BMW M3 Forum (E90 E92)
European Auto Source (EAS)
      09-29-2020, 09:29 PM   #221
GTBrandon
GTBrandon's Avatar
Drives: 13' M3 Competition
Going in for an alignment tomorrow with ZCP suspension and camber pins pulled. I have 19x10in square set up, 265 right now but 275/285 once these wear out.
Will be tracking the car a few times a year, and DD the rest of the year. Thinking 1.6F, 1.9R with 1/16th toe in on both F/R. Does that sound right? Seeing some people say toe 0 vs toe in. Going for max camber with stock ZCP suspension with pins pulled, just not sure if there is a too much camber for the rear, or what to do on toe?
      10-07-2020, 08:49 AM   #222
nishfish87
38
Drives: E92 M3, F85 X5M
Looking at getting alignment done after new LCA, FCA, and BC coils. I drive the car as a weekend spirit driving and was thinking the following to provide the shop:
Front
Camber -2.5 deg
Toe 0.08 deg / 1/16"
Total Toe 0.20 deg
Rear
Camber -2.0 deg
Toe 0.20 deg
Total Toe 0.3 - 0.4 deg
Does this look right?
Wheels: Titan7 TS5 Front 18x10 +25 275/35 Rear 18x10.5 +25 285/35
      10-07-2020, 08:55 AM   #223
DRLane
DRLane's Avatar
Drives: E92 M3
2008 m3  [6.63]
Front
Camber -2.5 deg
Total Toe 0.20 deg
Rear
Camber -2.0 deg
Toe 0.20 deg
For just driving around town and canyon runs. Keep the front toe neutral (zero out). Run the toe in at the rear.
You don't need any help with turn in on the streets which is the reasoning for toe out on the front. You'll just chew up your tires faster.
Not a Doctor, those are just my initials.
      03-15-2021, 07:55 PM   #224
jvictormp
jvictormp's Avatar
Brazil
881
Drives: 2008 M3 E92 6MT
Hi guys.
I just installed the solid subframe bushings. You think I should keep the rear toe in or should I zero it?
      03-27-2021, 11:27 AM   #225
jasonturbo
60
Drives: E90 M3, 997.1 GT3 RS, DC2R
Originally Posted by jvictormp View Post
Hi guys.
I would tell you to keep a small amount of toe-in... much better braking stability.
jvictormp881.00
      08-03-2021, 08:45 AM   #226
Kevin Bird
47
Drives: BMW M3 GT4
GT4 Settings
I thought this might be of interest
4_0000_1_M3GT4-Setup-Zandvoort_Info_FS_0409_KC-1.pdf
Appreciate 5
      01-10-2022, 08:53 AM   #227
its55
2008 BMW E92 M3
281
Drives: BMW M3
Stock Tires & Suspension
Camber - LF -1.2 RF -1.3
Toe - LF 0.09 RF 0.08
Camber - LR -1.6, RR -1.6
Toe - LR 0.07, RR 0.05
Thrust Angle - 0.01
      10-11-2022, 03:06 PM   #228
TboneS54
YNWA
TboneS54's Avatar
Drives: 2004 M3 6spd & 2011 M3 DCT
Swift springs, pins pulled on stock mounts. Everything else stock.
Was able to get down to -2 camber all around.
Neutral toe up front, about 10-12 minutes toe in each side in the rear for stability.
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54
      10-12-2022, 12:39 AM   #229
tigermack
OPN DIFF
tigermack's Avatar
Hong Kong
475
Drives: 10' E90 M3 6MT LB
2010 M3  [0.00]
1995 BMW e36 325i  [7.91]
2006 BMW e90 330i  [8.34]
-4 0 toe f
-2.5 1/8” toe in r
'10 LB E90 slicktop/speed cloth/6MT
ex. '06 330i 6MT & '10 n54 6MT Msport
Autocross vids https://www.youtube.com/user/tigermack
https://www.instagram.com/tigermack
jvictormp881.00
      12-13-2022, 11:37 AM   #230
jmeenach
Drives: E92 M3
Originally Posted by tigermack View Post
-4 0 toe f
-2.5 1/8” toe in r
That's a really aggressive front set up. Dedicated track car by chance?
      12-13-2022, 11:39 AM   #231
jmeenach
Drives: E92 M3
-2.5deg, 0 toe F
-2.2deg, 3/32" toe in R
      12-27-2022, 12:43 PM   #232
tigermack
OPN DIFF
tigermack's Avatar
Hong Kong
475
2010 M3  [0.00]
Mostly autocross.
      01-07-2023, 10:38 AM   #233
smokinjoe64
Naval Aviator
smokinjoe64's Avatar
Drives: 12 e92 M3 6MT
Post
Set-up: Bilstein B-16s w/EDC
e92 M3 - Interlagos Blue | Fox Red Extended |Carbon Leather
Performance Mods: Alpine Stage II E85; SuperSprint F1s; Cat-less Bomiz X-Pipe; aFe CAI; Bilstein B16s w/EDC; Brembo BBK; AutoSolutions SSK
      01-07-2023, 10:46 PM   #234
tlrid3r
just another M3
tlrid3r's Avatar
Drives: e92 M3
Attachment 2663937
This is interesting they measure ride height differently from front to rear.
Any one know how to convert minutes to degree for the front caster.
Thanks
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
      03-26-2023, 11:54 AM   #235
Sanchez14
Drives: TBD
Any recommendations on this set up? Just installed coilovers and taking it in this week for a solid alignment and maybe corner balancing too.
Car is mostly a weekend canyon car and 6-8 HPDE’s per year. My goal is better track dynamics, plus improved tread life on my track tires without putting too much additional wear on my street tires.
I’m thinking -2.5 front and -1.5 rear. 0 toe front and -.15 rear. Not sure on caster.
      03-29-2023, 12:55 PM   #236
jmeenach
Drives: E92 M3
I initially did the same thing but didn't get the contact patch in the rear that I was looking for, so I upped it to 2.2 or 2.3 degrees in the rear. I run r compound tires, so street wear isn't something I really worry about. My tires don't last long regardless!
If you primarily use this car as a canyon car and have that level of track days, I wouldn't personally be concerned with the street wear.
      03-29-2023, 03:16 PM   #237
TboneS54
YNWA
TboneS54's Avatar
Wear is more from toe than camber anyway. The only true way to know if the camber is the right amount is to analyze tire temp across. I agree with jmeenach to go up in the rear, at least to -2 if not a bit higher. Front might need more as well, but -2.5 is a fine starting point. A little tow in for the rear (10-12 minutes each side or about a 1/64th to a 1/32nd" each side). Up front is a bit of a matter of taste. Zero is best for tire wear, but can feel a bit wonderous. I like the feel of toe-out (on my e46, didn't bother with e90 daily), it's a bit snappier on turn in. Not much toe in or out, just a touch (less than rear) if you don't want zero.
      03-31-2023, 04:52 PM   #238
jmeenach
Drives: E92 M3
I agree a hint of front toe-out on an e46, but I wasn't a big fan on my e92. It was harder to control IMO than zero toe on high speed straights, especially at tracks like Willow Springs. I found zero toe to be the best blend of turn-in/stability.
TboneS541043.00
      02-26-2024, 12:53 PM   #239
Thumbie
Thumbie's Avatar
96
Drives: 2011 M3/4/6
Just did an HPDE at Thunderhill west with the below alignment. Car is on Ohlins R&T with camber plates. Otherwise stock on 280tw summer tires. I would call this spec "mildly aggressive street"?
Front:
-2.5 camber
7.5 caster (basically the most stock bolts will allow)
0 toe
Rear:
-2 camber
0 toe
Car handled great, very sharp turn-in, response and very easy to control. Tended to push a little in the corners but would oversteer a little when getting on the gas. (I'm also just an intermediate driver)
I do notice on the street the car will track the road more when you let go of the steering wheel. Very easy to control though. Also noticed a slight drop in feel when driving in a straight line, not in a bad way just different. Not sure if that's caused by the caster or not.
-Thumbie
2011 Jerez E90 M3 6-speed Competition Package
      04-04-2024, 01:04 PM   #240
jmeenach
Drives: E92 M3
Checking back in with updated specs. I've increased to an average of 1-2 track days per month, so I'm now at a point where I cycle tires out long before I overly wear the inner shoulders. Especially in the front with 0 toe, where to TBone's point, wear is actually less than you would expect from a high camber setup.
FWIW I run KW clubsport 2-way. 275/35r18 200TW tires on 18x10" wheels with 10mm front spacer to clear perch. Word to the wise - most wheels won't clear with a 5mm spacer, though many websites advertise using a 5mm spacer. Go with a shorty spring or buy a 10mm spacer to save yourself some fitment headaches. You'll also need more than 3' camber up front to avoid rubbing on the fender with a 10mm spacer (at least in my experience).
New alignment setup:
Front
-3.25 deg
0 toe
Rear
-2.7 deg
1/8" toe-in
I have a notebook that I keep with me to detail any "unsettling" moments, over/understeer, etc., which will allow me to tweak setup with my shop and develop individual suspension settings for each track I take the car to.
      04-04-2024, 06:27 PM   #241
TboneS54
YNWA
TboneS54's Avatar
I keep reading that e9x doesn't need as much neg camber as E46 did. Probably something to do with the front subframe or having a extra pair of control arms now.
jmeenach, how did you determine to go with -3.25? The correct way to take temps across the tire surface and go to the amount of neg camber that creates an even distribution of heat across the tire.
I wonder if street/dual duty cars need more than -3?
      04-05-2024, 11:01 AM   #242
Thumbie
Thumbie's Avatar
96
Drives: 2011 M3/4/6
good question, probably don't "need" that much if dual dudty. I think it Depends on which application you want it set up to perform better at, and what your definition is of a "happy medium". -3 up front is somewhat aggressive for the street but my friends who track their e90s regularly run close to -4 up front, and still commute in them a few times a week
I'm happy with -2.5 but on track I can tell a little more would be nice.
-Thumbie
m3post
