01-16-2024, 07:36 AM   #6
pirategenes
21
Drives: E90 M3
Not sure where you got lost, so I'll post directly here in addition to the links I provided above. Apex Wheels Winter wheel/tire recommendations:
E9X M3:
Front & Rear: 18x9" ET30 or ET31 (EC-7) with 245/40-18 winter tires
Available in: ARC-8, EC-7, EC-7RS, FL-5, SM-10, SM-10RS, VS-5RS
Direct fit.
E9X Pre-LCI non-M (what the OP has):
Direct fit.
Between the "####" is direct copy from the Apex website. I hope this clarifies.
      01-16-2024, 08:27 AM   #7
M3SQRD
M3SQRD's Avatar
2164
E9X M3:
Direct fit.
Direct fit.
Very surprising recommendation for the M which comes with rear 9.5et23 or 10et25 wheels from the factory and oem recommend winter tire sizes are 235/255. 9et30/31 are extremely sunken into the rear wheel wells. Handling in any conditions will not be optimal for the M with a 245 square setup with the front sticking out ~0.25” and the rear sunken in ~0.75” - a 1” combined relative shift in front-rear wheelbase per side. Again, this is going to change, along with a 245 square setup, the balance and handing, resulting in massive understeer which is the last thing you want in snow driving conditions. Absolutely terrible recommendations for the M in any driving conditions.
      01-16-2024, 08:31 AM   #8
pirategenes
21
Drives: E90 M3
Here in Michigan we get snow, and I like to safely drive the car. This is the setup I have and it works great in snow. That said, I do use spacers to correct the wheelbase discrepancies you mentioned.
      01-16-2024, 10:13 AM   #9
M3SQRD
M3SQRD's Avatar
2164
Yeah, odd recommendations with one being less aggressive than stock and the other very aggressive compared to stock. I guess they’re probably using the most aggressive 9” wheel offset they offer on the M.
I run Dunlop 3D 235/40-18 on 18x8et27 and 255/40-18 on 18x9et20. Balance and driveability are good.
m3post
