04-04-2019, 11:03 AM | #45 | ||
Rep 3,540
I need to optimize the bump stops on my current setup with different dampers. I'll find a weekend soon to measure how much travel I have before engagement (I want at least 3/4"). Quote:
I haven't found a good database for OE (or any other mfg) spring specs unfortunately. Since ACS rebrands Eibach springs though, you can look at ACS' TUV documentation and the Eibach one side by side and easily figure out which Eibach springs ACS is using where and therefore get their specs. |
04-05-2019, 05:34 PM | #46 |
16
Rep 132
Dustin335i - why not tried Dinan?
Instead of cutting down the bump stops with Eibach why did you not go to Dinan (3/4 inch drop) with their special bump stops (with springs on top) which seems to me best of all worlds and Dinan engineers carefully for BMW cars.
I have a 2014 335Xi with adaptive suspension (hence close to your 540xi) and am thinking about the Dinan route. Might be few hundred$ more but small general difference after labor accounted for. Thanks. |
04-06-2019, 03:21 PM | #48 | |
Dustin335i
50
Rep 80
Drives: Mineral Grey M235i M/T
I'm thinking this through; I have to ask- does your car have adaptive suspension (electronic dampening control struts)?
04-06-2019, 03:44 PM | #49 | |
Dustin335i
50
Rep 80
I'm experiencing a weird issue an Independent bmw shop is trying to diagnose....
04-06-2019, 04:23 PM | #50 | ||
163
Rep 216
04-06-2019, 05:32 PM | #51 |
Dustin335i
50
Rep 80
Hey man, thanks for replying.
I took my 340i, Adaptive Suspension, M sport, X-drive into a tuning shop to have the Eibach Sport installed on Wednesday. When I first saw the car, it looked great. It looked clean. I was impressed. I pulled out of the shop, and noticed my brake pedal was extremely soft, and went to the floor, before I stopped. I was very surprised, and almost drove out into traffic before the car stopped. It's the sensation you get after you do a brake job, and the car doesn't want to stop, until you pump the brakes a few times. I thought little of it, and drove home. The next day, the issue was still there. I drove carefully all day. The car's suspension seemed GREAT, but the braking was obviously wrong. I called the shop and reported the issue, and they told me they didn't touch the hydraulic braking system at all, and there's no way this could be their fault. I just bought the car 4 weeks ago from a BMW dealer as a CPO car, and it's been flawless. I've put 1500 miles on it, and the braking as been excellent. This shop who inspected my car and lowered the suspension couldn't promise they wouldn't invoice me for looking at the brakes, as they claim they didn't touch the system, so it must be something else. Basically; they said it wasn't their fault. This frustrated me a lot. I bled the brakes myself in my garage yesterday, using a single person, cheap bleeder. I got some air out of the system, but it still wasn't right. I took it to an independent BMW specialist this morning (saturday). He hooked up a pressure canister to the master cylinder reservoir and forced fluid into the system, and carefully bled all 6 bleed points. (there are two bleed nipples on each of the two front brake calipers, 1 on each of the rear). The system got better after his work.... but it's still not right. My brake pedal travels too far down before braking the car properly. It's safe now, but it's not right. The system is 80% right maybe. The bimmer specialist wants me to come back Monday; saying he will hook up a diagnostic took, and run a special bleeding procedure that takes more time... He's convinced he can get the system perfect, and apologized to me twice. He treated me VERY well. I'm sitting here scratching my head, wondering what the first shop (who supposedly only lowered my car) could have done to my brake system. I think it's possible a rookie technician accidentally undid a brake line and it bled out. He was afraid to tell the shop owner, so he just topped off the system with more fluid, without bleeding it. How else could air get into the system, causing this issue?? Do you have any thoughts??
04-06-2019, 11:16 PM | #52 |
Rep 3,540
Brakes have nothing to do with EDC or lowering springs. None of the calipers or lines need to be removed to do springs.
The indie mechanic will probably run the ISTA bleeding procedure where the various valves pulse to loosen any bubbles and force them out. It's not very long of a procedure. |
04-08-2019, 09:19 AM | #53 | |
Modder of everything I own
147
Rep 491
I used the front sway bar instructions on the Dinan website.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
04-08-2019, 10:09 AM | #54 |
16
Rep 132
For Dustin 2017 335Xi adaptive suspension
Hey Dustin - we have similar cars. Mine is 2014.
Why did you pick the Eibachs? Are they progressive or linear springs? How do you find the ride and the handling now? I believe these have 0.8 in lower in Front and 0.6 in in Rear. Correct? I find the Dinan spring and bump stop correction logically appealing, but Dinan does not have progressive springs. Is the spring/shock matchup ok with your adaptive suspension and Eibachs? To my surprise, some RWD owners berate the Dinan spring match to their stock shocks and some have even thrown the adaptive shocks away out of frustration with ANY springs. I always thought Dinan took an excellent system approach. (My Dinan stage 1 performance kit is flawless, for example.) Thanks. |
04-08-2019, 01:15 PM | #55 | ||
Rep 5,400
04-08-2019, 01:43 PM | #56 | |
Dustin335i
50
Rep 80
04-08-2019, 01:49 PM | #57 | |
Dustin335i
50
Rep 80
04-08-2019, 03:32 PM | #59 |
Dustin335i
50
Rep 80
I totally agree this is how they should have left the factory! Your ride looks SICK.
04-08-2019, 05:20 PM | #60 | ||||
Rep 5,400
I just received a Wiechers strut tower bar today. It's beautifully made. Don't think the polished aluminum look matches well in the engine bay so I'm getting it powder coated in a gloss black. That should complete my suspension. Put Michelin pilot Sport 4S 245/40-18 summer tires on this afternoon. Amazed on the short drive home. Cornering was sick! Anxious to drive it more tomorrow |
04-11-2019, 11:25 PM | #61 |
16
Rep 132
Dustin - why did you go with RWD Eibach's on your Xi?
Also, what is the Eibach model # you used? When you go from Comfort to Sport do you get a better spring-shock compatibility in a damping sense or only tighter handling than with the stock adaptive setup? I find the stock setup not only has lean but the springs and shocks are not matched as well as they should be. A progressive spring might fix this nicely.
04-11-2019, 11:35 PM | #62 | |
Rep 5,400
04-16-2019, 04:40 AM | #63 |
Rep 468
I have the same question.
The online catalogue list E10-20-031-05-22 part for 340ix/330dx/335dx. The Eibach PDF list E10-20-031-06-22 part for the same 340ix/330dx/335dx. The difference in those springs are the spring height and the payload. I'm unsure now which is the correct spring for my 16' 335xd You can see the 05-22 is 35mm/25mm drop and the 06-22 is 20mm/15mm drop |
04-16-2019, 08:38 AM | #64 | |
Rep 5,400
Having said that, some of the forum guys have gone ahead and installed the 05 part# on their xDrives because they like look of the drop. If you do that you have to be concerned about the dampers and bump stops, that they still have enough travel since you just took away about 1.5" of travel with the lower springs. For example my Koni Special Active xDrive dampers aren't designed for that much drop. Koni told me that the milder drop of the Eibach 06 spring kit is fine. Been driving on them fine for 9 months. I can't recall if you have the adaptive suspension instead of standard dampers like mine. I've read several guys who installed the 06 Eibachs without issues. I don't know the caveats of installing the lower 05 Eibachs with adaptive dampers. Suggest you call Eibach and point out the documentation mistake and discuss your particular options. Hope this helps! |
04-16-2019, 10:43 AM | #65 | |
Rep 3,540
The mistake is they forgot to list the -06-22 kit under 335dx on the online catalog. The 435dx has both kits listed under it. |
04-16-2019, 12:09 PM | #66 | |
Rep 468
The combo i'm going with is Bilsteins B6 with either Eibachs but The Bilstein recommends max drop on the B6's is 30mm, which is why I think the 06 might be more suitable. Has anyone got a photo of the Eibachs 06 fitted? The photo in the previous post is with the 05's and they look totally sick, altough very similar to ACS springs. Judging by what people say about ACS springs being a bit lower then Eibachs, more I think is they might be based on the 05 eibach model. |
