04-28-2024, 12:53 AM | #1 |
232
Rep 365
Drives: E53 X5, E83 X3, E93 M3
Why is this left hand thread? -- Fender
Can someone please explain to me why this one fastener on the right side fender is left hand thread only when all the others are right hand thread--even on the left side fender? I didn't understand this until I looked at realoem and verified it is indeed left hand thread. Then I had to find the ONE bolt...nearly cross threaded this thing...
This is wild... There must be a reason. Is this just the engineers messing with us? #14 https://www.realoem.com/bmw/enUS/sho...diagId=41_1706 Read the special note.
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
04-28-2024, 03:39 PM | #2 |
464
Rep 370
I want to know that too!
RocketyMan232.00 |
04-28-2024, 10:06 PM | #3 |
232
Rep 365
I can't be the only one, right?
Maybe there's an answer hidden in TIS...
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
04-28-2024, 10:15 PM | #4 |
232
Rep 365
TIS Information for Right Side Panel
This is the best I got...
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
04-29-2024, 05:13 AM | #5 |
mTekMods
2164
Rep 2,915
i broke that fixing point the first time i took off my fender. dumb for sure.
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
RocketyMan232.00 |
04-29-2024, 10:22 AM | #6 |
Rep 5,866
I don’t see a clear reason why a left-hand threaded bolt is used in a location that’s hard mounted. Typically, left & right threads are used when you want to increase or decrease the length of a rod with monoballs at each end (e.g., anti-sway bar drop link, camber arms, etc.).
04-29-2024, 03:39 PM | #7 |
464
Rep 370
Maybe it is an Easter egg from BMW engineers.
RocketyMan232.00 |
04-29-2024, 04:41 PM | #8 |
Rep 413
It wouldn't surprise me if it makes it easier on the factory line for a robot (or maybe a final inspection human?) to more easily keep the fender tucked closer to the unibody structure near that corner whereas tightening away from the unibody structure might tend to "move" the fender away from the hood a little widening the panel gap beyond allowable specification. At least that's why I would have chosen a reverse thread screw at that location.
Last edited by Theodore; 05-02-2024 at 08:08 AM.. Reason: "pull" replaced with "move" |
amg6975504.50 |
04-30-2024, 09:45 AM | #9 | |
Rep 649
04-30-2024, 10:08 AM | #10 |
Rep 5,866
There is absolutely no difference in how a left-hand threaded fastener applies/develops preload. Only difference is you drive the screw in turning CCW, instead of CW. Nothing is getting “pulled” because it’s a thru hole.
05-01-2024, 04:37 PM | #12 |
232
Rep 365
The captured nut is in a plastic clip that is riveted to the plastic fender. So I have a hard time thinking the torque of the bolt (with capture washer) will apply torque to the fender.
Still doesn't make sense.
2008 BMW M3 E93 MT
R135 └┼┼┼ ..246 |
05-02-2024, 05:39 AM | #13 | |
Rep 5,866
In the design of spacecraft and payloads, left-right hand threads are used to dial in pointing requirements of antennas, optics, cameras, star trackers, etc. I can’t think of any left-hand threaded fasteners being used for any other purpose in 30+ years of designing one-of-a-kind spacecraft/space vehicle structures. |
