10-15-2014, 09:09 AM | #7437 |
General
10449
Rep 40,810
PM sent.
10-15-2014, 09:39 AM | #7438 | |
Rep 1,573
2015i Cadillac Escalade ESV
10-15-2014, 09:47 AM | #7439 |
187
Rep 231
Thanks! I'm downloading 53.5 right now and will keep both versions on my computer just in case. I got a weird Java message last night so I will try the newer version this morning to see if it helps.
10-15-2014, 02:15 PM | #7440 |
Rep 1
Coding BMW F30
Hi Shawnsheridan,
I am new to the forum and i would like to coding my BMW F30 but i need the links of download: - E-Sys, Datafiles, PSdZData and Token I have Enet cable yet. Thanks and Regards!! |
10-15-2014, 02:19 PM | #7441 |
General
10449
Rep 40,810
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 10-15-2014 at 10:04 PM.. |
10-15-2014, 02:48 PM | #7442 | |
Rep 30
Is this necessary for flashing the EGS module or just for the HU_???, KOMBI & HUD modules? I have an Automatic Charger from Halfords (http://www.halfords.com/wcsstore/Hal...log/181750.jpg) which is a much lower rating, is this not good enough? Thanks |
10-15-2014, 03:16 PM | #7443 | |
General
10449
Rep 40,810
BMW Spec is for 50 Amp minimum, and using something less is risky. It may work, or it could brick ECU. I do not know. I know people too that just jump car to another running car, and had no issues.
10-15-2014, 03:23 PM | #7444 | |
Rep 30
So as far as your are aware this is the same flash procedure for any module? |
10-15-2014, 03:32 PM | #7445 |
General
10449
Rep 40,810
Yes, always the same. ECU not matter.
10-16-2014, 02:23 AM | #7446 | |
Rep 1,772
10-16-2014, 01:37 PM | #7448 |
General
10449
Rep 40,810
PM sent.
10-17-2014, 10:00 AM | #7450 |
Rep 2
hi Shawn
I have a M235 F22, i remember i had a "close half window function for easy entry", but now i lost it after i retrofit NBT in a local garage, do you know what tools i can code it back? Could you please send me a link for the coding software ? Thank you very much |
10-17-2014, 10:16 AM | #7451 | |
General
10449
Rep 40,810
10-17-2014, 10:18 AM | #7452 |
General
10449
Rep 40,810
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 10-17-2014 at 11:40 AM.. |
10-17-2014, 03:04 PM | #7453 | |
83
Rep 187
3060 LceMaster, 1C FOLLOWMEHOME_VIA_FFB nicht aktiv > aktiv" I will try this soon and let the results know.. |
10-18-2014, 01:55 PM | #7454 |
Rep 50
was trying to recode car to ECE, by changing typeshlussen parameter from US to ECE (3A57->3A55). The i recoded the whole car except ACSM.
After the coding HU_CIC radio is completly silenced. I can hear CD, can hear people when I call them with bluetooth, but the radio is muted. What may cause this problem ? When I code HU_CIC back to US the radio play. Is there a FSC code which after changes US->ECE is no longer valid and blocks radio reception? Rheingold reports for CIC fault code: |
10-18-2014, 01:57 PM | #7455 |
General
10449
Rep 40,810
No. There is FSC Code only for SDARS, which is Satellite Radio (XM/Sirius).
10-18-2014, 01:59 PM | #7456 |
Rep 50
10-18-2014, 02:01 PM | #7457 |
General
10449
Rep 40,810
No. Unless car has factory option 655 Satellite Radio, it does not get FSC Code, but Terrestrial Radio (AM/FM) still works without FSC Code.
10-18-2014, 02:48 PM | #7458 |
Rep 50
