09-10-2010, 07:28 PM | #1 |
1771
Rep 7,653
✚WHEELSTO | Macht Schnell True 3" Down Pipes
Ever since the introduction of Macht Schnell into the world of BMW, we have been big fan and advocate. Products are high quality and the beauty is in its simplicity of design and focus on function. Stock downpipes cause a major restriction in exhaust flow coupled with their small 57mm (2.25″) pipe diameter and numerous crush-bends with factory pre-cats squeezed in engine compartment. This results in excessive backpressure and excessive heat, which ultimately affects overall performance at all RPM loads. Macht Schnells 76.2mm (3.00″) N54 Catless Track Downpipes allow instantaneous turbo spooling and ultra-low backpressure proving significant hp/tq gains that can be felt immediately after installation. Mandrel-bent T304 Stainless Steel tubing is used to ensure constant exhaust flow is achieved by eliminating any restrictions, resulting in maximum gains and noticeable sound during turbo spooling. TIG-welded construction and Stainless Steel V-Band/catback flanges are durable as well as pleasing to the eyes. Heavy Duty exhaust gaskets and Stainless locking fasteners complete the package. Stainless O2 sensor bung locations are mounted in the factory locations while introducing additional stainless steel thermocouple bungs for those monitoring EGTs. Macht Schnell 3.0" Stainless Steel Down Pipe http://www.wstoshop.com/servlet/the-...ownpipe/Detail Downpipe Features: - 76.2mm overall diameter, eliminating restrictive factory pre-cats and crush bends - 100% T304 Stainless Steel construction, using mandrel bends - Precision TIG welded joints - Heavy-Duty Stainless V-Band/Exhaust flanges - Heavy-Duty locking fasteners and exhaust gaskets included - Factory O2 locations retained with Stainless Steel bungs - Pre-installed Stainless EGT bungs for easy thermocouple mounting - Reduced underhood temperatures Macht Schnell 3.0" Thermal Coated Down Pipe http://www.wstoshop.com/servlet/the-...ownpipe/Detail Downpipe Features: - 76.2mm overall diameter, eliminating restrictive factory pre-cats and crush bends - ThermalCoating reduces surface temperatures by as much as 54% - Meets U.S. military specification MIL-C-81751B for metallic-ceramic coatings, including FAA approval - 100% T304 Stainless Steel construction, using mandrel bends - Precision TIG welded joints - Heavy-Duty Stainless V-Band/Exhaust flanges - Heavy-Duty locking fasteners and exhaust gaskets included - Factory O2 locations retained with Stainless Steel bungs - Pre-installed Stainless EGT bungs for easy thermocouple mounting - Reduced underhood temperatures You can check out more Macht Schnell products HERE How to Order or Get More Information: Click on the pictures to go to order online Call: 312.880.7767 Email: info@wheelsto.com PM the WheelSTO Crew: Julius ● Julius@WSTO Dave ● Dave@WSTO Support ● WheelSTO
09-15-2010, 08:57 AM | #2 |
201
Rep 2,117
We have 5% off special going on every product through our website!
www.wstoshop.com Please feel free to contact us for more information! Thank you for your support
10-12-2010, 01:50 AM | #5 |
Rep 3,070
Drives: A boring one...
Do these DP's come Catted, or only catless?
10-13-2010, 04:19 PM | #6 |
1771
Rep 7,653
Currently they only come catless.
11-01-2010, 09:45 PM | #8 |
Rep 443
You can purchase online at
Stainless Steel - http://www.wstoshop.com/servlet/the-...ownpipe/Detail Thermal Coated - http://www.wstoshop.com/servlet/the-...ownpipe/Detail Don't forget to use coupon code : winter5 for extra 5% off! Thank you for your support |
down pipe, macht schnell, wheelsto |
