BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > HELP: CAS: Selector-lever interlock
      09-02-2020, 04:46 PM   #1
soursalsa
Kid Diddler
Drives: 2009 BMW 328i E90
Hi all,
Just ran ISTA today to finally diagnose my gearbox light.
Code: 00A0B6
Description: CAS: Selector-level interlock.
This is the only active fault, I got this light after putting my shifter back in place, having previously lifted my shifter out of its normal resting spot to remove some screws, all of this in order to access a broken Sport mode wire, which works perfectly fine. I’ve encountered on-and-off issues with the gear selector getting stuck in park (P), this has been rare since the first encounter and I normally just get the light. I’m not sure what the problem is, any help would be appreciated!
      09-03-2020, 11:09 PM   #2
e91Owner
e91Owner
Drives: 2011 e91 & 2010 e60
Originally Posted by soursalsa View Post
Hi all,
Code: 00A0B6
Since you are using ista, it should also have a fault isolation routine to follow. I don't have my laptop at the moment, but it's pretty easy to follow from the fault tree.
      09-09-2022, 04:13 PM   #3
rayant4
Drives: 2009 328i
Did you manage to fix this problem, I just got the same code when I fixed my wires
      03-21-2024, 02:47 PM   #4
bmw335i_901
Drives: BMW 335I 2008
was anyone able to find a fix for this problem? have the same thing right now.
e90, help a noob, help me pls, help needed
