07-28-2020, 08:45 AM | #1 |
123
Rep 2,200
F80 rear subframe onto E92
anyone know if the M F8X subframe is compatible with e82/E9X ?
Looking at rear subframe upgrades for my E82 track car, E9X M will bolt right in, not sure if F8X will also bolt in. I realize the LSD is servo activated and that would have to be swapped with a regular clutch, but the arm improvements may be worth it. F8X complete dropouts are quite a bit cheaper than E9X complete subframes If not I plan on swapping in a E9X M rear subframe
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten.. 1974 2002, many various 3s. |
07-28-2020, 09:19 AM | #2 |
///M Powered for Life
11492
Rep 10,330
I don't know, however, working on both cars, their rear subframes seem pretty similar. There isn't a generational shift in the rear suspension and subframe between both gens
07-28-2020, 10:16 AM | #3 |
Rep 3,988
The mounting points don't look close to being the same.
