Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > E93 Combox microphone issue
      04-07-2024, 07:28 AM   #1
shtepa93
Drives: e93 320d
Hello,
I purchased a used E93 320d which has factory installed Combox Telematics. I noticed that when I connect my phone via bluetooth, microphone doesn't work (other people can't hear me speaking). I scanned errors with INPA, and got two errors A8EF and AA08, one in Media and one in ECall. Both errors indicate there is an open circuit with microphone1. I checked wiring and everything seemed to be ok (connectors and wires). Then I bought a new microphone, cleared the errors with INPA but that didn't fix the issue, those errors appeared again.
I decided to buy a used combox, with same part number as mine to see if my original combox is faulty. I swapped in the new(used) combox, and the microphone started to work. Actually everything worked fine without coding which was surprising. The next day I decided to code the new combox with my factory VO (ncsexpert), and set my VIN (tool32) just to be on the safe side. After coding my VO to combox and ecall, and also coding my vin, I got again same issue with my microphone as described from beginning of the post. It seems that coding somehow broke the microphone.
I would really appreciate if someone could help me here, because I'm getting desperate and I don't have anymore ideas what could I try to make this microphone work.
Here is my VO:
Code:
E93_#0311&LCD3%0475*DY31$1CA$1CB$1CD$205$216$230$248$2DF$320$387$423$428$430$431$441$459$481$493$494$4AE$4BY$4UT$502$508$521$522$534$540$548$563$5AK$606$612$615$616$633$676$698$6AA$6AB$6FL$6NF$6VC$760$7HE$7RS$7SN$801$851$879$8TL$8TN$9AA-A090+UEU5
Media FSWPSW
Code:
TYP_LENKUNG
	linkslenker
SPRACHE
	deutsch
BT_UFN
	wert_01
USED_MICROPHONES
	wert_01
PHONE_TYPE_JAPAN
	nicht_aktiv
RINGTONE
	ringtone_1
RSE_HIGH
	nicht_aktiv
TDA_CFG_CUST_MOBILE_USE_M
	aktiv
TDA_DEACTIVATE_STATUS_M
	nicht_aktiv
BT_OBJECT_PUSH
	nicht_aktiv
MICROPHONE_SENSITIVITY
	l4_mic
PB_DOWNLOAD_PRIORITY
	wert_03
INBAND_RINGING
	nicht_aktiv
CONFIG_INDEX
	config_index_6
DPAS_INDEX
	dpas_3
TESTCALL_FLAG_ENABLE
	nicht_aktiv
A2DP_AVRCP_EIN_AUS
	aktiv
AKD_SUPPORTED_POIS
	wert_25
API_EIN_AUS_MED
	aktiv
API_IPOD_ONE_WIRE
	aktiv
API_IPOD_TWO_WIRE_SERIEL
	aktiv
API_TWO_USB_M
	aktiv
AUDIO_NOTES_EIN_AUS
	nicht_aktiv
AUDIO_SOURCE_FILE
	file_1
AUDIO_VERSTAERKER
	wert_01
AVRCP_BROWSING_EIN_AUS
	nicht_aktiv
CALENDAR_EIN_AUS
	aktiv
CAR_TYPE_IPOD_LOGO
	bmw
CONTACT_NUMBERS_BCALL_M
	nicht_aktiv
CONTACT_NUMBERS_DEALER_M
	nicht_aktiv
CONTACT_NUMBERS_HOTLINE_M
	nicht_aktiv
CONTACTS_EIN_AUS
	aktiv
DATACOMM_CSIM
	aktiv
DATACOMM_INTERFACE
	mamac
DRM_CHIP_ENABLED
	aktiv
DUN_PROFILE_M
	aktiv
EMAIL_EIN_AUS
	aktiv
EXTERNAL_CALL_LISTS_M
	aktiv
FBLOCK_PHONEBOOK_EIN_AUS
	nicht_aktiv
GPS_FROM_MOST
	nicht_aktiv
GPS_POSITION_TIMEOUT
	wert_01
HEAD_BOOT_UP_TIMEOUT
	wert_15
HEAD_UNIT_MODEL
	cic_mid_rueko
HEATING_CONTROL_ENABLED
	aktiv
HORN_CONTROL_ENABLED
	nicht_aktiv
INCOMING_CALL_LIST_M
	aktiv
IP_ROUTER
	aktiv
LIGHT_CONTROL_ENABLED
	nicht_aktiv
M_SECURITY_MODE_AEH
	des_cbc
M_SECURITY_MODE_AEP
	aes_128
M_SECURITY_MODE_ASH
	des_cbc_mac
M_SECURITY_MODE_ASP
	hmac_sha_256
MAIN_BOARD_ALONE
	ecallboard_present
MED_SVS_EIN_AUS
	aktiv
MMS_EIN_AUS
	nicht_aktiv
MULTI_PARTY_CALL_M
	aktiv
MY_INFO_SUPPORTED_POIS
	wert_25
ONLINE_ROUTER
	aktiv
PHONEBOOK_NAME_DISP_ORD_M
	last_first
PICTURE_VIEWER_EIN_AUS
	aktiv
PIM_BILDER_EIN_AUS
	aktiv
POWER_FOLLOW_UP_THRESHOLD
	wert_01
RDL_CONTROL
	aktiv
RDU_CONTROL_ENABLED
	aktiv
REMINDER_EIN_AUS
	aktiv
REMINDER_TRIGGERS_EIN_AUS
	aktiv
RESPONSE_ON_HOLD_M
	nicht_aktiv
SECURE_SIMPLE_PAIRING_M
	nicht_aktiv
SIM_ENABLED_MB
	enabled_all
SMS_EIN_AUS_MED
	aktiv
SORTING_VARIANT_M
	standard
STARTUP_ACTIVE
	nicht_aktiv
SVR_ENABLED
	aktiv
SWUP_ASK_CONF_ENABLED
	aktiv
SWUP_ENABLE_ENG_UPDATES
	nicht_aktiv
SWUP_ENABLE_SW_UPDATES
	aktiv
SWUP_SOURCE_ONLINE
	nicht_aktiv
SWUP_SOURCE_USBMSCDD
	aktiv
TASK_EIN_AUS
	aktiv
TDA_CFG_IND_PDM_GR_NBR_M
	file0
TDA_CFG_TSM_TRIGGER
	all
TDA_FBLOCK
	fblock_df
TDA_TSM_ACTIVE
	aktiv
TELEMATIC_COUNTRY_VARIANT
	row
TELEMATIK_VIN
	most_vin
TELEX_M
	aktiv
TEXT_NOTES_EIN_AUS
	aktiv
UNICODE_EIN_AUS
	nicht_aktiv
USB_HUB_M
	nicht_aktiv
VCARD_OVER_MOST_M
	aktiv
VENTILATION_CNTRL_ENABLED
	aktiv
VIDEO_PLAYER_EIN_AUS
	aktiv
BT_EIN_AUS_MED
	aktiv
OFFSET_BTAS
	wert_00
OFFSET_IPOD_SERIAL
	wert_00
COVER_ART_TWO_WIRE
	nicht_aktiv
ETHERNET
	nicht_aktiv
PAN_PROFILE_M
	aktiv
FOLLOW_UP_TIME_EXTENSION
	wert_02
SWUP_CYCLIC_MONITORING
	wert_20
SWUP_CYCLIC_RESET_TIMEOUT
	wert_255
SWUP_CYCLIC_RST_THRESHOLD
	wert_05
HANDSFREE_SECONDARY
	aktiv
BMW_INFO_SUPPORTED_POIS
	wert_25
SWUP_INSTALL_TIME_SWIP
	nicht_aktiv
USB1_IPOD_AUDIO
	digital
USB2_IPOD_AUDIO
	analog
CIC FSWPSW
Code:
TYP_LENKUNG
	linkslenker
ZYLINDER_ZAHL
	4_zylinder
SVS
	nicht_aktiv
RDC
	nicht_aktiv
HUD_M
	nicht_aktiv
TDA_ATM_CALL_ID
	standard
TDA_ATM_INTERVAL
	standard
TDA_ATM_START_TIME
	standard
TDA_CFG_HLC_DATA
	nicht_aktiv
	file0
TDA_CFG_VEHICLE_SER
	nicht_aktiv
ACC_CIC
	nicht_aktiv
ACC_SGN
	nicht_aktiv
ACTIVE_BACKREST_ADJ
	nicht_aktiv
ADRESSBOOK
	aktiv
AF_FUNKTION
	af_ein
AREA_CODE_DVD
	area_code_2
ASSIST
	aktiv
ASSIST_AKD
	aktiv
ASSIST_AUTOMATIC_SERVREQ
	aktiv
ASSIST_BCALL
	aktiv
ASSIST_ECALL
	aktiv
ASSIST_FCD
	aktiv
ASSIST_HOTLINE
	aktiv
ASSIST_INITIALIZATION
	aktiv
ASSIST_MY_INFO
	aktiv
ASSIST_REMOTE_DOORLOCK
	aktiv
ASSIST_REMOTE_HORNLIGHT
	nicht_aktiv
ASSIST_REMOTE_HVAC
	aktiv
ASSIST_SERVREQ
	aktiv
ASSIST_SVR_SHOW
	nicht_aktiv
ASSIST_VEHICLEFINDER_SHOW
	aktiv
ASSIST_VI_PLUS
	aktiv
AUDIO_SYSTEM_CIC
	hifi
AUX1
	standard
AUX2_INTEGRATED_IN_RSE
	wert_255
AUX4
	standard
BACKDOOR_OPENINGANGLE
	nicht_aktiv
BEHANDLUNG_2S_TIMER
	aktiv
BRAKE_ASSISTENT
	nicht_aktiv
CDMM_AUX_HU
	nicht_aktiv
CDMM_BLUETOOTH_AUDIO
	aktiv
CDMM_DVD_SINGLE
	nicht_aktiv
CDMM_ES
	nicht_aktiv
CDMM_TV_AUDIOTRACE
	nicht_aktiv
CDMM_TV_AUTOSTORE
	nicht_aktiv
CDMM_TV_BML
	nicht_aktiv
CDMM_TV_EPG
	nicht_aktiv
CDMM_TV_FOLLOWING
	nicht_aktiv
CDMM_TV_PRESETLIST
	nicht_aktiv
CDMM_TV_TELETEXT
	nicht_aktiv
CDMM_USB
	nicht_aktiv
CDMM_USB_AUDIO_SINGLE
	aktiv
CONTACT_NUMBERS_BT
	aktiv
	aktiv
DAB_LAENDERVARIANTEN
	nicht_aktiv
DCC
	nicht_aktiv
DOOR_LOCKING_SELECTABLE
	aktiv
DVDAUDIO_AOP
	nicht_aktiv
DVDVIDEO_AOP
	nicht_aktiv
ENTWICKLER_MENUE
	nicht_aktiv
ENTWICKLER_MENUE_ASIEN
	nicht_aktiv
EXTERNER_MOST
	aktiv
FGR
	aktiv
FOLLOWING_AVAILABLE
	aktiv
GUIDED_TOURS
	nicht_aktiv
GUIDING_TIMING
	ece
HEADUP_DISPLAY
	nicht_aktiv
HVAC_INDEPENDENT_HEATING
	nicht_aktiv
IPD_BEHANDLUNG
	nicht_aktiv
KOPIEREN_VON_PROFILEN
	aktiv
LANE_DEPARTURE_WARNING
	nicht_aktiv
MACRO_CAM_LEGALDISCLAIMER
	ld_mit_timeout
MACRO_NIVI
	nicht_aktiv
MACRO_NIVICAM_LDISCLAIMER
	ld_mit_timeout
MACRO_PDC
	aktiv
MACRO_PDC_TOPVIEW
	nicht_aktiv
MACRO_PMA
	nicht_aktiv
MACRO_REARVIEW
	nicht_aktiv
MACRO_SIDEVIEW
	nicht_aktiv
MACRO_TRAILER_COUPLING
	nicht_aktiv
MMS
	standard
MULTICHANNEL_MMC_DVD
	nicht_aktiv
NAVI_2D_MAP_OPTIONS
	nicht_aktiv
NAVI_FLEET_MODE
	nicht_aktiv
NAVI_MAPMODE_AUTOMATIC
	nicht_aktiv
NAVI_MAPSCROLL_LIGHTBEAM
	aktiv
NAVI_MECCA_INDICATOR
	aktiv
NAVI_ROAD_PREVIEW
	nicht_aktiv
NAVI_SHOW_GEOCORDINATES
	aktiv
NAVI_TRAFFIC_INFO_MAP
	aktiv
NAVI_USE_WHILE_UPDATE
	aktiv
NVC
	wert_255
ONLINE_CONFIG_TABLE_INDEX
	config_table_0
PHONE_MPC
	aktiv
PHONE_OBJPUSH_MENUE
	nicht_aktiv
PHONE_SMS
	aktiv
PIA_MMI
	kein_pia_menue
PIA_PORTIERUNGSMASTER
	aktiv
PIA_RESERVED
	nicht_aktiv
PIA_RUECKSETZEN_DEFAULT
	aktiv
POI_DETAILS
	nicht_aktiv
PORTIERUNG
	aktiv
RADIO_DAB
	nicht_aktiv
RADIO_IBOC
	nicht_aktiv
RADIO_SDARS
	nicht_aktiv
RADIO_WEATHERBAND
	nicht_aktiv
RGB_YUV_AUX1
	reserved
RPA_CIC
	aktiv
RSE_INTERNAL_VIDEO_PLAYBK
	wert_255
RVC_CIC
	wert_255
SERVICE_MENUE
	aktiv
SHUTDOWN_DELAY_TIMER_1
	wert_01
SHUTDOWN_DELAY_TIMER_2
	wert_00
SMG
	nicht_aktiv
SPRECHERWAHL1
	weiblich
SPRECHERWAHL2
	weiblich
SPRECHERWAHL3
	weiblich
SYSTEM_GPS_RECEIVER
	aktiv
SYSTEM_TTS
	aktiv
TELEX
	aktiv
TI_CA_TMC
	nicht_aktiv
TI_DETOUR_BUTTON_DISABLED
	nicht_aktiv
TI_FALLBACK_DISABLED
	nicht_aktiv
TI_POPUPS_DISABLED
	nicht_aktiv
TI_TMC
	aktiv
TI_TMC_REGIONAL
	nicht_aktiv
TI_TPEG
	nicht_aktiv
TI_USE_COMBI_DISABLED
	nicht_aktiv
TI_VICS
	nicht_aktiv
TIMER_VOLLBILDKARTE
	permanent
TV
	wert_255
TVC
	wert_255
TVM_VARIANTEN
	kein_tvm
USB_AVAILABLE
	aktiv
YC_AUX1
	reserved
YC_AUX4
	reserved
DKG_CIC
	nicht_aktiv
EDC_CIC
	nicht_aktiv
TDA_ASC_STATUS_CIC
	nicht_aktiv
TDA_BDA_STATUS_CIC
	nicht_aktiv
TDA_DEACTIVATE_STATUS_CIC
	aktiv
TDA_HLC_STATUS_CIC
	nicht_aktiv
TDA_MSC_STATUS_CIC
	nicht_aktiv
TDA_TDC_STATUS_CIC
	nicht_aktiv
MMC_CIC
	wert_255
ASSIST_ECALL_CALL_HANGUP
	aktiv
CDMM_USB_AUDIO_AZ_SEARCH
	aktiv
HIGH_BEAM_ASSISTANT
	nicht_aktiv
HVAC_AIRLAMINATION_CODRV
	nicht_aktiv
HVAC_AIRLAMINATION_DRV
	nicht_aktiv
HVAC_AUTOMATIC_INTENSITY
	aktiv
HVAC_CABRIO
	aktiv
HVAC_FOND_ACTIVATION
	nicht_aktiv
HVAC_INDEPENDENT_AIR
	aktiv
HVAC_POPUP_AIRDISTR
	nicht_aktiv
HVAC_POPUP_AUTO_TOGGLE
	nicht_aktiv
INTERVAL_LCP_ECHO_REQUEST
	value_0
LCP_ECHO_REQUEST
	aktiv
NAVI_RNC_MAINMAP_TEXT
	permanent
NIGHTVISION_1
	nicht_aktiv
TDA_CFG_SER_ERR_SINK_CIC
	aktiv
ASSIST_AKD_SHOW_READ
	aktiv
AUDIO_SIGNAL_ROUTING_CIC
	standard
AUX3_IN_RSE_RIGHT_SCREEN
	wert_255
BAUREIHE_CIC
	e93
CBS_VERSION_3_LOWER
	aktiv
CDMM_DVD_AOP_AUTOMATIC
	nicht_aktiv
COUNTRY
	deutschland
DAB_DABFOLLOWING
	aktiv
DAYDRIVING_LIGHT
	standard
DISPLAY_VARIANTE
	schmales_display
DOORLOCKING_SEATMEMORY
	aktiv
FDS_POPUP_DEACTIVATE
	nicht_aktiv
FOLLOWING_DAB_FM
	aktiv
GPS_FROM_NAVI
	aktiv
GUIDING_KOMBI_HUD
	rueko_mit_hud
GYRO_INTERN
	aktiv
HDC_CIC
	nicht_aktiv
HU_INTERNAL_VIDEO_PLAYBK
	wert_255
HUD_POSITION
	nicht_aktiv
HVAC_POPUP_SEATCLIMATE
	nicht_aktiv
HVAC_SEATCLIMATE_LED
	nicht_aktiv
HVAC_SEATHEAT_DISTR_FOND
	nicht_aktiv
HVAC_SEATHEAT_DISTR_FRONT
	nicht_aktiv
HVAC_SEATVENTILATION_FOND
	nicht_aktiv
HVAC_SEATVENTILATION_FRNT
	nicht_aktiv
HYBRID
	nicht_aktiv
IBA
	nicht_aktiv
IHKA_VARIANTE
	ihka_l2
LEGAL_DISCLAIMER_TIME
	kein_ld
M_KEY_SETTINGS
	nicht_aktiv
MACRO_FDS
	nicht_aktiv
MIC_OVER_MOST
	aktiv
MUTE_PIN_BEHAVIOUR
	no_function
MUTE_PIN_SOURCE
	no_source
NAVI_FUELSTOP_PROPOSAL
	aktiv
NAVI_VARIANTE
	ece
NIVI_2_OBJ_DETETECTION
	nicht_aktiv
PDC_SENSOR_HINTEN
	4_sensoren
PDC_SENSOR_VORN
	4_sensoren
PERMANENTER_PROFILWECHSEL
	aktiv
PHONE_ALL_INC_CALLS_LIST
	aktiv
PHONE_RSE
	nicht_aktiv
RADIO_COUNTRY
	ece
SL01_VIDEO
	nicht_aktiv
SL02_ES
	nicht_aktiv
SL03_IMPORT_EXPORT
	nicht_aktiv
SL04_PIA
	nicht_aktiv
SL05_KONTAKTE_EDIT
	nicht_aktiv
SL06_IBA_1
	aktiv
SL07_IBA_2
	aktiv
SL08_NUMMEREINGABE
	nicht_aktiv
SL09_BT_PAIRING
	nicht_aktiv
SL10_ASSIST_PANNENHILFE
	nicht_aktiv
SL11_BMW_ONLINE
	nicht_aktiv
SL12_BMW_INTERNET
	nicht_aktiv
SL13_ZIELEINGABE_SPELLER
	nicht_aktiv
SL14_ZIELEINGABE_KARTE
	nicht_aktiv
SL15_TRIPPLANER
	nicht_aktiv
SL16_NAVI_POI_SUCHE
	nicht_aktiv
SL17_ASIA_NAVI_POI
	nicht_aktiv
SL18_ASIA_SEARCH
	nicht_aktiv
SL19_ASIA_SETTINGS
	nicht_aktiv
SL20_RESERVE
	nicht_aktiv
STARTUP
	nicht_aktiv
TELEMATIC_INSTANCE_ID
	instanceid_0x01
TEMPORAERER_PROFILWECHSEL
	aktiv
VCARD_OVER_MOST_CIC
	aktiv
VERBRAUCH_CIC
	alle_anderen
VOL_MAX_ON
	standard
L4_L6_KOMMUNIKATIONSSCHLT
	l4_aktiv
ACOUSTICAL_LOCK_CONFIRM
	nicht_aktiv
ANTRIEB
	nicht_aktiv
CDMM_CHANGER_3
	kein_cdc
DAB_BAND
	beide
EINHEITEN_WEGSTRECKE_3
	mls_yrd
EMAIL_READ_OUT_BUTTON
	aktiv
ETC
	nicht_aktiv
L6_ZBE_ARBITRATOR
	nicht_aktiv
LANGUAGE_1_3
	deutsch
LANGUAGE_10
	nicht_aktiv
LANGUAGE_11
	nicht_aktiv
LANGUAGE_12
	nicht_aktiv
LANGUAGE_2_3
	franzoesisch
LANGUAGE_3_3
	english_uk
LANGUAGE_4
	nicht_aktiv
LANGUAGE_5
	nicht_aktiv
LANGUAGE_6
	nicht_aktiv
LANGUAGE_7
	nicht_aktiv
LANGUAGE_8
	nicht_aktiv
LANGUAGE_9
	nicht_aktiv
MULTICHANNEL_CIC
	nicht_aktiv
NAVI_KREUZUNGSZOOM
	nicht_aktiv
NAVI_PFEILANSICHT
	aktiv
NOTEPAD_CIC
	nicht_aktiv
OELSTANDSMENUE
	nicht_aktiv
ONBOARDCOMPUTER_DATE
	aktiv
ONLINE_DAR_INDEX_03
	dar_6
ONLINE_SERVICES
	aktiv
PHONE_CONFERENCE_CALL
	aktiv
PHONE_RESPONSE_HOLD
	nicht_aktiv
PHONE_SMS_READ_OUT_BUTTON
	aktiv
RADIO_DAB_VARIANTEN
	single_tuner_single_hw
RSE_3
	kein_rse
SCHNEEKETTENERKENNUNG
	nicht_aktiv
SL21_IBA_3
	aktiv
SPEEDLOCK_FREISCHALTMENU
	nicht_aktiv
TI_CAT_DEFAULT_CLOSED
	aktiv
TI_CAT_DEFAULT_FLOW
	aktiv
TI_CAT_DEFAULT_FORECAST
	aktiv
TI_CAT_DEFAULT_INCIDENTS
	aktiv
TI_CAT_DEFAULT_ONROUTE
	aktiv
TI_CAT_DEFAULT_PARK_PUBL
	aktiv
TI_CAT_DEFAULT_ROADWORKS
	aktiv
TI_CAT_DEFAULT_WEATHER
	aktiv
TI_CAT_VMAP_CLOSED
	aktiv
TI_CAT_VMAP_FLOW
	nicht_aktiv
TI_CAT_VMAP_FORECAST
	aktiv
TI_CAT_VMAP_INCIDENTS
	aktiv
TI_CAT_VMAP_ONROUTE
	nicht_aktiv
TI_CAT_VMAP_PARK_PUBL
	aktiv
TI_CAT_VMAP_ROADWORKS
	aktiv
TI_CAT_VMAP_WEATHER
	aktiv
TI_DAB_TMC
	nicht_aktiv
TIME_DIST_SAME_PRIO_3
	standard
TIME_OUT_GONG_3
	standard
VIDEO_NUR_MIT_HANDBREMSE
	nicht_aktiv
DUMPER_LEVEL
	nicht_aktiv
FONDLOCK_POPUP_TIMESPAN
	nicht_aktiv
GETRIEBETYP_CIC
	nicht_aktiv
LOGIC7_SYMBOL_C04
	nicht_aktiv
RUEKO_PU_0308
	nicht_aktiv
A2DP_PROFILE
	nicht_aktiv
AUDIO_PLAYER_ON_OFF
	nicht_aktiv
BT_DATA_SERVICE
	nicht_aktiv
BT_MODUL_ON_OFF
	nicht_aktiv
DSC_MENUE
	aktiv
DUN_PROFILE
	nicht_aktiv
EINHEITEN_MASTER
	pia_service
EXTERNAL_CALL_LISTS
	aktiv
FEATURE_DISPLAY
	deviceid
	l4_mic
MUTE_BUTTON
	aktiv
PAN_PROFILE
	aktiv
	wert_03
PRODUKTLINIE
	pl2
SDARS_IN_EXBOX
	inbox
	nicht_aktiv
DSC_OFF_CIC
	nicht_aktiv
MODELL_CIC
	bmw
RINGTONE_CIC
	bmw
TDA_CFG_CUST_MOBILE_CIC
	aktiv
DWA
	nicht_aktiv
ENABLE_BC2_AUTORESET
	aktiv
EXCL_MULTICHANN_FRONT_DVD
	nicht_aktiv
EXCL_MULTICHANNEL_MMC
	nicht_aktiv
EXCL_MULTICHANNEL_TV
	nicht_aktiv
EXCL_MULTICHANNL_REAR_DVD
	nicht_aktiv
FBM_DEFAULT
	aktiv
FBM_DETAILED_INFO
	aktiv
FBM_ENT
	aktiv
FBM_IBA
	aktiv
FBM_MENUJUMPS
	aktiv
FBM_NAVI
	aktiv
FBM_OTHER
	aktiv
FBM_SHORT_INFO
	aktiv
FBM_TEL
	aktiv
FM_BAND_KW
	aktiv
FM_BAND_MW
	aktiv
HUD_DISTANCE_INFO
	nicht_aktiv
MACRO_L6_PARKMENU
	nicht_aktiv
MOMENTDISTRIBUTION_MENU
	nicht_aktiv
ROUTEN_ID_GUIDEDTOURS
	nicht_aktiv
RSE_BRIGHTNESS
	nicht_aktiv
BAUART_CIC
	cabrio
CDMM_ES_ALBUM_INFO
	nicht_aktiv
LANE_CHANGE_WARNING
	nicht_aktiv
TDA_CFG_LEVEL3
	aktiv
CIC_MDRIVE
	nicht_aktiv
API_IPOD_EIN_AUS_CIC
	aktiv
API_MTP_EIN_AUS_CIC
	aktiv
BT_PHONE_INSTANCE_ID
	wert_02
DEFAULT_DATUM
	dd_mm_yyyy
DEFAULT_DRUCK_EINHEIT
	bar
DEFAULT_SVS_DIALOG
	standard
DEFAULT_TEMPERATUR
	celcius
DEFAULT_WEG_EINHEIT
	km
DEFAULT_ZEIT_EINHEIT
	24h
EINSTELLUNG_MEILEN
	mls_uk
ENT_VIDEO_VORNE_GESPERRT
	nicht_aktiv
FUNCTIONALITY_VIEWER
	aktiv
MAP_SCROLL_3D
	nicht_aktiv
NAD_PHONE_INSTANCE_ID
	wert_01
NAVI_DEST_EXPORT
	nicht_aktiv
NAVI_DEST_IMPORT
	nicht_aktiv
NAVI_MYPOI_EXPORT
	nicht_aktiv
NAVI_ROUTE_RECORD
	nicht_aktiv
NAVI_TRIP_EXPORT
	nicht_aktiv
NAVI_TRIP_IMPORT
	nicht_aktiv
ONLINE_SERVICES_GLS
	nicht_aktiv
RDC_SAFETY
	nicht_aktiv
SPEEDLIMIT_INFO
	nicht_aktiv
CHECKBOX_TP
	aktiv
FBM_SELECTION
	eight_buttons
CONNECTIVITY_SYSTEM_VER
	ecu_sw_vid
DATACOM_INTERFACE
	combox
EARLY_VIDEO_LEGALDISCL
	kein_ld
HDD_ACCESS_VIA_ETHERNET
	aktiv
INBAND_RINGING
	nicht_aktiv
SDARS_REPLAY_AUTOMATIC
	aktiv
VIDEO_WATCHDOG_NIGHTVISIO
	nicht_aktiv
VIDEO_WATCHDOG_REARVIEW
	nicht_aktiv
VIDEO_WATCHDOG_SIDEVIEW
	aktiv
VIDEO_WATCHDOG_TOPVIEW
	nicht_aktiv
CDMM_BT_DATABASE
	nicht_aktiv
CDMM_USB_COMPOSER_IPOD
	enabled
CDMM_USB_COMPOSER_MTP
	enabled
CDMM_USB_COVER_ART
	aktiv
DATACOM_TRANSFER
	mamac
LANGUAGE_MASTER
	deutsch
SOFTWARE_UPDATE_MANAGER
	aktiv
AUDIO_REMOTE_CONTROL
	nicht_aktiv
BRAKE_ASSISTENT_3
	nicht_aktiv
FM_DEEMPHASIS
	wert_01
KOMBI_CIC
	kombi_high
GRACENOTES_ACCESS
	most
NAVI_FULL_GUIDINGPOPUP
	aktiv
NAVI_MAP_ARROWVIEW
	aktiv
NAVI_SPLIT_GUIDINGPOPUP
	nicht_aktiv
EXTERNE_MOST_DIAG
	aktiv
MICROPHONE_0A
	no_microphone
AVOID_VIGNETTE_0A
	aktiv
ECALL_INSTANCE_ID_0A
	wert_01
SIDE_VIEW_CAMERA_0A
	wert_255
CONTACT_NUM_HOTLINE_0B
	aktiv
CONTACT_NUMBERS_BCALL_0B
	aktiv
HVAC_MSA_EFFICIENCY
	nicht_aktiv
KOMBIGUIDING_SCHALTBAR
	nicht_aktiv
MACRO_PIM
	aktiv
NAVI_ROUTE_STUDY
	nicht_aktiv
P_BOOK_NAME_DISPL_ORD
	lastname_first
PIM_ADR_VALID
	nicht_aktiv
PIM_CROSS_USE
	aktiv
PIM_OVERVIEW
	aktiv
PIM_TTS
	aktiv
PU_0909
	aktiv
CDMM_USB_AUDIO_DOUBLE_0B
	aktiv
CDMM_VIDEO_C0B
	nicht_aktiv
NAVI_INFO_INSTANCE_ID_0B
	wert_01
PHONE_TYPE_C0B
	combox
PICTURE_ALBUM_ARTS_0B
	aktiv
SW_UPDATE_ASSISTANT
	aktiv
TI_CA_TPEG_C0B
	nicht_aktiv
TI_VINFO_C0B
	aktiv
COMFORT_OPENING
	aktiv
HYBRID_EFFICIENCY_GRAPHIC
	nicht_aktiv
LANGUAGE_13
	nicht_aktiv
LANGUAGE_14
	nicht_aktiv
LANGUAGE_15
	nicht_aktiv
LANGUAGE_16
	nicht_aktiv
MMC_VARIANTE
	wert_02
RADIO_AM_LW
	aktiv
ALTERNATIV_ROUTEN
	aktiv
FM_BAND_LW_0C
	nicht_aktiv
GUIDING_TIMING_KM
	permanent
GUIDING_TIMING_MLS
	permanent
PIM_DRIVING_TEXT_LENGTH
	one_page
REMOTE_HMI
	nicht_aktiv
TEXTKUERZUNG
	aktiv
TVC_WIDTH_0C
	wert_01
TYPE_OF_FUEL_0C
	alle_kraftstoffe
TDA_ATM_ACTIVE_CIC_0C
	aktiv
TDA_CFG_AUTO_TRIG_CIC_0C
	aktiv
CLIMATE_ACT_ONE_TIMER
	nicht_aktiv
MESSAGE_FILTER
	aktiv
NAVI_MYPOI_IMPORT_C0D
	nicht_aktiv
ONE_SHOT_DEST_INPUT_C0D
	nicht_aktiv
ONLINE_BROWSER_C0D
	nur_bmw_online_aktiv
PDC_DIRECTION
	horizontal
TDA_TSR_INSTANCE_ID_C0D
	wert_02
API_TYPE
	combox
HUD_ACTIVATION
	nicht_aktiv
SINGLE_OR_MULTILINK
	multilink
SPEEDLOCK_X_KMH_MAX_C0E
	3_kmh
SPEEDLOCK_X_KMH_MIN_C0E
	3_kmh
A4A
	nicht_aktiv
AUDIO_SYSTEM_VAR
	default
CDMM_PERSONALRADIO
	nicht_aktiv
CDMM_USB_HMI
	new
CDMM_USB_POD_BOOK
	aktiv
CDMM_USB_VIDEO
	none
COMINGSTREET_KOMBI_HUD
	nicht_aktiv
NAVI_3D_MAP_OPTIONS_C0F
	nicht_aktiv
ROTATION_WERTE_EINHEITEN
	nicht_aktiv
BASIS_KOMBI_MMI_LIST
	aktiv
BMAP_JUNCTION_VIEW
	aktiv
DAB_STANDARD
	nicht_aktiv
DMB_MAX_FRAMERATE
	wert_0
DOORLOCKING_AFTER_DRIVING
	aktiv
HMI_FUER_DAB_DMB
	dab_dmb_radio
HUD_TURNSIGNAL
	nicht_aktiv
KOMBI_AR_PRES
	nicht_aktiv
PHONEBOOK_NAME_ORD
	aktiv
SECONDARY_HFP
	aktiv
SERVICE_HISTORY
	nicht_aktiv
WELCOME_LIGHT
	aktiv
EXT_MUSIC_MANAGEMENT
	nicht_aktiv
HUD_ROTATION
	nicht_aktiv
JUNCTION_VIEW_HUD
	nicht_aktiv
M_DIGITAL_TACHO_EINH
	nicht_aktiv
RSE_SERVICE_MESSAGES
	nicht_aktiv
TIME_LAG_IDG_CIC
	standard
TIME_LAG_IMG_CIC
	standard
AUDIO_OFFSET
	aktiv
BRAKE_ASSISTANT_CCM
	nicht_aktiv
BRAKE_ASSISTANT_FCW
	nicht_aktiv
LANGUAGE_UPDATE
	nicht_aktiv
M_DIGITAL_TACHO
	aktiv
MAX_VOL_STEP_RSE
	standard_39h
MDRIVE_CONFIG
	1_menu
MDRIVE_RUEKO
	nicht_aktiv
NANP_FORMAT
	nicht_aktiv
NAVI_POI_ONLINE_SEARCH
	browser
OELSTAND_OENS
	nicht_aktiv
TERMINAL_UI
	nicht_aktiv
VOL_MAX_ON_RSE
	standard_19h
A4A_REMOTE_APPS
	nicht_aktiv
ANZEIGE_FREQ
	nicht_aktiv
COLOUR_SWITCH
	nicht_aktiv
COLOUR_SWITCH_LINES
	sport
DAB_FOLLOWING_CHECKB_HMI
	nicht_aktiv
DEBOUNCE_KOMBI_BASIS
	defaultwert_50
ECO_ROUTE_TEXT
	nicht_aktiv
ENT_CHANNELBUFFER
	wert_11
ENT_ITEM_UPDATE_COUNT
	wert_1
ENT_MANAGED_CHANNEL
	wert_50
ENT_MAX_NUMBER_FAVOURIES
	wert_100
ENT_ONLINE
	nicht_aktiv
ENT_QUERY_CHANNEL
	wert_50
ENT_TEMPORARY_CHANNEL
	wert_100
HEADLIGHT_SETTING
	nicht_aktiv
HELLIGKEIT_AMBILIGHT
	nicht_aktiv
MMI_STATISTIK
	nicht_aktiv
MODE_HARDKEY
	more_sources
NAVI_POSITION_MENU
	aktiv
SERVICE_HISTORY_WHO
	default
SPEECH_2_TEXT
	nicht_aktiv
BRAKE_ASSISTANT_CONF
	nicht_aktiv
DATUMSFORMAT_AR_ASIA
	nicht_aktiv
ENABLE_SW_INFO_REQUEST_14
	nicht_aktiv
FBM_NO_TOUCHSENSOR
	nicht_aktiv
SLEEPDELAY_CLAMP30B_MIN_2
	wert_90
SLEEPDELAY_TIMERVALUE_2
	wert_1e
BEV
	nicht_aktiv
CONNECTED_DRIVE
	nicht_aktiv
ECO_FDS_POPUP
	nicht_aktiv
ECO_LIMIT
	nicht_aktiv
ECO_MODE
	nicht_aktiv
ECO_MODE_CONF
	nicht_aktiv
ECO_ROUTE
	nicht_aktiv
ECO_TIPPS
	aktiv
EFF_DYN_FORECAST_HYB
	na
EFF_DYN_SPORT_CID
	nicht_aktiv
EFF_DYN_SPORT_UNIT
	nicht_aktiv
EFF_DYN_SYS_CID
	nicht_aktiv
FDS_NAMING_MODE
	bis_0711
HIGH_END_AUDIO_MENUE
	kein_menue
HIST_BEV_CONSUMP
	nicht_aktiv
HIST_BEV_CONSUMP_SCALE_1
	50
HIST_BEV_CONSUMP_SCALE_2
HIST_BEV_CONSUMP_SCALE_3
	10
HIST_BEV_RECUP_SCALE_1
	20
HIST_BEV_RECUP_SCALE_2
	20
HIST_BEV_RECUP_SCALE_3
	30
HIST_CONSUMP_AVERAGE
	kein_wert
HIST_FDS_MODE_COLOR
	nicht_aktiv
HIST_FDS_MODE_NAME
	nicht_aktiv
HIST_GAS_CONSUMP
	nicht_aktiv
HIST_GAS_CONSUMP_SCALE_1
	na
HIST_GAS_CONSUMP_SCALE_2
	na
HIST_GAS_CONSUMP_SCALE_3
	na
HIST_GAS_CONSUMP_SCALE_4
	na
HIST_HYB_CONSUMP
	nicht_aktiv
HIST_HYB_CONSUMP_SCALE_1
	nicht_belegt
HIST_HYB_CONSUMP_SCALE_2
	nicht_belegt
HIST_HYB_CONSUMP_SCALE_3
	nicht_belegt
HIST_HYB_CONSUMP_SWITCH
	nicht_aktiv
HIST_ZOOM
	nicht_aktiv
MAXGLOBALREMOTECOMMANDS
	v20
MAXLOCALREMOTECOMMANDS
	v0
PHONEBOOK_CACHING
	nicht_aktiv
RR_SPEZ_KLZ
	nicht_aktiv
ENT_HUDRIVE_INSTALLED
	aktiv
EXTENDED_CC_MESSAGES
	aktiv
ONLINE_BROWSER_LIVE
	nicht_aktiv
SETTINGS_DOORLOCKING
	aktiv
SETTINGS_HOMELIGHT_PERIOD
	aktiv
SETTINGS_INFO_DISPLAY
	nicht_aktiv
SETTINGS_LIMIT
	aktiv
SETTINGS_SPIRITOFECSTASY
	nicht_aktiv
SETTINGS_TIP_BLINKING
	aktiv
SETTINGS_TOURIST_LIGHT
	nicht_aktiv
SETTINGS_TRACTION
	aktiv
TDA_CFG_BDA_REMOTE_HELP
	aktiv
TPEG_TAP
	nicht_aktiv
TRAVEL_BC
	aktiv
      05-01-2024, 12:57 PM   #2
shtepa93
Drives: e93 320d
I found what was the issue. I removed harness tape from combox wiring and saw that microphone cables are damaged (not sure how that happened). I resoldered them and microphone works now. I guess when I installed combox, I moved cables a little bit so microphone cables connected again and microphone worked for a short moment.
