E91 Leonia
08-12-2021, 01:06 PM | #111 |
198
Rep 263
The number of maintenance items and modification items is starting to blur.
It feels like a great transition, something that i'm very happy about as I continue to put personal touches onto the car. One thing that I'm working on atm.
William Mackenzie
IG: Shambam_makes Twitter: B_Shambam |
08-13-2021, 04:30 PM | #112 |
Save the Manuals!
1227
Rep 1,239
Drives: E91 RWD 6MT, X3, Ducati S4R
Garage List 2011 E91 6MT RWD &q ... [0.00]
2005 Ducati S4R 996 [0.00] 2000 Ducati M750 [0.00] RIP - 2011 E91 328i ... [10.00] |
Ok, I'll bite...
Is this a new airbox?
2011 6MT RWD ClubSport Wagon | 3,185lbs | 1 of 149 ZSPs delivered in North America
Outside: BMW M-Aero, Euro region lighting, Seibon | Inside: M3 cockpit, Recaro SPG, Prototipo, AutoSolutions SSK, UCP | Stop: M3 ST-40R, PFC | Grip: Solid-mounted subframes, rear coilover conversion, M3 Nitron R3, Hyperco, SPL, AKG, ARC8 | Go: StageFP, CF snorkel, 3IM, MILVs, SuperSprint headers, Dundon Motorsports Inconel exhaust, VoltPhreaks | Cool: CSF | PCA #2018100384 | BMW CCA #505794 |
bshambam197.50 |
08-14-2021, 12:36 AM | #113 |
198
Rep 263
Really great idea! Perhaps something that has cold air ducting to the bumper hole below. Maybe that's something i'll look @ in the future. For now, I will let the future posts of the renderings tell the story.
Back to maintenance and repair! I wanted to replace this bracket but the price point from the dealership was 40 dollars cad. I decided just to glue it with epoxy and it works just as intended. No need to spend unnecessary money haha more $ for mods.
William Mackenzie
08-18-2021, 01:20 AM | #115 |
198
Rep 263
Oh boy.... I have some wiring in my future...
This is the canbus adaptor that is sold by 'carsystems . com . ua' and their vendor 'custom retrofit'. I will be doing a full write-up in this thread for the F10 to E91 Steering Wheel Conversion.
William Mackenzie
08-19-2021, 08:58 AM | #116 |
198
Rep 263
While the front clip of the car is dismantled, I thought it would make sense to upgrade my communication skills.
William Mackenzie
08-21-2021, 11:39 AM | #117 |
198
Rep 263
To continue on the Horn project, they are installed on the oem location. With that being said, some adjustments need to happen with the installation since the Hella horn is larger than the OEM one.
I also re-wired the horns with a new connector. I think it's a MQS style?
William Mackenzie
08-24-2021, 02:57 PM | #118 |
198
Rep 263
With the new horns installed, I tried to put the front clip back on but the radiator support bushing broke off....
Picked up a pair from an E39 on amazon and they fit like a charm. The previous one popped out of the radiator support, whereas these ones are now flush. I hope it does its job.
William Mackenzie
09-16-2021, 12:44 PM | #119 |
198
Rep 263
Update 2021-09-16, approximately 1-year & 1 month after the initial purchase. The car is on the road.
The following parts were replaced at 197,025 kilometers. Engine: Modified 2-Gauge Main Engine Ground Strap Modified Belt Guard @ Front Main Seal Modified ATI Fluid Damper Pulley Modified Coolant Neck @ Upper Radiator Hose Modified Fuel Pump 400 LPH Walboro Replacement Coolant Return Hose (Aftermarket) Bosch Starter Motor HELLA/oem water pump BMW Left & Right Front Engine Motor Mounts BMW Vanos Solenoids BMW Vanos Solenoid Filters BMW Belt Tensioner, Slave Pulley VDO Replacement Fuel Pick-up system Gaskets: Oil Filter Housing Gasket Valve Cover Gasket Valvetronic Motor Gasket ESS Sensor Gasket Coolant Neck to Short Block Gasket Front Engine Seal Rear Engine Seal Intake Manifold Gasket inclusive of PCV system hoses *all flex hoses* Exhaust Manifold Gaskets + Hardware Exhaust Manifold to Exhaust Runner Gasket Transmission: Clutch Flywheel Shifter Fork Stop Pin Shifter Fork & release bearing Shifter Linkage Pins x2 Fluids Change: Power Steering Fluid Flushed with new CH Brake System Flush with Motul Fluid Clutch System Flush with Motul Fluids Engine Oil Replacement with Motul 8100 + New Oil Filter Transfer Case Flush with Motul Gear 300 Front & Rear differential Flush with Motul Gear 300 Radiator Flush with BMW fluid @ 50/50 mix ratio Exterior Lighting: LED Angel Eye H8 Bulbs LED Fog Light Bulbs LED Front Headlight Bulbs LED Rear Signal Lights LED Rear Brake Lights Maintenance: Total interior detail Total Engine bay detail inclusive of front clip disassembly Complete under-tray detail inclusive of replacement hardware for rusty bolts/washers Ceramic Coat/Seal all supporting black Plastics Silicone Additive for all door seals Panoramic Sunroof Drainage Hose Flush Misc Changes: Interior: F10 Msport Steering Wheel + Canbus Module Eonon Headunit w 7" LCD Display Replacement of Drivers Side Handle with Glasses Holder Leather Covered 6-Speed shifter cover Red colored Start Button 35% Ceramic Window tint from Passenger Rear doors and beyond Replacement Rear Right Window Guide Replacement Rear Right Window *car was broken into 2020-12* Replacement Rear Tailgate Door Latch Cover Replacement Rear interior Screw Covers Exterior: New Hella Fog Light Housing Restored OEM Front Headlights Replacement Clear Front Bumper Reflectors Thule Flush-fit Roof Rack 25mm Rear Wheel Spacers Bosch Front & Rear Oem Windshield Wipers 2x Radiator Support Brackets
William Mackenzie
09-16-2021, 02:40 PM | #121 |
198
Rep 263
Here are some quick photos of the Headlight Restoration project in its completion.
The Before photo, with heavy salt pitting and 12-years of road debris/damage. And after an untold number of sanding discs and grits later, we have a UV sealed and ceramic coated headlight like this. It isn't as good as new, but it's almost there.
William Mackenzie
E92_William1306.00 |
09-16-2021, 02:47 PM | #122 |
198
Rep 263
Here are some progress photos of the work.
Repairs Clarity The process was as follows: Dry @ 200-320-400-600-800-1000-1200 Wet @ 1200-1500-2000-3000 2x Compounding Solutions 2x Polishing Solutions 1 coat of UV Seal 1 coat of Ceramic
William Mackenzie
09-22-2021, 01:29 PM | #124 |
198
Rep 263
Well.... I was on the road last weekend and this happened.....
The car was stuck in 3rd gear going uphill.....
William Mackenzie
IG: Shambam_makes Twitter: B_Shambam Last edited by bshambam; 09-22-2021 at 06:55 PM.. |
09-23-2021, 10:38 AM | #126 |
198
Rep 263
Yeah.... It was really disappointing as I was confident in my skill to put the car back together. What I didn't anticipate was the signs of old age and fatigue on some of the most basic of parts.
The snap ring had let go on the shifter linkage, disconnecting the transmission from the shift lever. It's a lot of work getting at a failure like this.... and maybe I'm more peeved @ myself that I didn't replace this 3 dollar part when the transmission was out of the car earlier in the rebuild.
William Mackenzie
IG: Shambam_makes Twitter: B_Shambam Last edited by bshambam; 09-23-2021 at 03:07 PM.. |
09-24-2021, 03:12 PM | #129 |
198
Rep 263
I can help you with it after I finish the installation write-up!
William Mackenzie
09-28-2021, 01:23 PM | #131 |
198
Rep 263
I tried to replace the valve cover gasket in the hope that it would resolve any issues but unfortunately, it looks like the PCV is toast...
I've had to order a new valve cover.... In addition, I've also ordered the replacement Vanos Bolts. I am rather annoyed that the car has to sit for a bit more but so be it.
William Mackenzie
10-01-2021, 10:51 AM | #132 |
198
Rep 263
Now that the car is on the road, I wanted to calculate some of the overall expenditures. This is a WIP spreadsheet (work in progress) of all values since July 2020.
It looks like I am quickly reaching, or have already reached spending as much money on modifications, replacement & repair as I did on the base cost of the car.
William Mackenzie
CDirks135.00 |
