Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Dealers can't code my 07 335i
      06-09-2014, 07:24 PM   #1
Scrippy
Lord Scrip
Scrippy's Avatar
Drives: 2011 M3 Coupe
  [0.00]
2007 BMW 335i  [0.00]
what's up y'all! So I am the 2nd owner of my 07 335i. Love this car but the guy before me screwed up the Logic 7 system. I purchased a used Rad2 BMW Professional stereo and a used logic 7 amp. Cleaned up wiring and MOST bus and everything works great. All 13 speakers, Aux In, CD player, radio, Bluetooth, Voice commands etc.... However no dealership has been able to code my vehicle for me. I'm way past warranty with 130,058 miles. I've read just about every manual for the media entertainment system on the E92 and I cannot find a reason why. My theory is that the radio is VIN specific and I need to correct this in my cars module list. That is just my guess. Please don't reply if your going to tell me this has been discussed here before and I'm a toolbox for not finding it in the 7 trillion posts. Any help would be awesome.
      06-09-2014, 07:45 PM   #2
AgentAvalos
VIP
AgentAvalos's Avatar
Drives: AW E92 335is
2011 BMW 335is  [0.00]
bmcoding.com
you'll thank me later.
      06-21-2014, 04:59 PM   #3
makkan00
makkan00's Avatar
886
Drives: F83 and F36
Dealers cannot code your car as the radio or amp may be incompatible with your car as per their computer.
For example stereo from 2011 car should not be in 2008 car and dealer's equipment will check the compatible part numbers before.
I am not sure what you want to code as ncs may help.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play
      06-22-2014, 12:15 AM   #4
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
What are you trying to code if everything is working?
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      06-23-2014, 07:52 PM   #5
Scrippy
Lord Scrip
Scrippy's Avatar
  [0.00]
I want to update the chime to the gong. I would like to apply the HPFP update that prevented my registration from being done.
      06-23-2014, 07:53 PM   #6
Scrippy
Lord Scrip
Scrippy's Avatar
  [0.00]
HPFP update that prevented my registration from being done and change the interior chime to the gong.
      09-19-2014, 02:20 PM   #7
laurentProd
20
Drives: E93
UP !!
Does that mean that you can not code a second hand HU?
I was about to swap from business radio to professional radio for a friend and to code it to hifi. Are you sure it's not possible? Sound very strange...
      09-21-2014, 06:27 AM   #8
Teq
41
Drives: E90
Originally Posted by laurentProd View Post
UP !!
prof. radio is on the MOST. You must use that to program it.
      09-21-2014, 06:29 AM   #9
Teq
41
Drives: E90
If you're still stuck use INPA to print uid and post here. You'll see all your modules with vin.
      09-21-2014, 12:02 PM   #10
Scrippy
Lord Scrip
Scrippy's Avatar
  [0.00]
I just need to modify VO huh?
      09-21-2014, 12:15 PM   #11
Scrippy
Lord Scrip
Scrippy's Avatar
  [0.00]
      09-21-2014, 02:13 PM   #12
Teq
41
Drives: E90
Send me the last 7 numbers of your vin and I'll check.
      09-21-2014, 02:23 PM   #13
Scrippy
Lord Scrip
Scrippy's Avatar
  [0.00]
PV82826
      09-21-2014, 02:41 PM   #14
Teq
41
Drives: E90
Check on the back of the unit if it's using MOST. If yes then code using MOST if not code using Icom.
You can do it with winkfp like I said.
First show the screen of INPA where are the modules are displayed inc. their vin.
      09-21-2014, 03:05 PM   #15
Scrippy
Lord Scrip
Scrippy's Avatar
  [0.00]
It does have MOST. The stereo has a 1 month newer production date then my car.
      09-22-2014, 05:13 AM   #16
Teq
41
Drives: E90
Then code throught MOST using ista-p or winkfp and you're done.
I strongly suggest to do it with an Icom.
      09-22-2014, 01:21 PM   #17
laurentProd
20
Drives: E93
Well I'm going from business radio (not MOST) to pro radio (not MOST).
Using NCSExpert radio is not reachable via MOST obviously but under "normal radio".
Does that mean I will not be able to code it to HIFI?
      09-22-2014, 01:48 PM   #18
Scrippy
Lord Scrip
Scrippy's Avatar
  [0.00]
As far as I know, MOST is required for HiFi. My car has HiFi and the amp is in the trunk. The speakers wire to the amp and not the deck. The deck streams audio over MOST to the amp.
      09-25-2014, 02:15 PM   #19
Teq
41
Drives: E90
Eu spec car?
      09-25-2014, 05:15 PM   #20
taibanl
taibanl's Avatar
281
Drives: BMW
You CAN code a non-MOST radio. NCS expert using the V.O,; dealer using the "Conversions" path in ISTA/P.
HiFi is an analog system, @SCrippy, you have TOPHiFi.
      09-26-2014, 12:54 AM   #21
Scrippy
Lord Scrip
Scrippy's Avatar
  [0.00]
Your right on both accounts, I just couldn't remove my post. I realized like 2 seconds after writing that. I'm waiting on a cable to update my VO through ISTA. My stereo is used and I need to match it to my FRM options to get rid of SOS error and mirror errors.
      09-26-2014, 02:47 PM   #22
Teq
41
Drives: E90
Using anything else iso an Icom icm Ista-p is dangerous.
If you don't have a psu Ista-p won't continue.
coding, programing, stereo, used stereo
