      07-30-2008, 06:51 PM   #1
BerkTechnology
BerkTechnology's Avatar
223
Drives: Fast
OFFICIAL Wheel/Tire Fitment Thread - What has already been done to 1ers
Hi Guys,
Since this car is still so new I'd like to start an official "database" of people that have successfully/unsuccesfully fitted wheel/tire combinations.
This is to save people the trouble of having to go through multiple sets of wheels/tires to try and get things to fit properly.
If you can list your relavent mods on the car (springs, shocks, rolled fenders, etc). We don't need to know if you have a blow off valve. Mods if you can make this a sticky! :smile:
I'll start off:
Setup #1
Wheels: D-Force EmPower
Front: 18x8.5 +40
Spacer: none
Rear: 18x9.5 +43
Spacer: none
Tires:
Front Yokohama Advan Neova 255/40/18
Rear Hankook RS2 Z212 265/35/18
Suspension/Fender Mods/Camber:
-KW V3 lowered ~1.5" front, ~1" rear
-Vorshlag front camber plates (brings the tires "in" more, away from the fender lip), ~2 deg neg camber front & rear
-slight roll front & rear
-had to cut some of the plastic out from the inner fender well
Notes:
Rubbed front fender where fender meets bumper
Rubbed rears slightly under hard cornering or on hard bumps on the street
(Rubbing or anything else to note)
Setup#2
Front: 18x8.5 +40
Spacer: none
Rear: 18x9.5 +43
Spacer: none
Tires:
Front Toyo R1R 255/35/18
Rear Yokohama Advan Neova 255/40/18
same as above
Notes:
-Fronts are perfect now with mods from setup #1. Can't say for sure if I would need to do any of the above if I started off with the 255/35/18 Toyo R1R to begin with.
-Rears rubbed badly. Could not run the rear 255/40/18 Neova setup with the wheel. The 255 Neova was wider than the 265 Hankook because of the square shoulder of the Neova. The Hankook has a rounded shoulder so it would only rub under lots of compression.
Pictures:
      07-30-2008, 06:53 PM   #2
BerkTechnology
223
Drives: Fast
Please post your info in this order:
Wheels: (Wheel Make and Model)
Front:
(size) (offset)
Spacer:
(size or 'none')
Rear:
(size) (offset)
Spacer:
(size or 'none')
Tires:
Front
(Make) (Model) (Size)
Rear
Notes:
      07-30-2008, 07:12 PM   #3
larryn
Drives: '97 332ti, '21 X5 45e, '16 GT4
My Setup:
Wheels: D-Force LTW5
Front:
17x9 +41
Spacer:
5mm
Rear:
17x9 +41
Spacer:
none
Tires:
Front
Dunlop Direzza Z1 Star Spec 245/40/17
Rear
Front has slight roll to the inner fender lip, and the tab in the wheel well attaching the bumper cover to the fender is trimmed.I'm running -1.6 deg camber in front (none added in rear)
H&R Sport Springs on stock dampers
Notes:
No rubbing.
      07-30-2008, 09:45 PM   #4
gatorfast
gatorfast's Avatar
Drives: 718 Cayman
Great thread idea. Pics would be nice too!
      07-30-2008, 09:46 PM   #5
scottn2retro
scottn2retro's Avatar
496
Drives:
My Setup:
Wheels: BBS CHs
Front: 17x8.5 +38
Spacer: none
Rear: 17x8.5 +38
Spacer: none
Tires:
Front Nitto NT01 245/40/17
Rear Nitto NT01 245/40/17
Front and rear has pretty aggressive rolling, and the tab in the front wheel well attaching the bumper cover to the fender is trimmed. I'm running -2.0 deg camber in front and rear (fixed -2 deg. camber plates from Impact Engineering in San Jose)
KW Variant V3 dampers and lowered about as much as possible
Notes:
perhaps slight rubbing during racing
Additional Note: for the pictures below, we modified the custom camber plates to give us -3.5 degree of front camber
2015 M4 BMW Club Racer
SCTS Racing
https://www.facebook.com/sctsraceteam/
      07-30-2008, 10:29 PM   #6
mikeo
Santa Fe Concorso
mikeo's Avatar
Drives: '11 M-sport 328i, '13 X1 28i
Setup #1
Wheels: TRMotorsport MT1
Front: 18x8.5 et44
Spacer: none
Rear: 18x8.5 et44
Spacer: none
Tires:
Front Bridgestone Potenza RE760 Sport 245x35-18
Rear Bridgestone Potenza RE760 Sport 245x35-18
Stock
Notes:
Test fit showed front offset caused clearance issues with strut and steering control arm. Never ran them on the road, returned to TireRack since I didn't want to run spacers on a street setup.
Setup #2
Wheels: BBS RG-R Forged
Front: 17x8 et40
Spacer: none
Rear: 17x9 et42
Spacer: none
Tires:
Front
None mounted -- test fit
Rear
Stock
Notes:
Purchased and test fit for brake clearance without tires mounted. Fronts cleared suspension components and brake calipers without a problem. Rear 17x9 had minimal (~1mm) clearance from rear brake caliper high points to inside circumference of wheel--insufficient for use, IMO. Offsets, both front and rear, looked very good.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
      07-31-2008, 11:16 AM   #7
guyp
Drives:
Setup
Wheels: Sport edition F10
Front:
(18x8) (40 offset)
Spacer:
(none)
Rear:
(18x8) (40 offset)
Spacer:
(none')
Tires:
Front
(Hoosier) (R6) (225x40r18)
Rear
(Hoosier) (R6l) (245x35r18)
none
Notes:
No rubbing but very hard on front tire with no camber.
      07-31-2008, 05:30 PM   #8
davidframe
Drives: 2002 535is 135 135 235 530e
same size 17" all around per roundel magazine
Wheels: Beyern Mesh
Front: 17 x 8 offset 40
Spacer:
none
Rear:
17 x 8 offset 40
Spacer:
none
Tires:
Front
Bridgestone Potenza RE-01R 245-40-17
Rear
Suspension/Fender Mods/Camber: stock
Notes: breaking in now. much more neutral in corners. heard brief rub in rear only when hitting big dip in road - twice in 75 miles city-fwy so far.
      08-02-2008, 11:04 AM   #9
TT1351
TT1351's Avatar
508
Drives: 135, GTS, E30 M3+
3P with Matte Black powder coated centers and gloss white powder coated
Front: 19x8.5" 5x120mm - 40mm offset (225/35/19 tire) Goodyear F1
Rear:
19x9.5" 5x120mm - 47mm offset (255/35/19 tire) Goodyear F1
      08-09-2008, 07:02 AM   #10
Evolution Racewerks
Evolution Racewerks's Avatar
Drives: 20 M340i,15 M4,12 328i,08 135i
Wheels: Forgeline Competition ZX3R with titanium fasteners
Front:
18x10 +24
Spacer:
none
Rear:
18x10 +62
Spacer:
none
Tires:
Front
Yokohama Neova AD07 285/30/18
Rear
KW Clubsport - Lowered quite a bit (sorry don't have exact number)
KW Upper Camber Plate (included with KW Clubsport) - Camber, secret :wink:
Evolution Racewerks Wide Body Front Fender
Notes:
Front: Will not fit with stock fender
Rears: Did not roll the rear quarter panel. Slight rub on inner plastic liner. No rub on fender. If you roll the fender, it might tuck the plastic liner higher and might not rub at all anymore.
      08-10-2008, 09:07 AM   #11
eunosracr
159
Drives: a car
My Setup:
Wheels: Enkreuz HS10
Front: 19x 8.5 (not sure of offset)
Spacer: none
Rear: 19x 9.5 (not sure of offset)
Spacer: none
Tires:
Front Hankook Ventus 225/35/19
Rear Hankook Ventus 255/30/19
Notes:
Slight rubbing in front over hard bumps. Rolled all 4 fenders for extra clearance.
      08-13-2008, 05:25 PM   #12
BerkTechnology
223
Drives: Fast
Setup on Jack's car.
Wheels: Breyton GTS-R
Front: 18x 7.5 +45
Spacer: none
Rear: 18x 8.5 +48
Spacer: none
Tires:
Front Yokohama S-Drive 225/40/18
Rear Yokohama S-Drive 245/35/18
KW Suspensions V2 Coilovers
Notes:
No rubbing. Slight drop.
Picture:
      08-13-2008, 11:15 PM   #13
burlington-track
Drives: 135i
Wheels: Beyern Mesh
Spacer: none
Rear: 17 x 8 offset 40
Spacer: none
Tires:
Front Bridgestone Potenza RE-01R 245-40-17
Rear Bridgestone Potenza RE-01R 245-40-17
Can you turn the fronts wheels all the way.
Running any neg. camber.
Anything you like or not like.
      08-14-2008, 11:26 AM   #14
timt
Reader, Rare Poster
timt's Avatar
Drives: F80 M3 Black (2015)
I have the same setup as Jack's car (GTS-Rs) with a 255 rear, all tires are Bridgestone Potenza RE-01R. No apparent rubbing, fits well. Still set to do a minimal lower via KW v2s. So far so good with the 255 tire.
~ TimT 2015 M3 F80 Black with DCT and Adaptive Suspension
Previous (all 6MT): Dinan 135i, E46 M3, 2007 Porsche GT3, 2012 Cayman R, 2003 Carrera 4S, 2001 Gemballa Boxster S, and some Audis.
      08-14-2008, 02:22 PM   #15
mikeo
Santa Fe Concorso
mikeo's Avatar
So it's not the same as Jack's car ;-)
Please complete the form for your exact setup. Thanks!
      08-14-2008, 11:31 PM   #16
davidframe
[quote=davidframe;209427]same size 17" all around per roundel magazine
Wheels: Beyern Mesh
Spacer:
none
Rear:
17 x 8 offset 40
Spacer:
none
Tires:
Front
Rear
UPDATE: Back from Buttonwillow. Can turn lock to lock. No camber adjustments. No rubbing heard. Very neutral - much oversteer gone. Tires sing in corners more than I expected - maybe too new. Took temps - added 3 psi to 39 cold (adjusted). Performance box measured .984 lateral Gs. Didn't feel like I had much more than that without going sideways. All stock - for now.
      08-14-2008, 11:45 PM   #17
burlington-track
Drives: 135i
245s all around
Were the fronts getting overheaded (singing)?
How many hard laps did you run?
      08-15-2008, 11:55 AM   #18
ichiban
ichiban's Avatar
95
Drives: 08 135i
Wheel: Linea Corse Lemans
www.wheeldude.com
Front: 19x8.5 et 35
Spacer: none
Tires: 225/35/19 Toyo T1R
Rear 19x9.5 et 40
Spacer: none
Tires: 255/30/19 Toyo T1R
Suspension: Stock
Note: No rubbing issues when it's only me in the car (exceptions: heavy cornering, 60+ mph entrance speed). Minimal rub when there are 3 passenger.
      08-15-2008, 03:21 PM   #19
Eddie_440i
Eddie_440i's Avatar
Sweden
42
Drives: Bmw 440i GC
Wheels: Superstar Bugel
Front:
19 x 9,5 offset 40
Spacer:
none
Rear:
19 x 10 offset 42
Spacer:
none
Tires:
Front Hankook Ventus 245-35-19
Rear Hankook Ventus 265-30-19
(Rubbing with full car and speedblocks) Just 2 in car no problem
      08-18-2008, 10:58 PM   #20
stylinexpat
stylinexpat's Avatar
415
Drives:
Originally Posted by BerkTechnology View Post
Hi Guys,
I'll start off:
Setup #1
Front: 18x8.5 +40
Spacer: none
Rear: 18x9.5 +43
Spacer: none
Tires:
Notes:
Setup#2
Front: 18x8.5 +40
Spacer: none
Rear: 18x9.5 +43
Spacer: none
Tires:
same as above
Notes:
Pictures:
I noticed you replaced your seats. What did the stock seats weigh in at?
      08-19-2008, 12:19 AM   #21
BerkTechnology
223
Drives: Fast
The full answer...
http://www.1addicts.com/forums/showt...419#post222419
      08-30-2008, 09:43 PM   #22
nordique14
53
Drives: SGM 135i 'vert
Wheels: D-Power LTW5
Front: 17x8.5 ET40
Spacer:
none
Rear:
17x8.5 ET40
Spacer:
none
Tires:
Front
Nitto NT01 235/40-17
Rear
none - stock everything. If the car were lowered there might be rubbing but at the stock height there is no problem.
Notes:
Might be able to fit the 245/45-17 tires. The front wheels and tires are very close to the suspension so it might be too much but I will try them next.
