09-11-2019, 05:08 PM | #1 |
185
Rep 394
Reverse camera OEM style retrofit for $199 shipped - DIY Details
Hello,
I recently purchased a f30 328I Sportline without reverse camera. After doing some research i found a company that has a retrofit for $199. A bit skeptical but i gave it a go, as i have extremely tinted windows and could not see behind me. This is the kit: The kit took me about 3 hours to install, and i have to say, i am extrwemly happy. it comes with a reverse camera that clicks in by the hood latch, looks OEM as heck! UPDATE: Video of how the rear view camera works in daylight. Here is a video that shows how bright it is at night: The reverse camera works with the stock idrive, and also has dynamic parking lines when you move steering wheel. Here is the link: http://www.carnaviplayer.com/rearvie...-series-p-1222 If you do buy it make sure you use coupon code:free-shipping for 3 day free DHL shipping to USA. If anyone is interested, i can make a tutorial of it, but it was well worth it! ****BEFORE YOU BUYN READ THIS**** You have to select which version you have: CIC, NBT or EVO. **IF YOU HAVE CIC YOU WILL HAVE TO MANUALLY CHECK THE PINS TO SE IF ITS A 4PIN OR 6 PIN CONNECTOR.** Go on your main menu, and compare the red highlight, one is more red, the other is more orange. Both EVO version apply to just evo. For example, my car has a 6.5 inch screen and i had the NBT menu. so i chose the following: This is important, as the connector for the screen is different. HERE IS A VIDEO FROM CARNAVI SHOWING HOW TO REMOVE THE AIR VENTS AND CLIMATE CONTROL TO GET ACCESS TO THE MODULES: THIS VIDEO SHOWS THE ORDER AND PLACEMENT OF EACH CABLE. DISCLAIMER: DO NOT FORGET TO REMOVE THE FIBER OPTIC CABLES FROM YOUR ORIGINAL HARNESS AND INSTALL ON THE NEW HARNESS LIKE THIS: ***TROUBLESHOOTING*** If your guidelines are not centered, here is how to adjust alignment" Last edited by 330istocknot; 09-27-2019 at 11:35 AM.. |
9
09-12-2019, 01:25 PM | #2 |
Rep 842
Looks good but be aware:
If your car is Manual transmission, then this product is NOT compatible with your car. |
330istocknot184.50 |
09-12-2019, 02:00 PM | #3 |
Yoda of mods
1675
Rep 3,006
Drives: X5 RWD
Nice.
Current: 2020 Explorer ST (Agate Black Metallic), F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos |
09-12-2019, 05:31 PM | #4 | |
Rep 1,452
09-12-2019, 07:19 PM | #5 |
Rep 3,748
09-12-2019, 08:58 PM | #6 |
Rep 1,452
rudigrr21.00 AndrewC198910931.00 |
09-12-2019, 11:19 PM | #7 | |
185
Rep 394
The reverse camera has since them helped me out a lot. Rear view mirror is not useless all the time, just in extremely dark locations. |
Pauloxxi339.00 AndrewC198910931.00 |
09-13-2019, 07:37 AM | #9 |
Rep 1,827
Great find! I've been wanting the Bimmertech retrofit kit, but it was price prohibitive. Did install require any coding?
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
09-13-2019, 10:59 AM | #12 |
Rep 1,827
If you do a little research, you'll see that BMW actually didn't make backup cameras standard until 2018, because that's when a federal mandate that all new cars MUST have a backup camera went into effect. Until then, it was optional.
09-13-2019, 11:00 AM | #13 |
Rep 14
09-14-2019, 09:27 PM | #14 | |
119
Rep 191
09-14-2019, 11:18 PM | #17 |
Rep 1,452
It was part of the drivers assistant package on my 16.
09-16-2019, 11:39 AM | #18 |
185
Rep 394
No coding required, it was all plug and play. No error codes and it looks exactly like the retrofit from bimmertech or OEM, even the dynamic lines work the same.
09-16-2019, 11:53 AM | #19 |
Yoda of mods
1675
Rep 3,006
Drives: X5 RWD
Yes. You need to see if yours in 4 or 6 pin CIC.
09-16-2019, 01:18 PM | #21 |
119
Rep 191
