BMW M3 Forum (E90 E92)
EXXEL Distributions
      07-13-2011, 07:41 AM   #89
daniel-EU
Drives: M3 E91 2010
Great work !
The local dealer told me that this steering wheel cannot be fitter to M3
so I would like to install it according to your instructions
Please send me proper Part Number from BWM which I should order for my car
M3, 2010, DCT, EU version
Thank you
      07-13-2011, 10:45 AM   #90
daniel-EU
Drives: M3 E91 2010
Hi,
could you please confirm that for my M3 (2010, DCT, EU version) is suitable
performance steering wheel 32 30 2 165 396 ?
I am gonna buy and install one, and local dealer told me that it would not work for DCT
thank you very much
Dan
      07-14-2011, 11:46 AM   #91
Fsarc
Fsarc's Avatar
Drives: 2011.5 E92 M3 LMB
Great DIY Can anyone confirm the torque specs for 16mm steering wheel bolt? I've read 75 ft/lbs in this thread and 46 ft/lbs in a thread on E90post. Thanks.
      08-14-2011, 11:26 AM   #92
335PERU
Drives: 335I 2008
Problem installing my PW with the Paddle Shifters
Originally Posted by doba_s View Post
He is correct ... AT wheel = DCT wheel
Hi, I bought in USA my PW and when i just tried to install it in Lima Peru i realized that the dealer in Miami, did not give me the Coil Spring Cartridge, but that problem is being solved just by asking one to be shipped here to Peru, I think the code for my car is 61 31 9 122 381.
But the other real problem is that my automatic 335 VIN WBAWB73578P043691 comes with the Paddle Shifters in the original wheel and my Performance Wheel doesnt come with the holes for them. I would try to make the holles myself because i want to have both the PW and the Shifters. I have studied both Of the wheels and it seems that i only need two holes to make, do you think it would work?
      09-10-2011, 05:34 PM   #93
lawsat
16
Drives: BMW E92 M3
PM'd you about an installation inquiry. Thanks!
      10-11-2011, 10:13 PM   #94
Thumperx
Drives: 335I coupe
Hey Law,
I'm local and I've installed my Performance steering wheel. If Alek doesn't respond, you can PM me. I'll be glad to help out.
Anthony
Name: Blanca | 07 E92 | AW-Blk | ZSP | Alcon BBK | M3 Bits | VM RR Links | Koni | UUC Sways | V5 | Dinan CAI | ETS IC | Fge DV | ER CP | Cyba | Raden. Exh | Mod Step | Trunk Drawer | Perf LED Wheel | Illum Dr Sills | IS Shifter | Parrot | Philps D1S | 6000k fog | MTECH RR | CSL Trunk | Aero | Roof Spoiler | PSS on BBS RS-GT 19s
      10-12-2011, 01:47 AM   #95
lawsat
16
Drives: BMW E92 M3
Originally Posted by Thumperx View Post
Hey Law,
Anthony
Finished the installation by myself, than you for your offer though!
      10-12-2011, 10:25 AM   #96
THE TECH
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
Anyone know if you can get the installation kit separate from the steering wheel? If so, does anyone have part numbers?
      11-05-2011, 02:05 PM   #97
SEI
Indonesia
47
Drives: M3
just a heads up my 2011 sub connector colors are diff but pins still same
Old Blue Sub connector with Black inside
My 2011 M3 Blue sub connector with green and blue inside
Hope this helps!
now: 2008 335i (E92), 2011 M3 (E92), X3 35i (F25),2012 E63 AMG (W212), 2013 Kawasaki Ninja 250, 2007 Yamaha R6
gone:2009 GTR, 2007 335i (E93) 2004 M3 (HPF stg 3), 2008 Civic Lx, 2007 Z4M Roadster, 2001 Gembala GT550, 2007 CLS 55, 2007 STI, 2004 M3
      11-06-2011, 02:52 AM   #98
Leonardo629
Taiwan
168
Drives: 2013 M3 Coupe
This DIY helped me out a lot, I just installed my M performance wheel (non-elec), and it only took about 20 min.
      11-26-2011, 01:57 PM   #99
DOOBEE
DOOBEE's Avatar
Drives: 2008 M3
Great DIY. Installed my V1 today without issue.
      11-26-2011, 11:43 PM   #100
Alekshop
Alekshop's Avatar
Drives: E30 M3 l E46 M3 l GT4 l 991 RS
it's possible but takes a long time as BMW dealer has to call each time to find out a part# for each particular piece of the kit.
      11-29-2011, 10:49 AM   #101
kmarei
kmarei's Avatar
Egypt
688
Drives: 2018 Audi RS5 coupe
2018 Audi RS5  [0.00]
i just changed my steering wheel to the newer PSW non-electric one
i followed this DIY, which was great, but this part was not shown well in the pictures, and it was the hardest part
so i took some pics
what you are trying to do is to press these 2 metal bars in, to release the airbag.
one on each side
right side
left side
front showing where you need to insert the screw driver (shown with 2 screwdrivers just to highlight, you can do one at a time)
and this is what the hole looks like from the back
to me it's always easier to do something if i can visualize it, so i hope this helps you guys
      12-14-2011, 02:14 AM   #102
werly
Taiwan
53
Drives: 2011 MR E92 M3
Thanks to OP and kmarei's images above I also installed the PSW non-elec V2 just moments ago.
I agree with former installers that airbag remove is the hardest of all so I want to also contribute some pictures to make future PSW DIY easier
The insertion point is on the black rubber part at the back of the steering wheel, I circled it with red
They are really tricky, I don't know if anyone can visualize the insert slit with bare eyes...I can't. When you don't put it in, it is not there, but your screwdriver can certainly go in without any extra force. Like some members said, use your finger tip to feel the slit and insertion point. Using your new PSW to practice attacking the metal clip greatly benefits also, just like Leonardo629 suggests
Other than that, non-elec PSW is not very hard to install at all, you got to skip all the harness/wires work. But try not to close the truck after disconnecting the battery, otherwise you would ended up like me crawling into the back seat and ripped the arm rest off and managed to pull the emergency trunk release...
Cheers
      12-28-2011, 05:54 PM   #103
rye m3
Switzerland
33
Drives: 2011.75 E92 M3
Cheers
Didn't want to repost all the pics, but really wanted to thank you for your post. Glad I read the sticky all the way to this last one. I thought they changed the wheel for '11 and there weren't holes anymore or the airbag release had changed! This was a very helpful illustration. Thanks much! Went on in 20 minutes. I love the quality of the OEM fit and stitching - this is an incredible buy in a performance Alcantara steering wheel. Not so crazy about the blue, but hope I'll get used to it.
E92 M3 MR on Red/Black ZCP Sound
Carbon
2007 997S - sold
2003 E46 M3 Steel Grey on Red- sold
1997 E36 M3 Arctic Silver on Black- sold
      12-28-2011, 06:38 PM   #104
werly
Taiwan
53
You got it! I just thought to return some favors to the forum
I love my PSW as well, the blue ring is a bonus, if only the electronic one has it I will absolutely jump on that, but doing that DIY is another story...haha
      01-07-2012, 07:01 PM   #105
TTG
TTG's Avatar
Drives: M340
Thank You Kmarei Big time....
As you indicated the most difficult part of this mod is to remove the airbag which OP doesn't get into too much. Thank you for posting your update.
It took me 20 mins total for the install.....
People with silver int should really consider this mod as the blue on the steering wheel goes very well with the interior color!
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired
2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired
2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired
      04-05-2012, 10:35 PM   #106
utah_ee
Drives: '08 M3 Sedan 6M
Awesome DIY!!
      04-16-2012, 09:20 PM   #107
rhouck
rhouck's Avatar
Drives: 2008 E92 M3
Thanks to everyone who contributed to this DIY. I used it on Saturday and everything went smoothly!
      04-25-2012, 01:13 AM   #108
thorny
thorny's Avatar
Drives: M3
I just installed my new Alcantra steering wheel (non-electric). I forgot to disconnect the battery and now I have a Pass. Restraint Error. Any ideas on how to get rid of it? Thank you.
      04-27-2012, 11:42 AM   #109
Yodaime
Just a normal member.
Yodaime's Avatar
Vietnam
171
Drives: Banh Xeo
Sorry to jack thread but how hard is it to install this wheel? Do you have to mess with any electrical stuff like the bmw performance electric wheel? I got the same wheel as you.
Originally Posted by nrrm1127 View Post
My life is complete. Yodaime has commented on a post with my car in it.
      05-02-2012, 01:11 AM   #110
thorny
thorny's Avatar
Drives: M3
I solved my problem. Got Bavarian Technic cable and erased the code. If you face the same problem and decide to go the same route, be sure to turn on hazard flashers, otherwise cable wont communicate!
m3post
