11-06-2019, 01:12 PM | #23 | |
Rep 41
11-10-2019, 07:09 PM | #24 | |
Sergeant
23
Rep 206
2011, Interlagos 6SP, E92 M3.[IMG][/IMG]
11-11-2022, 12:53 PM | #25 |
Rep 460
Sorry for reviving an old thread but I am curious.
Why do our cars have an Idle Control Valve? With older cars that had mechanical throttles, I understand that this was necessary to have computer control over engine idle speeds, but on modern cars with throttle by wire, why is this necessary? Clearly the ECU has complete control over the throttle butterfly valves, otherwise we would not be able to use Cruise Control. |
02-28-2023, 02:51 PM | #26 | |
Rep 20
04-08-2023, 10:15 PM | #27 |
129
Rep 165
I don't want to start a new thread on this topic.
Can someone please confirm: My engine went into limp home a few weeks back on cold start, and it happened again the other day. Same codes as the first time that lead to Idle Control Valve. I bought a new fuel breather valve, but decided against buying an idle control valve figuring I can clean it out. Back in the day when I owned an e36 m3 some 12-15 years ago, this was also a common problem however the solution was cleaning it out with carb cleaner or soaking it in sea foam - I forgot which product it was exactly. But you could clean it out, which would typically resolve the issue. For the e92 m3, I searched the codes I was getting and from what I found - everyone that has had this issue has replaced the entire ICV unit. Why not clean it? Does that not work or am I missing something? Obviously trying to avoid spending $800 if I don't have to. Last edited by GinTonic; 04-08-2023 at 10:24 PM.. |
AndyW673.50 |
04-09-2023, 05:11 PM | #28 | |
Field Marshal
6730
Rep 1,829
Drives: '08 E92 M3
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
07-24-2023, 01:58 PM | #31 |
Rep 2
Codes and Attempt to Replace Fuel Breather and ICV
I recently experienced P152D Manufacturer Control from my OBD II scanner and with ProTool it is 2B0D Idle Actuator Monitoring, Bank 1. My throttle actuators were replaced less than 1,500 miles ago.
In process of replacing the FBV (Fuel Breather Valve) and the ICV (Idle Control Valve). FBV was easy to remove, but the ICV I can see is a bit more challenging. More to come on the resutls and if it has fixed my idling problem between 2K and 2.5K RPM's that is consistently happening at startup. 2008 BMW M3 Active Autowerke SC Manual. 106K and the video of the cold start issue can be found on YT when you search 2008 BMW M3 S65 Active Autowerke Idling Issue before fix Last edited by roller1150; 07-24-2023 at 02:21 PM.. |
DrFerry6730.00 |
11-11-2023, 04:27 PM | #33 |
Field Marshal
6730
Rep 1,829
Drives: '08 E92 M3
Did cleaning it work?
///M Power-Belgium63919.50 |
02-11-2024, 03:30 PM | #35 |
129
Rep 165
So, coming back to this.
The symptoms came back about a month or two ago with the colder weather. It was really noticeable when putting the car into gear right after starting the engine. Since I had the plenum off the other day, I changed out the fuel breather valve. I ordered one a year ago and never got around to changing it out. All symptoms of fluctuating idle are now gone. |
DrFerry6730.00 |
