BMW M3 Forum (E90 E92)
      04-10-2022, 08:57 PM   #89
edwinm3
edwinm3's Avatar
Drives: F82
Im gonna be posting a new f8x complete kit for sale soon, less than 10 miles, all new take off, stay tuned
Appreciate 3
FMLYSDN1181.50
e92zero212.00
      06-13-2022, 01:19 PM   #90
Gouki
72
Drives: E92M3, E46M3, E63M6, SL55, 182
Again, thank you for this guide, I've been using this set up for a while now. One addition to recommend is that for the rear calipers which use the washers I'd replace all four BMW Disc Brake Caliper Bracket Mounting Bolts - 34206850536. I believe that using the 2x2mm flat washers might cause less bolt thread into the caliper and the existing bolts might come lose (mine did), even when the correct torque is applied (the torque for the rear brake caliper to wheel carrier is 65nm (47.9 ft-lbs)).
You will notice that the new bolts have a teal colored coating on the tip, likely threadlock.
DrFerry6728.50
e92zero212.00
      06-19-2022, 02:43 PM   #91
julzcagg
julzcagg's Avatar
Drives: 2011 e92 m3
I was told by BSI upgrades on Facebook that to install F8x M brakes would only require adapters that cost only 240$. Is this true? Another company VYS garage said I would need F8x hubs and rotors. BSI upgrades doesn't send large packages because their overseas in Poland, but if they did they say I just need the adapters with the calipers and I'd be good to go. I hate e9x calipers, for some reason I just need my calipers to be a nice shiny red or blue if that's what's easier to get at the time.
DrFerry6728.50
      06-19-2022, 03:10 PM   #92
julzcagg
julzcagg's Avatar
Drives: 2011 e92 m3
I would buy them as soon as you're ready to sell them. Just looking for the front brakes though. When you're ready to sell email me at julzcaggiano@gmail.com
DrFerry6728.50
      06-19-2022, 03:13 PM   #93
edwinm3
edwinm3's Avatar
Drives: F82
i'll let you know for sure but keep in mind that you'd have to buy the complete set as i unfortunately am not looking at splitting it thanks
Grigio Telesto M4, 6MT.
Coyote 5.0 F-150
991 GT3
      06-20-2022, 03:10 AM   #94
edwinm3
edwinm3's Avatar
Drives: F82
email sent
Coyote 5.0 F-150
991 GT3
      06-26-2022, 04:58 PM   #95
e92zero
Drives: 2011 E92 BW
For the folks that did this upgrade. Just wanted to confirm what was listed. So we are to use the e9x brake lines and not the f8x ones? A post a while back mention something about the thread on the hose is much longer and doesn't seat all the way? Thanks for any help/feedback.
      07-18-2022, 01:53 AM   #96
--Aramis--
124
Drives: M3
Interesting retrofit, if we can use F80 spindle, is someone have used the ones with additionnal camber parts 31217853639 and 31217853640 ?
      07-28-2022, 12:53 AM   #97
Raptorworks
Drives: bmw e92
I have nearly finished this on my e92 335i.. I have the m4 lines fitted but what is giving me grief atm is getting a suitable bracket to support the brake line and abs sensor wiring.
e92zero212.00
      07-28-2022, 08:33 AM   #98
tdott
Drives: M3
That is part of the issue using the M4 brake lines, they are longer and the grommets are not in the right place to re-use the e9x mounting bracket.
Since the ends of the brake lines are the same, I choose to use the E9x M3 Brake lines and they keep it OEM looking.
DrFerry6728.50
      07-28-2022, 08:34 AM   #99
tdott
Drives: M3
See above, better to use the E9x M3 lines imo. But both will work.
DrFerry6728.50
e92zero212.00
      07-28-2022, 08:41 AM   #100
tdott
Drives: M3
Based on the part# both are 32mm long, so I don't see that bolt helping, other than the thread locker, which you can add locktite when re-using the stock bolts. I don't remember exactly but I believe I checked and the stock bolt was fully engaged even with the washers because they normally protrude slightly, but if you want you can find a M12X1.5X34 suitable bolt to replace it which is 2mm longer than the 32mm ones.
      07-28-2022, 09:15 PM   #101
Raptorworks
Drives: bmw e92
I was thinking of getting 34302284733, which is the bracket to hold the lines to the upright.
      11-27-2022, 10:22 PM   #102
e92zero
Drives: 2011 E92 BW
I just finished this mod along with the F80 flange to use the M14 bolts. A couple of notes to share with the community:
Front is very straight forward once you splice the speed sensor wire. No complication at all
Rear was very troublesome:
* the handbrake support plate rub against the rear rotor and the outer lip needs to be trimmed off about 2 mm.
* using a 2mm washer will get the caliper to clear but it doesn't center the caliper on the rotor. I did some test fitting and it needs about 4mm washer. What I ended up doing was cutting my left over subframe bolts and enlarging the hole of those washers to clear the M12 bolts. They work perfectly. With this, I upgraded to use a different bolt that's longer. BMW Part number 07119906199. These are 10.9 grade (same as the original bolt) but longer. Tightened to 81 lb ft following the f8x m3 forum spec. Official spec is 30 Nm + 90 degree. Your call.
* the rear dust shield needs to be trimmed to not rub the rotor. Furthermore, it needs to be trimmed around the rear caliper ears as it won't clear
I honestly don't know if I would have attempted this if I had known the rear requires so much work and trimming. I really like the end result though. Good luck.
Here are some pictures for reference.
Appreciate 3
jvictormp881.00
DrFerry6728.50
CTMike262.00
      11-28-2022, 06:47 PM   #103
Erickuokwa
Erickuokwa's Avatar
489
Drives: E90 M3
May I ask what wheels are you running on the f8x brakes? I'm interested in this fitting for the future but only if I can clear my 18x10 +25 te37
      11-28-2022, 06:50 PM   #104
zcp312
///M
zcp312's Avatar
Drives: 2011 E90 M3 ZCP
Did you reach out to Tom directly to get the front f80 hubs? I don't see them listed on the core4 website. Curious which package you got off the site.
      11-29-2022, 10:00 AM   #105
e92zero
Drives: 2011 E92 BW
I assume the questions were towards me so I will try to answer them here.
Erickuokwa I am running the RAC 19 wheel. They are definitely closer then the oem brakes but it's good enough imho. It would probably clear some 18 but I wouldn't do it myself for the risk of wheel damage with trapped rocks. Whatever wheels you use, make sure the bolt hole clears the m14 bolts first. I had to enlarge mine with a reamer just a bit.
zcp312 I didn't reach out to Tom, I just sourced the parts myself. Good luck.
zcp31294.50
      12-24-2022, 02:54 PM   #106
gnx
Όλα ρόδες
gnx's Avatar
760
Drives: BMW
I understand that front abs sensors need to be handled with. Does that hold for the rear axle as well?
      12-26-2022, 08:57 PM   #107
gmx
Drives: VO 1M
bump, anyone know?
EDIT: I'm convinced those are parts for repair and aren't on any specific factory code (EDC, wheel models) nor CS/GTS editions. Half a degree at the hub rather than tower would be nice but yeah, unlikely it's going to be on a wrecker car unless it's already been repaired prior. BNIB from dealer/dealer parts network is going to be the only feasible option.
Bilstein CS | Rays ZE40 | Solid/spherical front / rear.
YouTube
      12-27-2022, 12:51 AM   #108
ornicar
ornicar's Avatar
136
Drives: 125i
bump, anyone know?
Hi, yes i use these spindles with -.5 º of négative cambers. I have bought it new. Feel free to ask if you have some questions.
      12-27-2022, 11:18 AM   #109
gnx
Όλα ρόδες
gnx's Avatar
760
Drives: BMW
What wheel bearings did you use? These?
https://www.leebmann24.de/radnabe-mi...207857506.html
OR the ones from the e92 M3?
https://www.leebmann24.de/schwenklag...212283435.html
      12-27-2022, 11:28 AM   #110
ornicar
ornicar's Avatar
136
Drives: 125i
Originally Posted by gnx View Post
I use the fist one for M2 M4 with M14x1.25 bolts
gnx759.50
m3post
