TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Classifieds Section > BMW CREE LED Angel Eyes | 2-Year Warranty | 10W, 20W, 32W & 40W | Horizon LEDs
Closed Thread
      10-02-2014, 05:52 PM   #397
tom619
26
Drives: 320d M Sport Business Edition
Originally Posted by kev335i View Post
Not sure what you ordered I got my interior led kit today was sent recorded so if its gone missing I'm sure there's noting to worry about
I ordered the 20w led angel eyes gold edition on 15/09
      10-03-2014, 08:40 AM   #398
HorizonLEDs
HorizonLEDs's Avatar
17
Drives: Honda Accord
All delayed Angel Eyes should be with you now guys, latest tomorrow.
      10-07-2014, 06:30 PM   #399
HorizonLEDs
17
Big thanks to Kev for forwarding us these pictures of his pride & joy rocking our 40W Gold Edition Cree LED Angel Eyes!
Little review & further pictures from Kev on this thread: -
http://www.e90post.com/forums/showth...1#post16745561
Enjoy...
Great photos, really shows off the quality on our BMW Angel Eyes. Again thank you Kev for the pictures, a job well done indeed as it can be tricky getting good shots of these LEDs
Thanks,
Zain @ Horizon LEDs
      10-09-2014, 01:54 PM   #400
AdzC
Drives: E92 335d
Fancy some of these ^^^^^^^^^^
Do we get any discount?
Space Grey E92 335d
1998 Yamaha R1
      10-10-2014, 04:41 AM   #401
tom619
26
I installed the 20w angel eyes on my LCI halogen E90 last weekend. They look great but I have noticed that my o/s outer ring is not as bright as the n/s outer ring. Is this normal?
      10-10-2014, 07:38 PM   #402
HorizonLEDs
17
Yes you sure do! Send us a PM
      10-10-2014, 07:41 PM   #403
HorizonLEDs
17
Hi,
Yes this sounds normal, due to way the rings are designed and with the bulb being fitted into the centre of the inner rings. If you look at it from a distance (as if to say your an oncoming driver) these should look very different. It all depends on the angle you look at them from too.
Also if you have a look through this thread there is a better explanation somewhere of how these work with a diagram showing how the light is reflected through the rings.
Thanks
      10-10-2014, 07:55 PM   #404
HorizonLEDs
17
This BRAND NEW & EXCLUSIVE product may be to some interest of a few members on here: -
https://www.facebook.com/media/set/?...7917262&type=1
Now available to order directly from our website: -
http://www.horizonleds.co.uk/cree-le...ht-bar-10-inch
Some pictures below: -
Dimensions
Product
Night Before Shot
After Shot
Just check out the specifications for this small, discreet yet powerful LED light bar: -
  • Technology – x5 High Power 10W Cree XM-L LEDs.
  • Wattage – Total 50W.
  • Operating Voltage – 10W to 30W.
  • Lifespan – 50,000 Hours.
  • IP Rating – IP68.
  • Finish – Black Powder Coating.
  • Body – 6063 CNC Machined Aluminum.
  • Hardware – Stainless Steel.
  • Durability - High Vibration & Impact Resistance.
  • Light Bar Size – 10” (250mm x 70mm x 145mm).
  • Lens - 1000 Meters Light Reach, 10° Magnifying.
  • Working Temperature - <65°C
  • Bracket Size – 1.5” – 2.5” Mounting (Stainless Steel) 30° Angle.
  • Product Weight – 1.80kg Including Fixing Brackets.
  • Multi Fitment – Various Applications.
  • Colour Temperature – 6000K Pure Xenon Daylight White.
  • Lumens Output - 3640 Lumens
  • Light Pattern – Flood LED, Producing a Wide Output Range.
  • Approvals - CE & RoHs Complaint
Pictures of the actual kit, comes with brackets and fixing bolts, pre wired using high quality cabling along with purpose built secure packaging. These are so good they can be used whilst submerged fully in water/ice/snow!
We have taken pictures of a yard at night without any other lighting to show before & after shots whilst connected to a 12V car battery, the furthest tree in this particular yard is 50 meters away and the light output is just phenomenal!
Worldwide shipping along with a full money back guarantee will be offered on this product, that's how confident we are! ;-)
As always, any questions just let us know!
      10-11-2014, 02:15 PM   #405
AdzC
Drives: E92 335d
PM Sent
Space Grey E92 335d
1998 Yamaha R1
      10-12-2014, 06:43 AM   #406
HorizonLEDs
17
Great Cheers!
      10-14-2014, 04:19 AM   #407
tom619
26
Hi,
Thanks
Can't seem to find the information you refer to Zain?
I must say it is doing my head in just a wee bit as I can't understand why one side would be brighter than the other
      10-14-2014, 04:25 AM   #408
tom619
26
Also, I'm quite interested in the H7 CREE Headlight kit can you tell me what else is required for these to work or is it just plug and play?
      10-14-2014, 05:16 AM   #409
tom619
26
Originally Posted by cupraraj View Post
Hello guys, i have fitted these in today, my passenger headlight is abit strange compared to my right, the passenGer outside halo is not as bright as the other rings because the inside light has a hole that comes out more than the outside, anybody know what i mean and can anyone help or give advice how i get it to work properly?
I believe I'm seeing the same sort of thing. My passenger side outer halo is not as bright as my driver side outer halo.
      10-14-2014, 05:36 AM   #410
dy63
160
Drives: F30
i never fixed them as i couldnt be arsed to remove everything again as it takes ages. my passenger outter is dim and abit green, if this is the bulb im not sure. however i did notice the passenger bulb does not sit tight in like the right one did. i believe this was because of the passenger bracket for the bulbs position had a peice coming out where as the right didnt
      10-14-2014, 06:55 PM   #411
HorizonLEDs
17
Hi Tom,
See below, this should explain it a lot better than I can!
Cheers,
Zain
      10-14-2014, 06:56 PM   #412
HorizonLEDs
17
These are simply plug and play. Pictures here of them fitted to a customers car: -
https://www.facebook.com/media/set/?...7917262&type=3
Cheers,
Zain
      10-14-2014, 06:58 PM   #413
HorizonLEDs
17
Hey Raj,
If you get a chance to fit them could you take some pictures and email them to me so I can have a look and hopefully make some recommendations?
Thanks,
Zain
      10-14-2014, 06:58 PM   #414
HorizonLEDs
17
Originally Posted by tonyteam View Post
http://www.horizonleds.co.uk/oem-led...s-gold-edition
in a 2007 Pre-lci E90 is safety? OEM leds wattage are only 10watt. is safety for the LM module?
Hi,
Yes they are completely safe, remember LEDs are low power consumption bulbs. Also your cars wiring is designed to handle up to 55W
Thanks
      10-20-2014, 06:20 PM   #415
HorizonLEDs
17
OEM Number Plate LEDs COMING SOON!
Watch this space guys!
      10-26-2014, 12:51 PM   #416
ArsE92
ArsE92's Avatar
23
Drives: E92 335i SE
Damn. You really do need small hands to fit these. I just had ten minutes to try and had to give up as the darkness came!
It'll be next weekend before I get another chance now.
      10-30-2014, 03:55 PM   #417
tobeski
9
Drives: BMW E93 330D M-Sport
So this may be a daft question...
Just received my H8 40w gold LEDs and they come with 4 ballasts.
Do I need to use all 4?
      11-01-2014, 03:29 AM   #418
tobeski
9
Found a previous post that says that 2 ballasts are extra with the 40w if you get radio interference but these are not normally needed. Assume this is the same for the gold edition too.
Closed Thread
angel eyes, cree led, hid, led, xenon
