04-23-2014, 10:23 AM | #6360 |
General
10449
Rep 40,810
Strange...it should have reset. Did you make checkboxes at all functions or just the typical 4?
04-23-2014, 10:24 AM | #6361 |
General
10449
Rep 40,810
PM sent.
04-23-2014, 11:14 AM | #6362 |
Rep 28
Only the typical 4. Anyway I am going to downgrade the firmware and see whether I can get back bmw online and internet. And will try to change the area code again.
04-23-2014, 11:14 AM | #6363 | |
Rep 122
Drives: F30 320D Sport
Garage List 2006 325iA E90 Sedan [0.00]
1999 320i E46 Sedan [0.00] 1991 318i E36 Sedan [0.00] 2012 320D F30 Sport ... [0.00] |
NBT plays them all. |
04-23-2014, 12:17 PM | #6364 |
General
10449
Rep 40,810
Hmm, so maybe all check-boxes are needed.
04-23-2014, 04:08 PM | #6366 |
General
10449
Rep 40,810
PM sent.
04-23-2014, 04:23 PM | #6367 |
Rep 11
Thanks a lot,Shawn....
As I understand I need to change zeitkriterium to 1403 to get all updates from the new firmware,right? Last edited by milest; 04-23-2014 at 04:37 PM.. |
04-23-2014, 05:14 PM | #6368 | |
General
10449
Rep 40,810
Assuming you have an ECU that has been flashed with new firmware, the update could be seen:
04-23-2014, 08:42 PM | #6370 |
65
Rep 72
Drives: 08 M Coupe;14 M6;17 X6M;18 X5M
Garage List 2021 BMW X6 M50 [0.00]
2018 Porsche 911 GT3 [0.00] 2015 BMW i8 [0.00] 2008 BMW M Coupe [0.00] 2017 Porsche 911 Tu ... [0.00] 1986 Porsche 911 Sl ... [0.00] 2021 BMW Alpina XB7 [0.00] |
Enable Park Assistant with Driver Assistant package and X-Drive
In the 5, 6, and 7 series cars with Driver Assistant packages, it also includes Park Assistant (where the car parallel parks itself). For the cars that also have X-Drive this feature is not included with the DA package. Wonder if it would be possible to code this option to show up in the parking menu?
04-23-2014, 08:44 PM | #6371 |
General
10449
Rep 40,810
PM sent.
04-23-2014, 08:47 PM | #6372 | |
General
10449
Rep 40,810
04-23-2014, 10:01 PM | #6373 |
65
Rep 72
04-23-2014, 10:13 PM | #6374 | ||
General
10449
Rep 40,810
It is no different than adding EBT as explained here, except you are adding 5DP instead of 6NS: Quote:
04-24-2014, 03:18 AM | #6375 | |
Rep 11
I just can't understand why I need "Immediately with original FA and VO coding" to see any upgrade. Isn't it already done when service upgrades the car to the new firmware? Thanks in advance, |
04-24-2014, 04:11 AM | #6376 |
General
10449
Rep 40,810
Yes. I didn't say it was you that had to VO Code it. After ISTA/P flashes the ECU, it is then encodes it according to FA. So, it is VO Coded as I wrote, but by the dealer.
04-24-2014, 01:58 PM | #6378 |
56
Rep 286
So shawn, When they upgrade the ISTEP on the older cars, they use a common firmware for all hardware variances and depending on the FA/Build Date, portion of the firmware gets enabled depending on this? Is that correct?
04-24-2014, 02:18 PM | #6379 |
General
10449
Rep 40,810
The ECU will get the highest firmware it can support, which may be lower than a newer version of the same ECU. But no matter which firmware it gets, the subsequent individual FDL codings carried out during VO Coding are dependent on the FA Date.
