04-30-2017, 08:27 PM | #178 |
70
Rep 235
Anyone have a PDF of the BMW procedure that runs through the retrofit? I swear I saw it before but no luck finding it now. Would appreciate it if you could send it my way.
05-06-2017, 09:57 PM | #180 |
70
Rep 235
Hey guys. So finally got around to doing the retrofit, just did the rear brakes today and have a question. For any of you guys that did this on their 328i, did you need new hardware for the e-brakes? I initially put the adjuster screw on the smallest setting to make reinstall easy, and once I got the rotors on there I started adjusting/stretching the adjuster spring. I adjusted the driver's side to what seems to be the max it will extend to, and the ebrake is still not grabbing onto the rotor at all. I do see the new rear rotor hats are about 1cm wider than the old ones, maybe the e-brake hardware I have won't stretch out that much? Appreciate any input.
05-24-2017, 03:17 PM | #182 |
508
Rep 2,981
Drives: 2013 BMW F30 EBII
Did my install of M performance brakes this past weekend...Love the look of these...makes the entire car look better than the stock small calipers that came with my car.
Drives: 2011 Porsche 958, 1965 Chevy C10, 1988 Porsche 944 Sold:2010 e90 Montego Blue, 2013 F30 EBII, 2013 Tangerine Scream Ford Focus ST, 2006 Mini R50,2004 VW Touareg, 2012 Camaro Convertible, 2008 Porsche 911 Convertible, 2007 Corvette, 2004 BMW e64 convertible, 2000 Dodge Dakota, 1999 Ford F150, 1999 Porsche Boxster, 1999 Ferrari Modena, 1992 BMW e36, 1990 Nissan 240sx, 1979 Celica, 1974 Mustang II
My Build Thread |
08-16-2017, 06:46 AM | #183 |
Rep 16
So much nicer. Great addition!
Oy vey!
Will fix your keys for you at locksmiths leicester |
roll_the_dice508.00 |
08-16-2017, 09:16 AM | #184 |
508
Rep 2,981
Thanks! I love the look. Someone rolled down their window the other day at a traffic light and said...love your car and the brakes!
My Build Thread |
CJ4211566.50 |
10-02-2017, 08:46 PM | #185 | |
56
Rep 173
Installed M Performance Brakes on my F31 today! My biggest challenge was getting the lug studs off. Effing Sears had them well over 200 ft/lbs (I was lazy and didn't feel like putting on my new 398 Orbit Grey wheels last week).
All in all, it took me about 5 hours (1 hour just to remove lugs). It was a bit of a challenge getting the caliper bolts off all 4 corners. It seems like they come with quite a bit of Loctite from the factory. I let the bolts soak in PB Blaster for a bit, which helped. I bleed the system in the proper order twice, then used Reingold to activate the DSC bleed procedure to shake loose any additional air bubbles (there were some). I then VO coded SPBR to the HO-WORT folder, Using Serpent720 instructions. Quote:
06-03-2018, 10:43 PM | #187 |
136
Rep 357
10-06-2018, 11:28 PM | #188 |
24
Rep 68
Where have you seen the M Performance Brake Kit sold for under $2000.00 in the USA and what is the labor cost and hours to install at a BMW dealership.
10-06-2018, 11:43 PM | #189 |
24
Rep 68
F30 3 Series M Performance Brakes Installed
Where in the USA have you seen the M Performance Brake kit selling for under $2000.00 and what is the labor hours and charge for a BMW dealership to install.
10-07-2018, 06:30 PM | #190 | |
290
Rep 396
Drives: F87 M2C
My local dealership quoted me ~$700 after tax, depending on your location I would expect it to be cheaper.
Past: 2011 Acqua Minerale Blue Hyundai Genesis Coupe 3.8 Past: 2017 Alpine White 440i F32 Current: 2020 Long Beach Blue M2 Competition PC Build: 5950x/6900xt |
10-12-2018, 08:31 PM | #192 |
Yoda of mods
1678
Rep 3,007
Drives: X5 RWD
That's a damn good deal.
Current: 2020 Explorer ST (Agate Black Metallic) AWD, F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos |
10-12-2018, 08:37 PM | #193 |
56
Rep 173
10-21-2018, 01:08 PM | #194 |
42
Rep 126
11-15-2018, 02:38 PM | #195 |
13
Rep 220
hi everyone,
i have this kit and my brake pads are almost done. Can somebody tell me if they are just the regular pads or does this come with special pads? I've been through the entire booklets and cannot find any info on replacement parts. greatly appreciate any input. thanks! |
11-15-2018, 06:54 PM | #196 | |
56
Rep 173
Here are the part #'s for EBC Reds REDSTUFF EBC DP32130C- FRONT EBC DP32133C- REAR Here are the part #'s for OEM BMW Pads. 34-11-2-284-969 FRONT 34-21-2-284-989 REAR |
11-23-2018, 03:12 PM | #197 | |
19
Rep 153
Front:*https://www.amazon.com/gp/aw/d/B01LY...op_mb_pd_title Back:*https://www.amazon.com/gp/aw/d/B01CF...op_mb_pd_title The back was on sales for ~$30. After properly cleaning and lube all contact parts, for ~2 weeks of driving not a single noise. Stopping power is the same for me for day to day driving. But, I have read that ceramic pads are not good for track. I decided not to change rotors (they are above minimum) and I reused sensors. Not doing the pads break-in process either. So far so good. |
12-03-2018, 03:49 PM | #198 |
611
Rep 233
I'm looking to buy the M Brake upgrade from a BMW dealer on Ebay as well, but I have the Maintenance plan and I am wondering how this may affect that, and/or the warranty? Not sure my dealer will install customer supplied parts, even if from another BMW dealer, and if I get done somewhere else I see them trying to deny any warranty/maintenance claims if they arise, no?
