Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Oil change -- what oil to use?
      06-07-2011, 01:50 PM   #23
Chriztofor
Chriztofor's Avatar
Drives: '06 325i and '13 X5
By the way, here is my e-mail to Royal purple. If they respond, I will post it.
Hello,
I have a 2006 BMW 325i. As per the owner's manual, it requires LL-01 oil. There are two oils that carry this certification Castrol 0w-30 and Mobil 1 0w-40. Does your oil carry a LL-01 certification? If not why not? If you claim that Royal Purple exceeds manufacturer's specs. Can you be more specific.
For example, Castrol 0w-30 and Castrol 5w-40, does not meet API SN, does not meet SM, meets SL, SJ, ACEA A3, B3, and B4. Castrol 0w-30 is LL-01 approved and Castrol 5w-40 is not LL-01 approved. Therefore, I have to go with 0w-30 because BMW requires LL-01 oil.
Also, Castrol 10w-40: MEETS API SN, SM, SL, SJ, ACEA A3, B3, and B4 but it is not LL-01 approved. This oil meets two other criteria API SN and SM more than 0w-30 and 5w-40 and it is not LL01 approved. Since Castro's 10w-40 EXCEEDS 0w-30 but is NOT LL-01 certified I still have to use Castrol 0w-30 as per BMW.
With that in mind, here is my question. Why should I use royal purple over Castrol 0w-30 and/or Mobil 1 0w-40 when they are both LL-01 (Longlife) approved?
Thank you!
Your future customer,
Chris
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
      06-07-2011, 02:36 PM   #24
DieselDiner
DieselDiner's Avatar
486
Drives: 335d
Originally Posted by Chriztofor View Post
0w-30 is LL-01 approved and 5w-40 is not, why?
Could it be that Castrol did not submit 5W-40 to BMW for LL01 approval? Mobil has a similar situation with 5W-30 EPS vs. 5W-40 EPS for BMW LL04; the 5W-30 is approved, the 5W-40 is not. Yet both grades have Mercedes 229.51 approval, which is arguably more stringent than LL04. I've always assumed that Mobil simply did not submit the 5W-40 for LL04, but don't know that for a fact.
      06-07-2011, 02:45 PM   #25
NaTuReB0Y
Powered By 36DD
NaTuReB0Y's Avatar
Drives: 2006 E90
I have been using Mobil 1 0W40 and Castrol 0W30 for the last 6 years........with no issues
5,000 miles intervals.......I've done 16 oil changes + 2 free oil change under warranty.....
currently at 94,197 miles.......next oil change in a few weeks.
2006 E90 330i Jet Black | 20" WORK VS-XX | FK452 | H&R Sport on Koni Yellow | REMUS QUAD
jc207815.50
      06-07-2011, 07:21 PM   #26
Chriztofor
Chriztofor's Avatar
I don't want to keep double posting so read this link http://www.e90post.com/forums/showth...=1#post9770500
      06-29-2011, 01:14 PM   #27
ALL4_3SERIES
Drives: 2011 BMW 328XI Sedan
U.S. Spec Car in Europe
Hello all! I am a newbie here and recently purchased a 2011 E90. My question is this I took delivery of my car in Europe as I am stationed here in the military. I assume my car had LL-01 from the factory, but I am not sure. I have about 1037 miles and would like to change the oil at 1200 miles (following Mike Miller's Old School Maintenance plan). So should I run a LL-04 oil for now (I move back to the states in six months), then change the oil again to meet the LL-01 standard while I am in the states or can I keep the LL-04? I have heard these standards are due to high sulfur content in the gasoline in the states, and a low sulfur gasoline in Europe. If my car in fact had LL-01 in the car from the get go, did I harm the car by keeping that oil in there for the break in period using European gasoline? I honestly didn't have the choice to change it, as the Germans are sticklers on wasting oil products. They didn't even want to change my oil at 1200 miles, but they finally agreed to make the appointment. Sorry lots of questions, but I love this car and want to take good care of it. Help anyone?
      06-29-2011, 02:17 PM   #28
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
No harm to your car. LL01 have higher TBN to combat additional acids created by higher sulfur laden US fuel and you don't have a diesel. US gas can have more sulphur when compared to ULSD
r
      07-01-2011, 12:33 PM   #29
ALL4_3SERIES
So can I keep using LL-01 without any issues? Or should I switch to LL-04 for the time being?
      07-01-2011, 04:13 PM   #30
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
I would use LL04 in europe to keep intake deposits down to a minimum.
      07-01-2011, 11:02 PM   #31
Bimmer37
Drives: e90 335i
niice!
      07-13-2011, 11:04 PM   #32
Glim
21
Drives: 2006 330i & 2013 X5 35i
In Canada, keep an eye on the Canadian tire flyers, the German Castrol 0-30 goes on sale quarterly for $7.49 per lt.
      09-17-2011, 11:56 AM   #33
altheg02
Drives: 3 series
I looked for Castrol syntec and my local store carried the EDGE with SPT 5W-40 which the label says if for BMW. Is this a new formula or just renaming? I hope I used the right oil.
      09-21-2011, 12:46 AM   #34
Blue Streak
Gunny
Blue Streak's Avatar
Drives: '07 E90 335i 6MT, 2016 F10 535
2007 E90 335i  [9.00]
It's the same. They just changed the name recently. I think it even says that on the bottles. If it's "LL01" approved, you're good.
2007 E90 335i 6MT, ZSP, Nav, PDC, CA, Montego Blue, Terra Dakota leather, CDV, clutch-stop, E46 M Shift Knob, Logic HVI, JB4 PnP, MS 3" downpipes, Koni Yellow adjustable sport shocks, RE 12mm(f)/BMS 15mm(r) spacers, Blacklines, LUX 5.0 LED halo ring lights, DAEOS (Vista) harness, GP Thunder 7500k fogs, 35% sides-20% rear tint, matt black kidney grill, matt black 335i trunk badge
      09-21-2011, 06:53 AM   #35
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Castrol consolidated their naming conventions just a few months ago. The only LL01 sold outside the dealerships in the US is their 0w-30. It Castrol Edge with Syntec. The 5w40 you speak about used to be a LL98 IIRC.
      09-23-2011, 03:16 PM   #36
USAF Rick
USAF Rick's Avatar
Drives: Montego Blue 08 335i e92
K I have a question that I havent really found here yet. With disregards to the warranty and BMW approved oil, what kind of oil do you guys think will be better than the recommended stuff? Stuff like redline? royal purple? I have an 08 335i and my warranty is over so I want to start doing my own thing. I know redline oils are not cheap, but are they worth it??
      09-23-2011, 03:19 PM   #37
tibra1
127
Drives: 2011 ZCP M3 - 2007 335i crashd
Not found yet??..
This question has been asked more than any other question in the history of all questions ever asked in the universe..EVER!!
      11-13-2011, 12:44 AM   #38
Glim
21
I run 7500 mi intervals with bertolli 0w-30 olive oil.
cjack29.50
      11-13-2011, 12:08 PM   #39
Tom K.
Tom K.'s Avatar
Drives: '07 328iT, '13 Boxster
Virgin or Extra Virgin?
Tom
      11-13-2011, 01:30 PM   #40
Glim
21
Tom
Virgin
It makes the car smell and taste better than extra virgin
      11-15-2011, 11:09 AM   #41
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
First one has to define "better". In a basic sense all LL01 oils of the same grade will reform the same over the long haul under designed operational parameters of the vehicle. Outside of that people are really guessing based upon the fact their engine still runs on X. Not very scientific nor reliable.
      11-15-2011, 11:46 AM   #42
psre08
Drives: 330i E90 & 330Ci E46
I tried a bunch of different types and none of them were any good on either my E46 or my E90. This summer I just switched to the BMW oil from the dealer. The E90 runs fine because it's newer, so time will tell. But the E46 is a new car, the annoying pre-ignition rattle is gone and it consumes less oil than before. I'm just not going to bother anymore with constantly trying something new.
      11-16-2011, 10:36 AM   #43
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
I know what you mean. IMO our engines run well on Castrol oils and I just wish we had more Castrol products to choose from such as a 0-40w.
      11-26-2011, 09:52 PM   #44
zshopa
Driver
Drives: 2006 330XI
Take a look at Castrol 5w-40 it states on the label that it is designed for bmws. It also meets all certifications for Castrol 0W-30. If you go by certification you would think that Castrol 5w-40 is the same as Castro's 0w-30. However, Castrol's website shows that their 5w-40 is NOT for bmws that require LL01 ( see link, page 2) [http://www.castrol.com/liveassets/bp...syntec_usa.pdf This LL01 cert must mean something. Why risk using royal purple or amsoil or any other oil without that LL-01 certification? Castorl 0W-30 and Mobil 1 0-40 have that certification. The complete list can be found on BMW's website http://www.bmwusa.com/Standard/Conte...ngineOils.aspx
very helpful links
thank you,
