      09-30-2012, 05:23 PM   #67
DrGadget
DrGadget's Avatar
Australia
46
Drives: M140i F20 LCI-2
2018 BMW M140i  [0.00]
Originally Posted by Eyeman View Post
Yep, I hate not having a spare (so now I have one). I also carry a mobility kit, a compressor, and a scissors jack. I'd recommend a small breaker bar over a ratchet. If a lug is really stuck and you stand on a rachet, it might break and still leave you stranded.
My jack kit from BMW-Direct came with a breaker bar and all the other goodies including the torque bar. I'm carrying a full size 18" spare until my alloy space saver arrives.
Current: Alpine White M140i F20 LCI-2, 250kW/335hp, 2018.
Sold: Melbourne Red 340i F30 LCI Luxury Line MMPK - 265kW/355hp, 2016.
Sold: Alpine White 123d e82, 2010, 150kW/204hp.
      10-03-2012, 10:01 PM   #68
cpsquare8
Drives: 135is
Ok - for around $200 + 25 shipping and handling and change plus mounting you can get items to build your spare on-line or at your dealer. Discounted pricing at getBMWparts.com
Collision Catalog - 2001 - BMW - 330XI front suspension, wheels, wheel, spare 330i, 330xi $57.28 PN 36116750007
OEM Catalog TIRE 125/80D17 99M C $148.80 PN 36122150029
Tires are about a week on order. So for about $250-275 peace of mind and a new set up.
      10-05-2012, 08:54 AM   #69
str8shot
str8shot's Avatar
107
Drives: N54 Montego Blue 135i
Here's what I did...
Here's what I did.
$2.99 @ Walmart:
$9.99 @ Walmart:
Should be more than enough to get you home.
      10-15-2012, 07:34 PM   #70
DrGadget
DrGadget's Avatar
Australia
46
Originally Posted by str8shot View Post
Here's what I did.
$2.99 @ Walmart:
$9.99 @ Walmart:
My tyre suppliers showed me some of the handiwork of those who had used plugs and in the process destroyed their non-RFT tyres. In effect, the holes are too big to enable a patch/plug to be used. Not for me. I decided to keep the weight down and use a BMW Mobility Kit. The sealant is latex-based and washes out, so a holed tyre is not written off by goo.
      10-15-2012, 09:17 PM   #71
mleskovar
Drives: '18 230i
$9.99 @ Walmart:
FYI....a 250PSI air compressor that plugs into your auxiliary 12V port is smaller than this hand pump and fits easily in the battery compartment. Costs $8.99
      10-15-2012, 09:30 PM   #72
mleskovar
Drives: '18 230i
Given the choice always use internal patches over plugs but patches won't work at all close to the side walls because of flexing. The "hole" is only as big as YOU make it (unless the FOD makes it too big for even a plug). Once you get the tire goo into your tire pressure sensor and tire air valve they are history and need to be replaced. The goo/sealant makes a mess and is not easy to remove. If left in the tire it can solidify or freeze and cause tire balance problems. Ask your tyre supplier what they think of the sealant. But to each his own.
      10-15-2012, 10:28 PM   #73
bmw1racer
bimmerphile, technogeek
bmw1racer's Avatar
Drives: 2012 E82 6MT Sport
I would think (hope?) that the BMW Mobility Kit would not damage TPMS or the valve, since it's from BMW...
      10-15-2012, 11:36 PM   #74
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
+1. Yup, when BMW assist came for me when I had a flat on the "other side" of Germany... he also said it is always better to use a spare tire(even a mini like I had in the trunk) then to use the Mobility Kit. It is a last resort.
I also believe in order to "put" the glue/sealant in the tire... you have to remove the valve stem "guts" with a tool. The service tech also said even with the sealant inside... the wheel WILL vibrate like crazy. So I installed my mini donut. No vibrations, but major handling issues and the rear end was always "wagging" going down the road. Not fun.
That is why I bought a full size spare. Never again. I don't care how much trunk space I lost. I feel safer with that full size spare back there!
Dack
      10-17-2012, 04:54 AM   #75
DrGadget
DrGadget's Avatar
Australia
46
Mobility kit sealant
Dack
Dack: It is a latex sealant, and the idea is to spread it around then get to a tyre repairer ASAP. That is my around town solution so I don't expect vibrations at 80 kph. For long trips, I will use a M Sport spare and on that point I can only agree with you. The cost of the alloy space saver plus freight to Australia was as ridiculous as the prices Michelin, Continental and others gouge us with here. That's why I chose a Mobility kit out of the US and a Jack system out of Germany-UK as shown.
      05-24-2016, 10:22 PM   #76
RoscoT
Drives: 128 Convertible
The ContiComfortKit was recommended to me.
http://www.continentaltire.ca/www/ti...ortkit_en.html
      11-09-2019, 01:22 AM   #77
bobowar135
bobowar135's Avatar
Australia
3479
Drives: 08' Sedona Red 135i
Picked up am OEM jack and spare wheel in anticipation of my move to non-runflat tyres. The wheel is 17x7.5 and is brand spanking new shod with a new 225/45ZR17 Continental tyre. I scored them both from an E46 318i sedan at a wrecking yard for $120. Now if only I could find a retailer that has Michelin PSS's in stock!
Gangplank1541.50
Dackelone10588.50
      12-08-2019, 09:22 PM   #78
Ursan
Ursan's Avatar
53
Drives: '12 128i, Volvo 945t & 780t
Dunno if helpful
But if you're in the states (I don't know if they ship internationallyhttps://www.ecstuning.com/b-assemble...t/m3sparekit1/)
Dackelone10588.50
