10-28-2014, 12:00 PM | #7503 |
General
10447
Rep 40,805
If NBT => GYRO_INTERN = nicht_aktiv, then Gyro data is coming from ICM.
10-28-2014, 12:10 PM | #7504 |
Rep 12
Coding question - Eco Pro addl. miles display
Hi all, coding question for you...
I have coded my F30 to always start in Eco Pro mode (mainly for when my wife drives it ), but I would like to get rid of the blue "extra miles" display that shows up in the instrument cluster while in Eco Pro mode. Particularly since, on the F30, it blocks other items that could be displayed such as instant mileage, range, and so on (you have to cycle back to these using the BC button). In other modes (comfort, sport, etc), the display retains whatever I set it to, but every time I start the car it defaults back to the blue extra miles display (since it always starts in Eco Pro mode). Is there any way to change or disable this, via coding or otherwise? Many thanks for any ideas/comments. |
10-28-2014, 10:54 PM | #7505 |
Rep 12
Coding question - Eco Pro addl. miles display (follow-up)
Never mind my previous post... after a bit of trial and error, I think I found what I was looking for:
KOMBI > 300C > ECO_RW_DIGITAL_ENABLE – change to NICHT_AKTIV This appears to disable the blue "extra range display" in Eco Pro mode, for anyone who is interested in doing the same... |
llebnave6.50 |
10-29-2014, 02:21 PM | #7506 |
Rep 56
Links please?
Hi, Shawn!
Can you sent me in PM links for the latest versions of E-Sys and PSdZdata? For 2013 328i. Also looking for the best place to get the cable.. Thanks |
10-29-2014, 02:37 PM | #7507 |
Car OCD
263
Rep 595
Drives: 2017 EBII F36 430d M Sport
Another request for the download link, Shawn. I can see we keep you quite busy!
2014 F30 335i in case the link is specific to a type of car. Thanks A LOT in advance! |
10-29-2014, 04:48 PM | #7509 | |||
General
10447
Rep 40,805
http://enetcables.com/
10-29-2014, 05:41 PM | #7510 |
52
Rep 389
Hi Shawn
Can kindly send me the link to the latest Esys and Esys lite and psdzdata . Using token master if that makes a difference Thanks
10-29-2014, 07:22 PM | #7511 |
General
10447
Rep 40,805
PM sent.
10-30-2014, 08:12 AM | #7513 |
Rep 13
Hello,
I received my cable today, running E-Sys with token etc. I followed the backup sugestion (on the first page of this topic) and no problem, backup done! Then I try follow the PDF guide: E-Sys - How to change FA in F-series car.pdf And on this PDF, STEP 3 say: - "3. Go to expert mode > coding. Click read under vehicle order to read FA from car. Click edit. " Well, the FA was readed but the EDIT button is disabled. So I stop, disconnected from car, shutdown everything start over and same thing: Edit button disabled. Any advice? |
10-30-2014, 08:19 AM | #7514 | |
General
10447
Rep 40,805
10-30-2014, 08:20 AM | #7515 |
Rep 13
10-30-2014, 10:13 AM | #7516 | |
Rep 13
All right, I try again with your instruction and work fine. First code: enable enhanced bluetooth on F30, woking! Thank again for all support you give me: send me the software, the contact with Kristoff to purchase the token and all instructions! |
10-30-2014, 11:26 AM | #7517 |
Rep 43
Dear frog man i need your help
Good morning dear frogman. I have recently purchased the 2014 f30 328i m sport with non sport automatic and I hate the way it shifts and I was wondering if I could get the SAT sport automatic transmission coded instead. I live in orange county and based on what I see here you are the genius when it comes to coding. I would like to pay you for your services whatever amount you like to get the car coded to SAT . this is the only mod I care and need. if you can help me out plz contact me at 949 412 1521 and I will come to you. again thanks for all your help and looking forward to hearing from you.
10-30-2014, 12:28 PM | #7518 | |
Rep 1,892
10-30-2014, 04:22 PM | #7519 |
77
Rep 182
10-30-2014, 05:16 PM | #7520 |
General
10447
Rep 40,805
PM sent.
10-31-2014, 04:57 AM | #7522 |
Rep 13
Hello,
Yesterday after code A.S.S. (to memory last choice) and enhanced blue-tooth with A2DP, I try code this: Active High Beam Assistant MODIFY THE READ FA - Remove 5AP from the vehicle FA. VO CODE - FEM_BODY and FLA/KAFAS2 (whichever you are equipped with). AND Variable Light Distribution MODIFY THE READ FA - Remove 8S4 from the vehicle FA. VO CODE - FEM_BODY My car is a F30 year 2014 EUROPE, and have: S522A - xenon light S5ACA - high beam assistant Oh the PDF "F30_Coding_Reference_Guide_v1.5.pdf" says to activate these two modules my car need have "high beam assistant" - and my car have this. The issue: - On FA the 8S4 and 5AP dont exist; Maybe these codes are for USA market, and for Europe the codes different? Or car region dont matter? Thank. |
10-31-2014, 12:13 PM | #7523 | |
Rep 1,892
If you don't have those codes, then the feature should not be disabled in your car. If you have 522 and 5AC, you should have both features enabled already. if not, then there may be something else that is preventing it from working. Last edited by Frogman; 11-01-2014 at 12:31 PM.. |
