04-04-2024, 08:57 PM | #23 | |
Rep 4,367
link below has 255/35/19 on 19x9.5 ET35, square. although 19", the 255/35/19 tire dimensions are equivalent to 255/40/18 and it, will work on 18x9.5 ET35, square. https://f30.bimmerpost.com/forums/sh...7&postcount=26 |
04-04-2024, 11:41 PM | #24 | |
14
Rep 27
04-04-2024, 11:56 PM | #25 | |
Rep 4,367
in their test, the really stretched tire did best, however it is not practical for a daily driver, as you will have slim to no curb protection, less impact protection and harsher ride. most of the stuff i have read discuss having the wheel width equal to or 0.5" wider than the tire tread(not section) width for best handling, ride, etc. this seems most reasonable and what i mostly try to suggest. . Last edited by alohasurftoad; 04-05-2024 at 12:26 AM.. |
440i13.50 |
04-05-2024, 02:43 AM | #26 | |
1960
Rep 2,140
The extra wheel gap really isn't that bad; it's all about having a decent contact patch on the tarmac, but also not too much sidewall which give a softer feeling to the ride; that's why I'm not keen on 255s fitted to 18x9s - it's just a touch too wide IMO But that's my personal preference
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298 Last edited by danb1979; 04-05-2024 at 03:00 AM.. |
440i13.50 alohasurftoad3122.50 |
04-05-2024, 03:17 AM | #27 |
14
Rep 27
04-05-2024, 03:29 AM | #28 |
1960
Rep 2,140
Only you can make that decision..
The ARC8s with 245/40/18s on the link I added on the previous page look to be a spot on fitment to me; I know tourings do have that bit more generous arch size etc Equivalency table Rim width Minimum tyre width Ideal tyre width Maximum tyre width 5,0 Inches 155 mm 165 or 175 mm 185 mm 5,5 Inches 165 mm 175 or 185 mm 195 mm 6,0 Inches 175 mm 185 or 195 mm 205 mm 6,5 Inches 185 mm 195 or 205 mm 215 mm 7,0 Inches 195 mm 205 or 215 mm 225 mm 7,5 Inches 205 mm 215 or 225 mm 235 mm 8,0 Inches 215 mm 225 or 235 mm 245 mm 8,5 Inches 225 mm 235 or 245 mm 255 mm 9,0 Inches 235 mm 245 or 255 mm 265 mm 9,5 Inches 245 mm 255 or 265 mm 275 mm 10,0 Inches 255 mm 265 or 275 mm 285 mm 10,5 Inches 265 mm 275 or 285 mm 295 mm 11,0 Inches 275 mm 285 or 295 mm 305 mm 11,5 Inches 285 mm 295 or 305 mm 315 mm 12,0 Inches 295 mm 305 or 315 mm 325 mm 12,5 Inches 305 mm 315 or 325 mm 335 mm That table states a 245 or 255 will be perfect, 265 max (far too wide IMO) So it's down to you which to pick over the other... You will be absolutely fine with both
440i13.50 |
04-05-2024, 03:48 AM | #29 | |
14
Rep 27
danb19791959.50 |
04-05-2024, 10:21 AM | #30 | |
119
Rep 215
danb19791959.50 |
04-05-2024, 10:39 AM | #31 |
1960
Rep 2,140
Yes it's really good; a good tool to save to your bookmarks
It helped me when I was deciding on tyre sizes for the 18x8.5 and 18x9.5 LMs I ran on a previous Jap import E39 touring; everything was saying 235/40 and 265/35; but 245/40 and 275/35s worked the best:
mobbinthesteez22.50 |
04-05-2024, 12:25 PM | #32 |
Rep 4,367
https://f30.bimmerpost.com/forums/sh...&postcount=311
https://f30.bimmerpost.com/forums/sh...&postcount=313 the links above show obzen's F36 rwd 255/40/18 on 9 ET30 at m-sport height. at stock height your x-drive gaps will be bigger. if you go with 245/40/18 increase gaps 3.8 mm. with either size(but moreso with 245) you'll want to get lowered to reduce the gap and inherently tuck the upper shoulder of the tires slightly more. i suggest Eibach Pro-Kit E10-20-031-05-22 with F80 bumpstops over Koni SA dampers and rest of the bits comprising the strut/shock assembly. sorry to have opened "another can of worms", lol. |
04-05-2024, 02:12 PM | #33 | |
14
Rep 27
04-05-2024, 02:33 PM | #34 | |
Rep 4,367
KW V1 better product eibach pro kit + koni SA would be about the same price as B14 but cheaper than KWV1. eibach/koni will ride much better than both and be lowered just the right amount, since max recommended front lowering for x-drive is about 1.5" or 38mm. this is due to stresses put on the half shafts since the angle into the front differential changes when lowered. if you have the money for KWV1 and prefer the height adjustability, get that since the ride is better than the B14. although the eibach/koni setup is non height adjustable, the lowered ride height is just right(imo), reverse rake is addressed, handling is sporty yet compliant, since the spring rates are just 10% firmer than stock. for an idea of the drop, smak168 has the eibach on his F36xdrive, here... https://f30.bimmerpost.com/forums/sh...&postcount=158 here's one of a few koni/eibach threads in the suspension sub-forum https://f30.bimmerpost.com/forums/sh....php?t=1901058 |
440i13.50 |
04-05-2024, 03:29 PM | #35 | |
14
Rep 27
mobbinthesteez22.50 alohasurftoad3122.50 |
04-05-2024, 05:15 PM | #36 |
14
Rep 27
Side note - alohasurftoad will 245 squared be enough tire for a stage 2 tuned car? Just wondering if the 255 will provide a significant amount of difference compared to the 245 when I’m not stock power. Thanks
04-05-2024, 06:30 PM | #37 | |
Rep 4,367
if you want traction from a tire, compound>width. of course i understand running a 200TW extreme performance summer is not practical for a daily driver if you really wanna talk traction for stage2, an LSD should be in the convo before all of this...LSD+255's>"one legged" 285 |
440i13.50 |
04-05-2024, 08:19 PM | #38 |
14
Rep 27
I didn’t realize our cars could fit a 285! Yes I was debating a 200tw tire but like you said not good for a DD also I get a lot of rain here in the summer. How much would a LSD be with install roughly?
04-05-2024, 08:38 PM | #39 | |
Rep 4,367
above is strawhatdan running 255/40/18(26") on 18x9 ET30 front, 285/35/18(25.9") on 18x10.5 ET40 rear. fyi, this staggered size combo would work with an x-drive as well. the cheapest LSD is M-Performance, part# 33-10-8-659-989. $2330 USD plus ship and speculating install cost of $800-$1200 USD or more? idk... but yes OUCH! this'll hurt your wallet something fierce. Quaife or Wavetrac LSD's are best and cost even more! |
440i13.50 |
04-06-2024, 01:20 PM | #40 |
23
Rep 66
I just ordered a set of ARC8's 18x9 et30 today for my GC, and this thread was extremely helpful in my decision with wheel spec and tire sizing.
Thanks to all who contributed, especially Alohasurftoad. His knowledge and links provided were much appreciated. |
04-06-2024, 02:56 PM | #41 | |
1960
Rep 2,140
04-06-2024, 06:55 PM | #42 |
14
Rep 27
What tire size are you going with?
04-06-2024, 08:55 PM | #44 |
23
Rep 66
255/40/18 all the way around. Not sure which tire yet. Ill sort that out later.
I don't mind the slight extra poke. I actually really like that look and prefer it over the extra gap from the 245s. And I don't want to go with 19s, this is my dd and I live in the NE. |
