✚WHEELSTO | Macht Schnell Drop In Filter & Scoops for N54
09-09-2010, 11:41 PM | #1 |
1767
Rep 7,652
Ever since the introduction of Macht Schnell into the world of BMW, we have been big fan and advocate. Products are high quality and the beauty is in its simplicity of design and focus on function. Macht Schnell N54B30 Panel Filter http://www.wstoshop.com/servlet/the-...ormance/Detail Features of the N54B30 High Performance Panel Filter: - Direct replacement for your original equipment filter panel - Washable/reusable cotton gauze which allows more airflow - Sturdy sidewall construction ensures filter will last the life of the vehicle - Tight leak proof seal with your factory air box - Deepest multi-layered pleats increase air flow and maintain critical protection levels, while still providing maximum air delivery - Maintains OEM filters 99% debris collection efficiency to meet ISO 5011 standards - Maintains BMW engineered pressurized air box and OEM appearance Macht Schnell Intake Charge Scoop http://www.wstoshop.com/servlet/the-...-intake/Detail Features: - Aids in additional airflow to factory airbox, additional gains when combined with Macht Schnell High Performance Filter - Polyethylene construction, nearly indestructible - Elegant textured exterior, smooth gloss inner for maximum air delivery with no restriction - Will not rust, or deteriorate over time - Sold as a set Macht Schnell Stage 1 Intake Charge Kit For those looking to add both, check out the Stage 1 Kit (N54 Filter + ICS) http://www.wstoshop.com/servlet/the-...ormance/Detail The Filter + ICS will provide maximum air delivery to your N54 with noticeable power gains. You can check out more Macht Schnell products HERE How to Order or Get More Information: Click on the pictures to go to order online Call: 312.880.7767 Email: info@wheelsto.com PM the WheelSTO Crew: Julius ● Julius@WSTO Dave ● Dave@WSTO Support ● WheelSTO
09-10-2010, 08:55 PM | #3 |
1767
Rep 7,652
It is literally so easy that you don't need a DIY. there are couple of self tapping screws that you need to line up and use a small drill to make the lead hole and screw in.
However, the tricky part (if at all) is getting the grille and the snorkel out to make sure that you have clearance to work on them. I will try and look for a good DIY on that.
12-16-2010, 07:09 PM | #8 | |
1767
Rep 7,652
I am pretty sure that there are no plans to make them RED and i don't even know if that is possible as this is not made of metal but from injection molded plastic. the smoothness of the inside is what really differentiates the Macht Schnell scoops and also one of the reasons this cannot be painted or powdercoated and dyed.
filter, intake, macht schnell, n54, wheelsto |
