07-14-2014, 03:22 PM | #89 |
Rep 548
After 6 months of dealing with this "Increased Emissions" off and on I can say this issue was finally solved with a new "low fuel pressure sensor (and required adaptor since the design changed)". Problem solved.
BTW...The dealer threw a pre-cat O2 sensor at this issue with no effect. The low fuel pressure sensor (which I led them to after reading tons of posts here) was the culprit.
991.1 GT3
SOLD: e92 M3 6MT, Jet Black/Black Dinan: Software Tune | CF Intake | Exhaust | Pulley Kit | Stage 1 Suspension | Pedals /// BBS e88 18x9.5 et19; 18x10.5 et19 on PS4 265/285 /// Lux Angel Eyes |
07-14-2014, 10:15 PM | #90 | |
3388
Rep 7,542
Not fun to replace it either.. but will be good as new afterward (sadly until bank 1 actuator fails too... )
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
07-14-2014, 10:44 PM | #91 |
Commander-In-Chief
2196
Rep 8,947
Drives: 2023 M2 Coupe, 2020 GLE 450
TBA replacment
Yes, do them both. About the same labor as doing one, and it's only a matter of time,,, (1 week in my case).
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
07-14-2014, 11:15 PM | #92 |
3388
Rep 7,542
Agreed, I did both at the same time - about 52K miles.
07-15-2014, 12:27 AM | #93 | |
Rep 444
Bank 1 was replaced 4 weeks ago! I couldn't do both bc I was dependent on the dealer approving warranty work.. |
11-06-2014, 01:29 PM | #94 |
Rep 473
Hey Guys,
I posted up that after storing the car shortly after getting it, I was getting the increased emissions error on the dash. After driving it for a while, it went away. Then, when I had battery issues, it came back. Again, I changed the battery and it went away. Anyways, more recently, I got the increased emissions again. I had filled up at an ESSO station near me and got the error message. I didn't know what was going on, but, I was going to take it to my local indy shop to have it checked out. Well, after about 3/4 of a tank, I filled it up with V POWER 91 Octane from Shell and the error went away. Yay. Well, shortly after that, the real problems started. I was downtown in early October and I was on my way home when the dash lit up with an increased emissions AND reduced engine output with the redline drop to 4500, rough running and all that. I shut off the car and it reset. It happened a number of times and I took it to my indy shop. They did an injector flush but that didn't solve the problem. After a further investigation of the codes, they saw a 2B59 (Coolant Thermostat). I had the thermostat replaced today. Fingers crossed that it the last of the engine fault codes (at least until the throttle actuator or the ICV goes). DrC
DR CHUCK
2009 E92 M3 Le Mans Blau on Schwartz. DCT. RAC RG63, KW V3, Eisenmann Race, AP Racing, Vorsteiner GTS5 Front Bumper, Vorsteiner GTS-V Rear Diffuser. |
11-07-2014, 11:29 AM | #95 |
Rep 536
I had the dreaded "increased emissions" code about two months ago. After popping in the OBD2 in? It turned out to be the "low fuel pressure sensor" and i was relieved that it wasn't something far worse($$$). It was such a easy fix! Just remove the air box, and it's right in front of you. If you have small hands? You can probably do it with out removing the air box.
12-11-2014, 06:13 PM | #96 | |
Rep 4,633
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
01-07-2015, 10:46 PM | #97 | |
Rep 337
01-24-2015, 04:53 PM | #98 |
13
Rep 71
My 2008 with 71k miles just had the same issue. I typically only drive it on weekends and have been getting the battery discharge warnings, but I've been hesitant to replace the battery since it goes away once I drive the car for a bit.
I retrieved the CC ID 31 code by holding the stalk button down, but I'm assuming this doesn't narrow it down to anything. I'm not under warranty, so I'm not too eager to pay a tech to look at it immediately based on the experiences above. I also don't want them to do guesswork on parts replacement if it's just caused by a weak battery.
E90 335i 6MT - Sparkling Graphite/Black - SOLD
E93 335i Auto - Black/Red - SOLD E90 M3 6MT - White/Black - SOLD E92 M3 6MT - Red/Tan - SOLD |
01-24-2015, 10:25 PM | #99 |
Rep 1,536
If we're talking about idle control valve, there is a service bulletin for it and you could get it replaced at your dealer for free without having warranty.
04-02-2015, 11:42 AM | #100 |
Rep 4,092
Drives: 21 X6MC
Does anyone have a DIY to fix this problem?
05-07-2015, 08:54 PM | #101 |
Rep 24
increased emissions problem - my turn
I just got the increased emissions warning light problem this week. I was driving at 70 on hwy, then wham, massive reduction in power...WTF? Increased emissions lights up, then the yellow engine malfunction icon pops up, but virtually no power - but engine was still running. Pull over, turn off, and back on....all good. Drive to next exit just fine. Then got back on and punched it and it happened again. Restarted and drove fine. Problem recurred a couple of times. Drove to dealer today, they say it is the Vacuum Pump. I hope this is the last of it. SA said this is unusual. My car is '12 coupe 6MT with 15k miles on it (delivery date dec 2011) and is uber clean. I asked what it might cost if not under warrantee and the guy said $2500 to 3000 (Pump over $2k) In case this is wrong, he just guessed but that is a sobering amount of $$ for what may be an ancillary part. I will update when I get it back. BTW, other than oil changes and tires this is the only issue the car has ever had.
05-09-2015, 07:54 AM | #102 | |
Rep 468
05-09-2015, 08:55 AM | #103 |
Rep 1,773
Drives: 328it, RIP M3, E46 Sold
My bank 1 finally went out at 175k miles so I just replaced both.
06-08-2015, 01:55 PM | #104 |
244
Rep 241
I'm getting code P0050 "H02S Heater Control Circuit (Bank 2 Sensor 1)"
Figured doing the obvious and replacing the driver side (Bank 2) pre-cat wide band (sensor 1) would fix the issue. Wrong. Car seems to run better post install but still throwing a CEL - Increased Emissions. Not sure how to trouble shoot now, as its acting like I never replaced the sensor. Suggestions welcome! -- car is a 2009 e92 dct with 112k. Runs well other than this, need to get it inspected soon!! |
06-10-2015, 01:12 PM | #105 |
Rep 16
03-03-2016, 12:28 PM | #106 |
Rep 11
Hi all,
I have a 2010 M3 with 28k miles. The increased emissions light appeared and stayed on for 5 days then magically went away. I did no notice some hesitation during acceleration but the car was drivable. I have EZ care so I took into the dealer and they found a bad O2 sensor which was replaced under warranty. I also had a flaky power door actuator which was replaced. Total bill was $1200 (but I paid $50 deductible only). Anyway, here's where it gets more interesting. They claim that the codes will be still be in the computer for "hundreds of miles" and I have a state inspection due this month which I will fail, they claim, because the codes are still in the system even though the idiot light is gone. They wanted $75 to clear them and claimed EZ care won't pay for it. Is there truth to this? I pressed them to indicate how long it takes to clear the codes and they gave me a wishy washy answer of 150 miles. Is this accurate? Can I clear them some other way easily? |
05-08-2016, 12:48 PM | #107 | |
Rep 5
04-27-2019, 02:10 PM | #108 |
Rep 7
I too have run into this problem. The car lights come on saying increased emissions and basically shuts down the car where it will not drive over 40 mph. The BMW of Mobile Alabama had my car for almost a month. This is what all they did to rectify situation before replacing the EDM on the 8/80,000 warranty. Replaced was ]Both front and back O2 sensors and both actuators. They kept getting bank 1 or bank 2 message when the swapped them out so the ended up replacing both. Now keep in mind without any warranty on these parts it would have cost $1700 for each actuator had I gone to BMW Galleria in Diberville MS ( close to my house but I will never ever take a car to that dealership again. Its the first BMW dealership to open in over 23 years and the owner does not deserve that dealership. Hew is a stuck up snob who caters to his friends and family.
Anyhow, Becky in Mobile is wonderful. She managed to keep my bill low and made sure it was fixed before giving car back to me. |
04-27-2019, 02:14 PM | #109 | |
Rep 7
04-27-2019, 02:18 PM | #110 |
Rep 7
