Autotalent
      01-17-2023, 10:46 PM   #1
Barlos_
Barlos_'s Avatar
Drives: F83 M4
Can I put G82 Rims on a F82?
Good Day! Gentlemen, I had a question! Can I Fit BMW G82 M4 rims to a 2015-2020 F82 M4 ?
      01-18-2023, 12:20 AM   #2
omgf80
207
Drives: 18' ZCP F80
No, they changed the bolt pattern to 5x112. F8X is 5x120
Current:18' F80 AW | 05' T4R Sport
Sold: 89' 325ix | 09' 135i | 15' M235i | 17' I3
IG: omgf80
      01-18-2023, 02:12 PM   #3
Dabeamerking
Dabeamerking's Avatar
119
Drives: m4
5x112
      01-18-2023, 02:34 PM   #4
Chi_weezy
131
Drives: 2019 Ford Raptor
The grills should be an easy swap
Appreciate 6
DocL1930.00
Kilabyte3948.00
ntg442888.50
Redacre369.00
      01-18-2023, 03:06 PM   #5
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11490
Drives: E90M/E92M/M4GTS/M4GT4/X5M
they sell spacers that convert the hub and bolt pattern, but they're usually thick, so depending on offsets of both cars/wheels it could be possible
      01-18-2023, 03:09 PM   #6
Chi_weezy
131
Hun adapters yep and the wheels may look better with spacers anyways depending on offset of them
HotRodM4687.00
      03-08-2023, 12:40 PM   #7
Barlos_
Barlos_'s Avatar
Drives: F83 M4
Thank you so Much for everyone <3
      03-08-2023, 02:48 PM   #8
M3MF80
M3MF80's Avatar
Drives: M3 F80
I’ve seen HRE make similar wheels that look pretty close to G82 Comp wheels
      03-09-2023, 05:44 AM   #9
evoix
Drives: X3m Evo IX Evo X
looool. Ive seen people trying to make their grills look like the g82 and I just don't get it. People just want whats new even if it looks horrible.
After so many years i still cringe when i see the front grills of a g80/g82.
      03-29-2024, 06:14 AM   #10
M3SQRD
M3SQRD's Avatar
2164
G8x uses a 5x112 mm bolt pattern with a 66.5 mm hub.
F8x uses a 5x120 mm bolt pattern with a 72.6 mm hub.
G8x front wheel is 9.5et20 and its rear wheel’s 10.5et20.
F8x front wheel is 9.0et29 and its rear wheel’s 10.0et40.
The g8x uses much more aggressive wheel offsets than the f8x. Even without a bolt circle correction and a hub correction, the g8x offsets are too aggressive for the f8x. The front 9.5et20 is 2 mm more aggressive than the commonly used 9.5et22 aftermarket front wheel and this is without bolt circle and hub correction adapters. The rear 10.5et20 is too aggressive for the f8x (10.5et36 is about as aggressive as you can run with a 295 mm tire) and that’s before adding in the bolt circle and hub correction adapters. G8x wheels will not work on the f8x.
noemon46.00
f80post
