BMW M3 Forum (E90 E92)
      11-22-2023, 10:15 PM   #1
hson10
hson10's Avatar
Drives: '21 A90 Supra 3.0, '11 E92 M3C
2017 BMW M2  [0.00]
Rear Shock Mounts for ST XTA Coilovers
Need some help with looking for the correct rear shock mounts for ST XTA coilovers. My car has OEM EDC so I got the coilover part number that would be compatible for EDC-equipped cars (but I will leave them unplugged).
Do I purchase a new OEM EDC rear shock mount kit (i.e., something like this: https://www.turnermotorsport.com/p-1...SABEgLQifD_BwE)
or go with aftermarket mounts (I saw some folks recommending Monroe, but I think they don't make a 14mm ID one)? Car has around 115k mi so it will definitely need a refresh on RSBs.
The main thing I'm confused on is that it looks like there is a 10mm/12mm/14mm option for rear struts, so wondering if anybody who has ST XTAs / aftermarket EDC-compatible coilover kits purchased a new EDC rear shock mount kit, and if so, whether they went with 12 or 14mm?
I have done a ton of searching on this forum as well as on E9x owners on facebook and couldn't find a definitive answer on which rear shock mount I needed. Any help would be very much appreciated!
Thanks in advance
2021 A90 Supra 3.0 Nitro Yellow, 2011 E92 M3 Comp Jerez Black
Instagram @hans.device
      11-25-2023, 04:07 PM   #2
Redd
Drives: 2010 BMW E92 M3 Dakar Edition
Rear strut mounts are 10mm for non-EDC and 12mm for EDC. I'm not aware of 14mm RSM. I just installed my TracTive a little while back and they are definitely 10mm or 12mm.
If the ST coilovers are direct replacement for non-EDC dampers then get the 10mm ones. Even if you made a mistake you can go to a machine shop and get the metal sleeve bored out to 12mm.
Monroe does make a 10mm one. I would recommend just going Powerflex Black and not ever think about them again. Zero impact to NVH.
      12-09-2023, 03:38 PM   #3
M3SQRD
M3SQRD's Avatar
2164
Most aftermarket rear dampers use a 12 mm shaft OD. BTW, I’d also recommend Power Flex black RSMs - no increase in NVH.
      03-06-2024, 09:49 PM   #4
fengrr
Drives: E90 M3
These only for the non-edc 10mm right?
      03-06-2024, 11:11 PM   #5
M3SQRD
M3SQRD's Avatar
2164
I think you can get non-edc 10 mm and 12 mm. I haven’t checked in a while but I’d be surprised if they dropped a product. Dinan has RSM for edc.
m3post
