2010 2011 BMW 5 Series Forum F10 Anyone up 100k Miles on their F10? |
09-15-2020, 02:05 AM | #46 |
Rep 1,357
OnlyGerman363.50 |
09-20-2020, 01:15 PM | #49 | |
Rep 13
10-05-2020, 05:25 PM | #50 |
Rep 4
I'm at 102k this month. It's a 2014 550i xDrive. Apart from regular oil changes and maintenance, haven't had any issues. Planning to change the transmission oil soon though.
10-18-2020, 12:40 AM | #53 |
10
Rep 35
96k today... OFHG is only repair so far...my Turner motorsports thrust bushings will be going in soon...
https://www.turnermotorsport.com/p-559168-turner-f0xf1x-5-6-series-awd-thrust-arm-monoballs/ |
11-17-2021, 09:16 PM | #54 |
114
Rep 110
Drives: 440i GC, 650i GC, i7 xDrive60
Hey guys, I’m at 198,000 on my 2011 528i 6cyl. I’ve been very consistent with the services since I bought it at 40,000 miles and have no major issues. The biggest items have been the starter motor at 153k miles and recently the valve cover at 189k miles and soon the lower control arm bushings.. I’ve been very consistent with Oil, Fuel Cleaner, Ignition Coils and Spark Plugs so the car feels very smooth and responsive👍🏽😎
OnlyGerman363.50 StradaRedlands4994.00 |
04-21-2022, 08:21 PM | #55 |
53
Rep 231
Finally joined the 100k miles club!
2011 535iX N55 own since 2015. Still running strong! Changed: Spark plug @ 86k Tranny fluid @ 86k Battery @89k (since 30k) Bleed brake fluid @ 80k Regular 10k oil change Brake pad, brake rotors, Tires Fixed: Replaced Water Pump @87k Door vapor seal leaking @80k Head Light condensation @85k Trunk door lift support @92k Installed: Backup camera, backup sensors. Apple carplay
2011 535i xDrive Black/Black, Michelin PS AS 4
2014 435i RWD Convertible Service Manual: www.newtis.info Part: http://www.realoem.com |
04-22-2022, 07:55 AM | #56 | |
79
Rep 265
04-22-2022, 12:15 PM | #57 |
Rep 6
n63 with 148,000
My n63 550i has 148k miles, been maintained by my father and runs and drives like a dream, have had no major problems either
StradaRedlands4994.00 SummerallGuard0483.50 |
04-22-2022, 07:01 PM | #58 |
Rep 3,049
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
I'm new to the F10 world, but my '11 model with the N52 I6 has been having problem after problem. It has 112k miles on it, so really not a ton. Have had the oil sensor go out, both DISA valves, PCV valve/full valve cover, and valvetronic eccentric shaft sensor (luckily done at same time of PCV). I have two E9x with 180 and 220k miles on them, and hardly any problems other than the typical oil leaks. Got the '11 specifically for the I6 in it, but really questioning how well it was maintained (purchased from dealer, no records). Hopefully this will shake out the bugs and let me get it up to the 200k mile range I keep cars till!
04-22-2022, 08:25 PM | #59 |
Rep 1,357
I am now at 305K
StradaRedlands4994.00 KillFox9183.00 |
04-22-2022, 09:04 PM | #60 |
53
Rep 231
04-23-2022, 12:12 PM | #61 |
17
Rep 21
Hit 251,000 miles this week! 2014 535d with N57 engine.
04-23-2022, 07:37 PM | #63 |
84
Rep 114
2016 550i w/ 17k miles. 2nd owner and bought earlier this year. Got super lucky and found a cream puff. Original owner didn't drive it (much) and was in his mid 70s. He took good care of it and was not molested. Not sure how long i'll own it but i, too, also anticipate repairs, other than routine maintenance. I don't have a warranty but, instead, stash $$$ away each month in the event something comes up in the future. These cars are amazing and I love being behind the wheel of such an amazing machine. 550is are such sleepers!
2016 BMW 550i M Sport - Mineral Gray Metallic
2015 BMW X5 base - Jet Black 2011 BMW 335i - Alpine White |
StradaRedlands4994.00 Buddys550169.50 |
04-26-2022, 11:42 AM | #64 |
30
Rep 117
Drives: 2013 F30, 06 325i, 07 328i
I have an F10 2011 528i with 115k on the odometer. I have the N52. I bought it for really cheap with a blown timing chain with 101k miles on it. I planned on having to do the timing chain repair but it ended up being covered by warranty. It's not a sulev vehicle so I assumed the warranty was expired but there was some extended warranty on some of the components so the dealer fixed everything for free. I would recommend always calling the dealer even over 100k miles and make sure your repairs aren't covered by warranty before paying out of your own pocket. Besides that I've had to replace control arms and sassy bar bushings but that's about it.
04-29-2022, 01:35 AM | #66 |
Rep 3,049
