09-22-2014, 10:37 AM | #67 |
Rep 906
Yep. On certain F30 builds, there are two T25 bolts right where the warning triangle should be. However, on 2015s I've seen them replaced with plastic rivets.
You also need to detach the glow-in-the-dark emergency trunk release from the steel cable in order to completely remove the trunk-lid liner.
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
09-22-2014, 01:42 PM | #68 | |
Rep 808
I might just remove the emergency release, when I lock people in my trunk I don't want them to be able to get out |
09-26-2014, 08:01 PM | #70 |
32
Rep 79
09-27-2014, 12:57 PM | #73 |
Rep 808
10-02-2014, 11:16 PM | #74 |
Rep 906
My red LEDs just shipped yesterday!
11-07-2014, 05:22 PM | #75 |
10
Rep 88
01-10-2015, 06:32 PM | #76 |
Rep 9
I've been looking for the best reverse LED upgrade and had almost purchased some Weisslichts this afternoon when I thought about the flickering issue. Does anyone know if the system checks the reverse lamps with the same regularity as the turn signals? I don't mind the light show at startup but I'd prefer not to flash drivers behind me at night, and I'm totally unfamiliar with coding.
Thanks! |
01-10-2015, 07:20 PM | #77 | |
Rep 1,480
Drives: 2020 M340Xi (G20)
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
01-22-2015, 02:50 PM | #78 | |
Rep 1
ijdmtoy LEDs errors
[Color:Xenon White] I purchased these and they do in fact throw up errors. Working with them now to try and return/replace. It's too bad because they actually look great especially light up at night. The color is just a hue off factory. Also purchased these before which have the wrong base even though part # is the same... py24w. http://www.khoalty.com/bmw-e90-e92-l...-led-bulb.html You can't close the cover cap with these bulbs on a 15' 435gc but Khoalty thinks they should work and won't give a refund. Last edited by maikel; 01-22-2015 at 03:08 PM.. |
03-14-2015, 01:10 PM | #80 | |
Rep 1,480
Sure; please try these to fill in for the XXX:
For the single _X_, it is either L for LEFT or R for RIGHT So to code the right rear turn signal, go to REM:
That should do it
Al
03-14-2015, 01:29 PM | #81 |
Rep 3,089
Xin chao anhquan420
To be a bit more specific here is what you need to code: Rear Turn Signal REM / 3061 / FRA_H_L_KALTUEBERWACHUNG from aktiv to nicht_aktiv REM / 3061 / FRA_H_L_WARMUERBERWACHUNG from aktiv to nicht_aktiv REM / 3061 / FRA_H_L_IS_LED from nicht_aktiv to aktiv REM / 3061 / FRA_H_R_KALTUEBERWACHUNG from aktiv to nicht_aktiv REM / 3061 / FRA_H_R_WARMUERBERWACHUNG from aktiv to nicht_aktiv REM / 3061 / FRA_H_R_IS_LED from nicht_aktiv to aktiv Front Turn Signal FEM_BODY / 3061 / FRA_V_L_KALTUEBERWACHUNG from aktiv to nicht_ aktiv FEM_BODY / 3061 / FRA_V_L_WARMUERBERWACHUNG from aktiv to nicht_aktiv FEM_BODY / 3061 / FRA_V_L_IS_LED from nicht_aktiv to aktiv FEM_BODY / 3061 / FRA_V_R_KALTUEBERWACHUNG from aktiv to nicht_ aktiv FEM_BODY / 3061 / FRA_V_R_WARMUERBERWACHUNG from aktiv to nicht_aktiv FEM_BODY / 3061 / FRA_V_R_IS_LED from nicht_aktiv to aktiv Reverse REM / 3061 / RFS_L_KALTUEBERWACHUNG from aktiv to nicht_aktiv REM / 3061 / RFS_L_WARMUERBERWACHUNG from aktiv to nicht_aktiv REM / 3061 / RFS_L_IS_LED from nicht_aktiv to aktiv REM / 3061 / RFS_R_KALTUEBERWACHUNG from aktiv to nicht_aktiv REM / 3061 / RFS_R_WARMUERBERWACHUNG from aktiv to nicht_aktiv REM / 3061 / RFS_R_IS_LED from nicht_aktiv to aktiv
03-26-2015, 10:35 AM | #82 | |
Rep 1,480
Glad to have helped. I put LVL302VWY in my F30 reverse lights; suggest you ask Bimmian if that will work on your F32 HOPE THAT HELPS
Al
03-26-2015, 12:11 PM | #83 | |
Rep 3,089
http://www.ebay.com/itm/371271291551...%3AMEBIDX%3AIT
05-31-2018, 07:49 PM | #84 |
Rep 3
Coding F30 Flickering
Hey guys...newb here.
I just picked up a 2014 335xi and swapped all the incandescents with WeissLichts, front/rear turns, brake lights, reverse lights. They look pretty sweet so far, but I am getting the flickering mentioned previously. The code was provided, and I have a usb to OBD cable, but what software is needed to code my ride from a Mac or PC? - Learning Newb |
05-31-2018, 09:17 PM | #85 |
Rep 16,139
02-03-2019, 03:39 PM | #86 |
Rep 15
Hey, guys. I've been looking for the Weisslicht WTS302RAY Amber Turn Signals for F30, but it appears they're out of stock on every single website.
Moreover I live in Europe and can't find a reseller here. Is there an alternative which is sold in Europe? |
02-03-2019, 04:39 PM | #87 |
Rep 16,139
Look on your local Amazon.com. Search for Philips, Osram and iJDMTOY brand. There's nothing special about Weisslicht. They appear to be seriously over-priced re-labled Asian bulbs.
bulb, led, spektrum, weisslicht |
