02-01-2020, 10:31 AM | #89 |
Connoisseur
236
Rep 336
Drives: 2016 F82 ZCP
Just received my retrofit harness from Marius for xenon to pre lci. Doesn't looks too bad at all. Hardest part will be taking off the bumper. Will post results in the coming months.
Instagram: @dmikucki
02-01-2020, 12:36 PM | #90 | |
Rep 6,732
I’ll need to get the harness as well for my Xenon to pre-LCI light setup if I pull the trigger. Thx |
04-04-2020, 09:40 PM | #93 |
Connoisseur
236
Rep 336
Went ahead and did my xenon to pre lci headlight install. Wiring harness and remote coding was done my Marius. Overall this was not difficult at all. The hardest part was figuring how to remove the wiring pins from the oem headlight harness and then lining up the new headlights perfectly. The wiring harness came with amazing instructions from Marius. Recommend him for all your wiring and coding needs!! Some pictures below! Let me know if anyone has any questions
SanchoDivine558.00 Sublimeside80.00 |
04-05-2020, 12:43 PM | #94 |
181
Rep 246
Nice work.
I'm glad, i had the pre-lCI full LED headlights. I did not remove the bumper completely, just a little bit loose and squeezed the LCI ones in. The LCI headlights make a big difference in appearance.
M4 F82, MG, stage 2+, ER catless DP, Akra, Armytrix, BMS intake, ER charge pipes, Ohlins R&T, GTS/CS hood, GTS flash, EDC CS, 763M CS rims, LCI taillights and LCI LED adaptive headlights
M5 F10, Singapore grey, stage 2 E92 335i RB upgrade turbo & FBO |
04-27-2020, 09:35 AM | #96 |
Rep 1,384
Apart from VO coding the 522 and 552, can anyone tell me what else needs coding?
I'm about to fit mine in the next few hours and would like to also enable the eurostyle anti dazzle (converted from non adaptive xenon to adaptive LED icons). thanks
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
04-28-2020, 05:57 PM | #97 |
Rep 1,384
Shout out to Marius, he's super patient and helped answer all of my questions, whilst also performing the coding (it's way more than just VO coding 552).
I went from pre-lci non adaptive xenons to adaptive lci icons
2015 435i - 401whp
06-18-2020, 02:15 AM | #98 | |
Rep 19
Would love to hear for you ! thanks |
06-18-2020, 05:36 AM | #99 | |
1800
Rep 3,064
You just need coding Thanks |
06-20-2020, 03:30 PM | #100 | |
Rep 1
06-20-2020, 03:46 PM | #101 |
Rep 6,732
06-20-2020, 04:22 PM | #102 | |
Rep 19
But the drivers side of my car (my car is RHD) which i dont think its possible unless i extended my wires , i am not sure if its was different from LHD car but even i try to pull the wire as much as possible but seems it just not long enough to get there. Is it ok to cut the wires and simply extend it to make the loom longer? Anyone tried before? |
06-20-2020, 04:24 PM | #103 |
Rep 19
06-20-2020, 07:10 PM | #104 | |
Rep 6,732
Yeah several posts down about cutting the zips but no mention about RH car. I guess worse case would be to extend those specific wires. I would solder and shrink wrap those wires. |
09-24-2020, 03:26 PM | #108 |
Rep 6,732
03-06-2021, 09:18 AM | #109 |
83
Rep 379
Hi ...
I have a 2016 f30 with LED headlights. will it be just plug and play to upgrade to adaptive LED? Understood there will be coding required. can someone please clarify. Thanks. |
