BMW M3 Forum (E90 E92)
      12-06-2020, 07:04 PM   #1
Redd
Drives: 2010 BMW E92 M3 Dakar Edition
Rear Spherical Bearings Conversion on Stock Arms
This info was collected from various sites and I am just posting it here for reference. Most of the engineering was done by vtl and fe1rx on 1addicts. You can read their full threads at the links below (very informative reads!):
vtl - https://www.1addicts.com/forums/show....php?t=1302309
fe1rx - https://www.1addicts.com/forums/show....php?t=1615006
The stock M3 suspension retains rubber bushes in various locations. These can be replaced with the parts listed in the table below to get a rear suspension with spherical bearings while using stock arms. This would be a good medium between stock suspension vs full race arms (SPL, Turner, etc) while still being relatively maintenance- and noise-free with sealed OEM-style bearings.
Parts Required
A. 1x BimmerWorld Rear Camber Arm Bearing Kit:
https://www.bimmerworld.com/BimmerWo...aring-Kit.html
B. 8x Lemforder 3067901 or Meyle 3147100005 bearings
C. 4x custom tapered washers
(Pic by vtl)
Item C (tapered washers) go in these locations (marked in red):
Item B, needs to be installed offset 3mm to allow space for Item C.
(Pic by vtl)
More details on installation of the guide rod and wishbone bearings with tapered washers here:
https://www.1addicts.com/forums/show...&postcount=293
Tapered washer designed by vtl:
Disclaimer - I'm posting this info for reference. I am still collecting all the parts required to do this conversion so I can't comment on complexity of the job. Will post details/reviews here as I do this mod later.
Edit 16Nov2023 - Custom tapered washers are available for sale from spikenipple . Email him at: ow_dont_pull_that@hotmail.com
Appreciate 7
Bartledoo2691.50
Biginboca3763.50
M43S7RO503.00
rhyary1563.00
Scharbag2622.00
      12-06-2020, 07:17 PM   #2
Redd
I have 8 sets of tapered washers available for sale here at USD30 per set of 4 washers.
https://www.m3post.com/forums/showthread.php?p=26987547
derbo3610.00
      12-06-2020, 10:20 PM   #3
M43S7RO
Drives: Jerez Black E92 M3
I'm pretty sure the guide rod and wishbone on the M3 uses spherical ball joints at inner and outer locations from factory, no need to replace these unless worn. If they are worn, prob easiest to just replace with oem arms which will have the spherical bushings pre-installed.
M3SQRD2164.00
      12-06-2020, 10:29 PM   #4
Redd
Nope they are not. I have a set of new guide rods and wishbones and they are rubber on the hub-side. Also you cannot press out the bearing on the subframe side as it is swaged into the arm itself. If that bearing is worn out you must replace the arm. That said, I have 130k kms on my car and still on original rear arms. The rubber is showing some cracks but the bearings are fine.
derbo3610.00
      12-06-2020, 10:57 PM   #5
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
Can confirm that is not true. The table on the top of this thread is correct.
IG:ruhrohz_m3
Journal: Link
E9x ZCP Suspension Info: Link
Track Chat Discord: https://discord.gg/VsKbTyqBVj
SF Bay Area: DM For coding services
      12-07-2020, 12:28 AM   #6
tlrid3r
just another M3
tlrid3r's Avatar
Drives: e92 M3
Where to purchase the bearings tho.
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
      12-07-2020, 12:58 AM   #7
Redd
Lemforders USD35/pc on eBay. Meyle USD18/pc on Fcpeuro.
      12-07-2020, 01:27 AM   #8
GORDON.M3
GORDON.M3's Avatar
1423
Drives: E92 M3 • F25 X3 M-Sport
Looks good, any idea if when replacing the bushings to bearings should I buy a new part to do it or modify the original ones on my car?
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor
DINAN | EVOSPORT | VAC | ARP | RD SPORT | NEEZ | EIBACH | CSF | IND | BILSTEIN | KLASSEN | BREMBO | ENDLESS | BBS | BPM SPORT | PROJECT MU | EVENTURI
      12-07-2020, 02:35 AM   #9
Redd
My arms were 130k kms old, so I got new OEM TRW arms and will be installing the bearings into those. If your car is low mileage I suppose you can re-use the original arms.
      12-07-2020, 08:29 AM   #10
M43S7RO
My apologies! Wow, washers went quick.
      12-07-2020, 09:05 AM   #11
Redd
I've put your name on waitlist in case any buyer drops out.
      12-07-2020, 03:39 PM   #12
atopa2002
atopa2002's Avatar
Drives: Z3M, 2013 e92 M3, F15 X5
wait list should in case some one drop out or you make more
      12-07-2020, 04:28 PM   #13
GORDON.M3
GORDON.M3's Avatar
1423
You're probably right, I'll end up buying a new set of TRW arms.
I find it funny how we are swapping non-m bushings in an M car now. When all the other non-M guys are trying to swap in M3 stuff.
      12-07-2020, 06:48 PM   #14
Redd
In case someone drops out. I would have to order another 10 sets for a production run, but I doubt it will be done in time for Jan delivery.
      12-08-2020, 11:04 AM   #15
atopa2002
atopa2002's Avatar
Thanks ok , keep me in mind
To add to this I have done 1 and 2 in the table above using this bavauto tool
It made the job a walk in the park .
https://www.ecstuning.com/b-bav-auto-tools-parts/trailing-arm-bushing-tool-set/b8800101~bat/
      12-08-2020, 01:02 PM   #16
tdott
Drives: M3
I think that is a bad analogy, it is replacing a bushing with a Spherical bearing.
GORDON.M31422.50
      12-08-2020, 08:33 PM   #17
tsk94
tsk94's Avatar
1522
Drives: E92 M3, E82 128i, F82 M4, E36
Very cool. Thanks for posting!
Great option for those who haven't upgraded to full spherical rear arms and want the performance benefits but at a more reasonable price and maintains that 'stock' appearance when looking under the car.
CTMike262.00
      12-08-2020, 10:34 PM   #18
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
Lol the non-M guys also swap the M3 arms in and put this bearing in as stated in the 1 series posts up top. It appears they are the origin of the custom washers.
I like that we are replacing the rubber bushing with an OE Spherical bushing regardless if it is M or not.
IG:ruhrohz_m3
Journal: Link
      12-08-2020, 10:38 PM   #19
Redd
Yeah those 1er guys are pretty hardcore. Fe1rx went so far as to reverse engineer the M3 arms, machine his own arms, then stress test them to failure. That's passion right there.
///Mobbin1478.00
      12-09-2020, 02:19 PM   #20
///Mobbin
///Mobbin's Avatar
1478
Drives: m3
Redd thanks for sharing all of this, very cool!
Just when I thought I was done with my suspension setup
2021 Alfa Romeo Stelvio Quadrifoglio | 2.9L | Trofeo White Tri-Coat | 8-spd
      12-09-2020, 03:31 PM   #21
GORDON.M3
GORDON.M3's Avatar
1423
its never done.
///Mobbin1478.00
911r891.00
      12-09-2020, 06:16 PM   #22
Redd
its never done.
Haha I know right? One year ago I told myself there's nothing left to do on the M3. Famous last words.
m3post
