BMW M3 Forum (E90 E92)
BPM
      05-29-2020, 11:50 AM   #89
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
Originally Posted by ppatel14 View Post
So FCP Euro now stocks DS2500 for the front and rear and I'm thinking about trying them for the track using stock rotors/calipers with upgraded SS lines, brake fluid and NT01s on 18x10s. Would this be a worthwhile path given the warranty and lowering consumable costs? I'll prob track upwards of 6 events a year.
worse comes to worse, you send in toasted rotors/pads back to FCP and get a new set for street if it doesn't work out?
I'm going to offload a set of PFC08s for stock calipers soon.
IG:ruhrohz_m3
Journal: Link
E9x ZCP Suspension Info: Link
Track Chat Discord: https://discord.gg/VsKbTyqBVj
SF Bay Area: DM For coding services
      06-03-2020, 03:05 PM   #90
Rassilon
85
Drives: 2011 e92 m3
I had a very good experience with ds2500 as a dual purpose pad. It does squeaky every now and then on the street but it can handle the heat on track.
      06-05-2020, 08:53 AM   #91
jritt@essex
jritt@essex's Avatar
Drives: e90 335i, NSX, 997.2, 987.1
What tracks are you running? On an easy braking track like Roebling Road or Willow Springs Int'l you'd likely be fine. If you're talking Watkins Glen or Road America, definitely not. They'd burn up very quickly with NT01's.
      06-05-2020, 02:03 PM   #92
ppatel14
ppatel14's Avatar
Drives: 13' E92 AW ZCP 6MT
I'm based in Atlanta so typical tracks I frequent are Road Atlanta, Atlanta Motorsports Park, and Barber.
2013 E92 ZCP /// Alpine stage 2 tune, Bomiz Race X-Pipe, ARC-8 wheels, Vorshlag camber plates, Wheel studs, TMS spacers F15mm/R12.5mm, Stoptech SS lines, BW brass caliper guide
      01-06-2024, 04:18 PM   #93
Assimilator1
Assimilator1's Avatar
594
Drives: BMW M3 e92 08 & 330d e90 10
2010 BMW 330d  [8.00]
2008 BMW M3  [0.00]
Did you get the DS 2500s?
I fitted them to mine several months ago, but have only done 1 (cold, 5-10C) track day on them so far, no problems there.
They've been great on the road so far, with just that cold 5C day in November giving any issues, where the 1st couple of presses needed quite a bit of effort!
      01-06-2024, 04:58 PM   #94
M3SQRD
M3SQRD's Avatar
2166
PFC 11 and 08 compounds for track. 08 compound is more of an endurance compound. 11 has more initial bite, higher temp rating, higher friction and higher wear rate. I prefer the 11 over the 08.
Carbotech XP12 is a great track pad and works well with their 1521 street compound. XP20 outperforms the XP12 in all categories but may over power the tires without aero.
DrFerry6730.00
      01-06-2024, 05:05 PM   #95
t_win
Drives: e90 M3
Once you start doing summer track days, you'll find the DS2500 fading pretty quickly. I've only done wet track days with DS2500 on my M3, but on my turbo FRS that I track I run XP12 front and XP10 rears. Previously I ran XP8 front and rear on that car and noticed that I would get fade near the end of each session. With a much heavier car, you will need at least an XP10 for warmer track days.
Though it also depends how much brake you are using.
      01-08-2024, 01:37 PM   #96
Assimilator1
594
2008 BMW M3  [0.00]
Oh well, as long as they last better than the stock pads, that'll be fine by me.
Btw, thanks for the replies guys, but you didn't say what make pads you were talking about.
      01-17-2024, 02:17 PM   #97
Thumbie
Thumbie's Avatar
96
Drives: 2011 M3/4/6
This is definitely an important point for all to consider.
-Thumbie
2011 Jerez E90 M3 6-speed Competition Package
m3post
