The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > OEM Digital TV Retrofit (for CIC)..... DONE
      01-04-2024, 03:21 PM   #155
kzg1969
kzg1969's Avatar
Scotland
1299
Drives: X3M Comp / M3 E93
Originally Posted by Jose_JN View Post
How did you flash it?
It is possible to code it with NCS Expert (installed on a e9x series) or do you have to flash/code using Esys and a bench setup?
I am planning to move from DVBT to DVBT2 and I am not sure on what module should I have to buy and how to code/flash it properly
Best Regads
It was done on a bench by John (ccfj1) who i found on M3Cutters forum. Exactly what he did, i dont know. It just worked when he sent it back!
IIRC, when i was researching this, you can do it using NCSExpert but i dont have a copy nor the files (nor probably the skills).
      01-16-2024, 03:18 PM   #156
Jose_JN
Jose_JN's Avatar
Spain
88
Drives: e93 330d
Originally Posted by kzg1969 View Post
Hi,
This is the module that's in the car, so should be the correct one?
Hi mate,
Could you tellme if you have 'Europe West' at 'Tv Standard' menu?
I have bought a module like yours (same box) but, once installed I have 'automatic' and a lot of regions but not Europe West. So I dont know if it is ok for my country or it is only a coding issue.
With the new one (Dvb t2) only 10 stations are found while the old one (Dvb t1) can find 30+ channels.
I also have your same problem... no signal message even when stations are found
Next step, try to flash it...
Thanks for your support!
      03-07-2024, 05:12 AM   #157
scroller
14
Drives: 335i
Hi,
When changing the antenna for the E90, in order to receive a signal from it, is it attached additionally at the back, because I no longer have free inputs, or are the pins on the socket itself, which is connected to the big socket connected to it?
Thanks if someone know answer this question it will help me a lot.
