06-26-2023, 12:28 AM | #67 | |
Rep 5,506
Auto Detailing Enthusiast!
06-28-2023, 04:08 PM | #68 |
241
Rep 223
My Freaky Parts adapters combined with separately sourced Brembo (Megane 3 RS) calipers have worked great upto now.
2010 E90 M3
2013 F31 328i Touring M Performance |
06-30-2023, 01:37 PM | #69 |
62
Rep 145
I just wanted post. I did the 3 day Mvading the Dragon last weekend, and Freaky brake performed amazingly well. No hint of fade, nor did it thermally overload the rotor (blue color rotor syndrome). This is a very budget friendly upgrade for those who want balanced performance & aesthetics.
07-05-2023, 06:45 AM | #70 | |
241
Rep 223
2010 E90 M3
07-11-2023, 11:20 AM | #72 | |
Rep 3
In regards to torque settings, using the table below: https://www.m3post.com/forums/attach...1&d=1671659722 The hub to adaptors are M12 socket cap lubed into Aluminium. The caliper to adaptors are M14 socket cap lubed into Aluminium. Threadlock should be but grade so they don’t vibrate loose but not so permanent that you need to apply heat to remove the bolts in the future. We don’t specify a brand or colour as there’s several versions available, not all available in all regions we sell to. |
12-12-2023, 11:32 AM | #73 |
96
Rep 243
Yeah I am definitely going to purchase this kit.
How much easier is it to swap pads after a track day? That alone is motivation for me to buy. I am lazy haha
-Thumbie
2011 Jerez E90 M3 6-speed Competition Package |
12-12-2023, 12:49 PM | #74 |
Rep 5,550
Issue with kits like these that add fixed calipers with 4 or 6 pistons is that they are paired with OEM sized rotors which typically have insufficient thermal rotor mass for heavy track use. This is compared to a full brake kit that comes with larger and thicker rotors + 4/6 fixed piston calipers with much higher thermal mass capacity.
TboneS541043.00 |
12-12-2023, 03:23 PM | #75 | |
Rep 5,506
The ones that do fit behind stock 18" wheels have the same size or slightly smaller or larger (+/- 10mm) rotors. For example, Stoptech brakes uses 355x35 rotors (stock is 360x30) with 4/6 piston calipers - nearly the same size and heat capacity as stock rotors. A lot of people run the Stoptech without issues. Freaky brakes is basically the same set up with Brembo calipers. So if you are looking for a set up for light weight 18" wheels, the stock rotor is as large a rotor that can fit.
12-12-2023, 03:47 PM | #76 | |
Rep 5,550
12-12-2023, 03:55 PM | #77 | |
Rep 5,506
I have been tracking on the stock M3 brake calipers and rotors for the past 12 years and 50+ track days and have not had any issues. With normal 15-20min track sessions, the brakes never fade. This is even at hard braking tracks like Laguna Seca where you need to slam the brakes from 120mph to 30mph repeatedly. You just need to run aggressive pads and track brake fluid. The larger 4 piston Brembos adds more heat capacity and much better brake pedal modulation so it takes the stock rotors to the next level without significant cost.
12-12-2023, 04:02 PM | #78 | |
Rep 5,550
Even though they don’t have 405 mm diameter rotors, the AP and PFC rotors have considerably more thermal capacity due to thicker disc faces, increased rotor diameter and high vane count to keep rotors cool a rotor cool by increased pumping ait thru the rotor. The stock F8x or e9x can’t compete even though rotor size is +/-10 mm diameter |
jritt@essex1026.00 |
12-12-2023, 04:07 PM | #79 | |
Rep 5,506
I'm no expert in rotor design, but the stock floating rotor is pretty good for a stock rotor. In terms of cost, it is significantly cheaper than any aftermarket rotor. Throw in FCP Euro's lifetime warranty, I've saved myself thousands of dollars in rotors over the years. You have to remember that this caliper upgrade is a cost effective way to increase the performance of the stock brakes. This upgrade is less than $1000. If someone wants to sell me a new AP big brake kit for less than $1000, you bet I'd buy it!
12-12-2023, 04:11 PM | #80 | |
Rep 5,550
is the use of stock rotors which limits overall performance. The cast “floating pin” on the e9x blocks most of the rotor vane openings. F8x rotor design has maximized flow into the rotor vanes so it’s definitely an improvement over the e9x rotor |
12-12-2023, 04:21 PM | #81 | |
Rep 5,506
12-28-2023, 04:35 PM | #83 | |
96
Rep 243
One another page where you can buy only the brackets, they say you just need calipers from a Renaultsport Megane Mk3 275 Cup See if PMU makes pads for a Renaultsport Megane mk3 275 Cup i guess. Seems like that is the vehicle to search for.
-Thumbie
12-30-2023, 06:08 AM | #84 |
241
Rep 223
The Freaky Parts adapters uses calipers and pads from the Renault Megane Mk3 RS. However they no longer seem to sell the adapters separately but only it as a kit.
https://freakyparts.co.uk/collection...-big-brake-kit Same caliper here: https://moto-dynamic.com/brake-calip...-rs,3,184,6167 Multiple brake pad options are available for these calipers.
2010 E90 M3
Thumbie95.50 |
12-30-2023, 11:09 AM | #85 |
Rep 5,550
So they also offer a caliper bracket that allows the Brembo caliper to align with F8x 380 mm F brake rotor? The F8x F caliper floating pin design is far superior to the E9x rotor design. Brembo + F8x F (and R if available) rotor is definitely an improvement in track braking performance.
12-30-2023, 11:47 AM | #86 | |
Rep 5,506
If you’re looking to install F80 brakes, the whole front set up bolts on… you just need the f80 front spindles. Then the f80 rotors and calipers fit. Of course a f80 brake conversion will cost more than just replacing calipers.
12-30-2023, 11:53 AM | #87 | |
Rep 5,550
12-30-2023, 12:07 PM | #88 | |
Rep 5,506
The Megane RS calipers these use are designed to work with the 355 rotor on that car and so they fit good on a 360 behind 18” wheels. It isn’t designed to work with a 380 rotor. I’m not a fan of adapting calipers from other cars as it changes a lot of things such as brake bias, wheel clearance etc. A brake kit designed for a car is usually always better. I.e. even though they use the same calipers on every application, Stoptech uses different brake piston sizes on every application to match the stock system. But this budget option works good and has no drawbacks. I am surprised it works so well.
