      03-30-2014, 06:32 PM   #23
Stohlen
Drives: AW 135i
2008 BMW 135i  [5.66]
Originally Posted by Icewall View Post
Must be your tires. I have vmr v810 in the same offset with mpss tires. 235/40/18 and 265/35/18, no rub at all. Not even that tight, but it is close to the fender on the front.
He's rubbing on full lock on the front fender liner, not over bumps or anything. Most people rub on the front liners but just dont care because they hardly go full lock. Tho that being said I have 245/40s which are taller and barely rub at all at full lock.
      03-30-2014, 07:08 PM   #24
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
Originally Posted by 135Pats View Post
IDK but i'd love to know. I dream of fitting 245 up front.
I run 245/40 Dunlop ZIIs up front on ARC8s
-3* of Camber at 8 Degrees of Positive Caster and a 5mm spacer and I don't rub, although my front fenders are indeed rolled to avoid a rub under full compression as I'm quite low:
      03-30-2014, 07:21 PM   #25
Stohlen
Drives: AW 135i
Same. What are you running out back these days?
      03-30-2014, 07:33 PM   #26
jmc777
Drives: 2020 X2 M35i
I'm running 235/40 PSS on arc-8s all around on my 128 with stock sport suspension. No rubbing at all.
      03-30-2014, 07:34 PM   #27
Kgolf31
Kgolf31's Avatar
460
-2* degrees with 245s.
rubbing a bit on slightly rolled fenders. need to fix that
      03-30-2014, 08:06 PM   #28
805beemer
Drives: 2008 135i
I was under the impression caster wasn't adjustable on our cars? I know the m3 control arms add positive caster along with .75* neg camber. You guys think the m3 arms would give me enough caster?
      03-30-2014, 08:07 PM   #29
135iam
Drives: 2010 135i 6mt
Originally Posted by ShocknAwe View Post
Another thing worth looking at, I believe the front M3 tension struts (uppers) change front caster, and the M3 wishbones (lowers) add neg camber. Dunno how the struts change it though, cant remember to save me.
I would like to know the answer to this. I have been told the lowers provide approx -0.7 degrees of negative camber, by pushing the bottom of the front wheels out. Hadn't heard about the uppers impacting geometry, just that they remove flex with stiffer bushings and firmer that the stock stamped steel arms.
      03-30-2014, 08:16 PM   #30
Kgolf31
Kgolf31's Avatar
460
[IMG]http://i1015.photobucket.com/albums/...1/dyjatyra.jpg[/IMG]
I'm running coilover suspension with camber and caster adjustable plates
OEM suspension has limited adjustments for camber.
You do not need any more caster. Positive caster moves the wheel up front in the wheel well. More caster and you will rub more on that fender liner.
Unfortunately, caster isn't adjustable.
      03-30-2014, 08:38 PM   #31
805beemer
Drives: 2008 135i
Ok thanks. so then would negative caster help if I bought some adjustable camber/caster plates?
      03-30-2014, 08:56 PM   #32
Kgolf31
Kgolf31's Avatar
460
Most likely, but cannot guarantee it would solve the issue.
I don't know if the 135i has less fender room, but I'm running max caster and from lock to lock I don't rub.
      03-30-2014, 09:08 PM   #33
135Pats
135Pats's Avatar
Drives: A few BMWs
Dang that's a lot of camber. So with plates it sounds like it's doable...they're on my 'to do list' but front sway and limited slip come first. So I can't say it's a huge priority, summertime i'll get around to it. 245/265 would be very nice and neutral I bet.
F30 N55 XDrive EBII
      03-30-2014, 09:44 PM   #34
andrey_gta
andrey_gta's Avatar
298
Drives: 130i coupé ;)
2008 BMW 128i  [10.00]
I'm quite low:
Nice car, loving the LCI Halogens. Are those the 18's. Square set up?
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff
"The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is
      03-30-2014, 10:08 PM   #35
da1edub
Drives: '08 135i
Timely thread
I'm wondering if the Bridgestones run a little wider than the PSSs and other options in that fitment. Same deal here, more or less--installed staggered EC-7s with 235/40/18 and 265/35/18 SO-4s on a stock suspension '08 135i last week, and experienced immediate audible rubbing up front during cornering. After getting the car up on a lift, it's apparent the fronts are getting some pretty substantial rub on the fender well, as well as lightly touching the strut on the inboard side. The rears seem fine. Given that I called Apex twice to confirm that fitment (tire size/wheel combination) was a no-hassle setup on this car, I'm not excited about this development.
The options seem to be to change the tires (either the sizes or brand) or try some additional hardware tweaks to get this wheel setup to work. Camber plates had been next on the list of intended modifications anyhow, so we're we're going to try Vorshlags and 3mm spacers this week to try and gain the necessary outboard and inboard clearance--will update accordingly.
      03-30-2014, 10:08 PM   #36
SacBeemerGuy
Drives: 2011 135is
Ok what's the deal! I'm about to buy apex EC-7 with 235/40/18 front and 265/35/18 rear and was told I would have zero rub issues even if I'm moderately lowered.... And the tires would be Michelin PSS's which are considered some of the widest... I don't want spacers or crazy camber to make these work
Please keep this updated
Also are you a vert? My phone won't show sorry.
      03-30-2014, 10:11 PM   #37
805beemer
Drives: 2008 135i
I'm a coupe
      03-30-2014, 10:16 PM   #38
SacBeemerGuy
Drives: 2011 135is
I'm a coupe
I would be fairly unhappy if I bought these and had rub issues... Hopefully the cause is worked out and an easy fix...
I am also a coupe
      03-30-2014, 10:30 PM   #39
805beemer
Drives: 2008 135i
Just measured both the width and height of the fronts. 25 1/4" tall and 9 5/8" wide. Not sure how much that would change with them actually being mounted on the car.
      03-30-2014, 10:34 PM   #40
135iam
This forum needs 135i/128i 18x8.5 +45mm front tire sticky thread.
1. Stock suspension these tires fit
2. Stock suspension these tires rub
3. Tires that fit with added neg camber
4. Tires that fit with added neg camber and roll or pull
And then there are spacers, hell I thought we bought these wheels to avoid spacers!
BigZ8822.50
      03-30-2014, 10:48 PM   #41
135iam
That's pretty close to what tire rack lists 25.4" and 9.5" for the re-11
Have you pulled the alignment pins, loosened the stock top hats, and maxed out stock suspensions neg camber?
      03-30-2014, 11:20 PM   #42
805beemer
Drives: 2008 135i
No, wasn't sure if that would help or not. Plus If I did that the rim would most likely rub the strut. I have some 5mm spacers but lost the extended lugs and wasn't sure if using the stock lugs was a good idea.
      03-31-2014, 06:26 AM   #43
Kgolf31
Kgolf31's Avatar
460
That is on the light side of camber for me
It is going to be an AutoX/Track car, so more camber the better. Plus I had to clear my strut/spring so I needed that camber.
17x8.5 ET40 Square
Rears need some more work, but I can get them to fit with high compression turned, it is just the low compression I'm dealing with some rubbing
      03-31-2014, 09:07 AM   #44
135Pats
135Pats's Avatar
Drives: A few BMWs
Dang. Yea makes perfect sense for a track setup, but on city streets I’d imagine 3 degrees is going to hunt all over the place and chase all the little cambers in the road. Tire wear aside.
So getting back to the original point- on a street driven E8x, you aren’t fitting 245 up front without making some significant alterations. Stock ride height maybe, lowered no chance unless you have camber etc similar to you track-specific setup. I’m running about 1.5 of camber up front, and there is no way a 245 would clear the strut or the fender.
I’m sure it’s an awesome track setup though.
F30 N55 XDrive EBII
