BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > B48/B46 Tuning Thread
ARMA SPEED
      09-07-2020, 11:58 PM   #1
Avaley
Avaley's Avatar
735
Drives: f32 430ix & 982 GT4 PDK
I've seen a ton of information on N20 tuning, times, dynos and results and wanted to see if anyone has had any luck modifying the B46/B48 engine now that the standard service warranty is beginning to fall off...
I have a stock 2018 430ix 8AT and will be adding FBO and a BM3 stage 1 tune to start.
Will be throwing these on in (thanks to Mike at XPH) within the next few months:
  • BM3 Stage 2
  • xHP Stage 3 8AT Transmission Flash
  • Injen SP Open Air Intake
  • Evolution Raceworks Catless Downpipe
  • Evolution Raceworks Charge Pipe Kit
  • Full AWE Catback Exhaust Suite
Things that I'm thinking of doing / will do later:
  • Black rims, 225/50/18R front and 245/50/18R rear - open to suggestions
  • BM3 Stage 2 E30 tune
  • CSF Heat Exchanger (unsure if necessary on B48 or worth it)
Would love to hear folks experience with this engine and open to any suggestions, thoughts and/or tips in tuning. Will keep this threaded updated.
      09-08-2020, 03:48 AM   #2
Luverse
Luverse's Avatar
Indonesia
179
Drives: BMW F30
  • BM3 Stage 1 + Transmission Flash
  • Injen SP Air Intake
  • Full AWE Exhaust Suite (Axleback Touring Single Sided + Performance Resonated Midpipe)
  • BM3 Stage 2 (worried about reliability / breaking the engine)
  • 19" lightweight alloy wheels and performance tires (open to suggestions)
i'm using B48 engine and Stage 2 BM3 for run and Stage 1 BM3 for daily
Performance mods so far:
1. Armytrix Catless Downpipe
2. Straight pipe exhaust with valvetronic remote control
3. FTP Charge pipe
4. FTP intake pipe
5. BMS open billet intake
6. BM3
Love the performance it deliver. But after several discussion with PTF, and due to minor accident, i removed the BMS open billet intake and now using stock intake.
PTF said, their tune is designed and tested to work with stock intake, and they not recommend us to use any aftermarket intake.
After i revert back to stock intake, i do feel that the performance is better and throttle response is much better. But i lost the fun noise of aftermarket intake.
Instagram: nightfall.f30
Avaley735.00
      09-08-2020, 12:08 PM   #3
Avaley
Avaley's Avatar
735
3. FTP Charge pipe
4. FTP intake pipe
6. BM3
Awesome! Thank you for the response, glad to see someone with success in tuning the B48. I looked through some of your posts, it seems that I'll probably want a XHP transmission tune for my 8AT as well...funny that the intake actually makes things worse - is it related to heat soak? Have you dyno'd? I feel that basic bolt ons and tune should get the B46/48 to 300whp. I'm going to be doing intake + tune first so will report back soon...will start with just tune and see if the intake makes things worse like yours
Harppa0.00
      09-08-2020, 08:40 PM   #4
Luverse
Luverse's Avatar
Indonesia
179
Drives: BMW F30
XHP transmission tune will definitely bring the fun to the whole next level.
I believe because the OTS map is designed and tested with stock intake, so PTF will not recomended aftermarket intake.
My latest dyno recorded 310hp and 445nm, on engine. That still using the BMS open billet intake. Haven't dyno'd again with stock intake.
For reference, this is PTF statement
Name:  PTF respond.jpg
Avaley735.00
      09-08-2020, 11:33 PM   #5
Avaley
Avaley's Avatar
735
Attachment 2408944
Awesome those are great numbers. I wonder maybe if it’s just a liability release or what the lawyers tell them to recommend but I would imagine an air aftermarket intake to still be a net positive.
I flashed stage 1 today and I am shocked at how much torque it added, everything else stock. My Injen SP open air intake is coming next so we shall see how it feels....
So BM3 doesn’t do anything to the transmission? The 8AT in sport puts down power and almost reads your mind and the engine just goes to redline each gear now. Also the fan always on option is great and my temps are noticeably cooler.
Have you tried ethanol mix? With your numbers, I feel like this engine can do 330hp 350ft lbs (475NM) trq at the crank with E30 stage 2 fbo. Bmws 4 bangers have always been underrated and could prob get to low 5s 0-60 and maybe break w FBO stage 2. I should get performance tires (19s?) and hopefully we b48 owners can push it to see gains over N series, an already great engine.
      09-09-2020, 06:09 AM   #6
Luverse
Luverse's Avatar
Indonesia
179
Drives: BMW F30
so far, from what i see on youtube, aftermarket intake only provide sound. No noticeable performance gain, even on dyno. In fact, some aftermarket intake cause decrease in dyno number.
No transmission tune for B48 engine. We need to get it from XHP.
Some folk says, the MAX cooling mode will wear your cooling system faster. I always set that option to off.
Nope, there's no ethanol in my country. Several folks here on B48 engine already run 0-60 in 4.8s. I believe they already post their dragy results.
I would recommend you get a better tyre. I went with Toyo Proxes T1R which is good, but now i'm using Yokohama Advan Sport V105 which is great.
Avaley735.00
      09-11-2020, 02:35 AM   #7
Dronamashina
Dronamashina's Avatar
64
Drives: Bmw 340ix
AWD and XHP transflash is a great combo! I added torque (launch control) in XHP custom settings (ajustable launch control) and now i can do -60 in 4.7 sec easily with regular st2 ots map. With custom st2 E50 tune 0-60 goes down to 4.3-4.4 sec. My best numbers with dragy are 4.18 0-60 and 12.43 1/4 mile!
And N20 isnt great engine at all. It has a lot of weak points and problems, and i dont think N20 has ever shown such numbers with stock turbo as B48.
Forgot to say that i have 2018 320ix and MGflasher tune.
2018 340ix AWD B58 8AT | MGflasher ST1 |
Instagram: andreykrop
Youtube: DronaMashina
Avaley735.00
      09-11-2020, 03:13 AM   #8
Luverse
Luverse's Avatar
Indonesia
179
Drives: BMW F30
what's the boost target for MGFlasher St 2 OTS?
that's quite impressive number you got
      09-11-2020, 04:47 AM   #9
Dronamashina
64
Drives: Bmw 340ix
Around 19 psi as I remember
      09-11-2020, 10:33 AM   #10
Avaley
Avaley's Avatar
735
Wow super impressive numbers don't think i've seen any other B48 run a sub 4.5s but makes sense as power is probably equal to B58 (which does 4.5 according to BMW) once FBO'd stage 2 E50 with 100 lbs less...my ethernet lightning adapter is on the way and will flash XHP stage 2 and add an intake to my stage 1 this weekend.
It seems that MGflasher might perform better than BM3 Stage2 though it is younger in adoption based on your post history....I may have to switch over or get a Cary Jordan custom BM3 tune after DP/straight pipe/stage 2.
I think the newer 8AT is the ZF 8HP50 which should be able to handle 500NM so the trans probably outlives the engine under boost.
How is the daily usability (both Luverse on your BM3st2 and Drona on your MGst2)? I find BM3 stage 1 in comfort to be unnoticeable to stock in traffic but day and night different under WOT in sport+ S gear. I'm a bit worried about pushing the engine too much as I've heard N20 was unreliable when pushed hard tho 19 PSI seems within reason...still early in B48 tuning life but promising if it stays reliable
      09-11-2020, 10:14 PM   #11
Luverse
Luverse's Avatar
Indonesia
179
Drives: BMW F30
for daily, i'm using stage 1 BM3 more often than stage 2. Because the traffic here is so bad, average speed can drop to 5km/h.
when doing a morning run with the crew, i'm using stage 2, and often go WOT, no problem so far.
able to pull this far on stage 2 OTS BM3
      09-11-2020, 10:48 PM   #12
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
N20 is still proven to be faster than B48.
Proof is in the pudding.
Quarter Mile, world wide rankings can be found here:
https://www.facebook.com/groups/2443...651/?ref=share
      09-11-2020, 10:49 PM   #13
sspade
sspade's Avatar
Drives: F30
Also...
N20 is a back to back winner of Ward's 10 Best Engines.
B48 is a zero time winner.
      09-12-2020, 01:53 AM   #14
Avaley
Avaley's Avatar
735
Don't have access but how does this rank? @Dronamashina
      09-12-2020, 04:26 AM   #15
Dronamashina
64
Drives: Bmw 340ix
1st place ha ha)) but they will never put me in that board...
      09-12-2020, 04:40 AM   #16
Dronamashina
64
Drives: Bmw 340ix
Also...
N20 has open deck and weak factory pistons. It has so many problems, so many blown engines... what are you talking about? Awards won’t make n20 reliable and tuneable. Also I have better 1/4 mile than all of those n20s in that leaderboard you posted above.
P.S. I had both n20 and b48, actually two b48s so I now what I’m talking about.
Avaley735.00
VipinLJ1949.00
      09-12-2020, 11:42 AM   #17
Dronamashina
64
Drives: Bmw 340ix
Yes MG performs better than bm3, I know one guy that moved from bm3 to MG because of that and he’s happy with that as I remember.
8hp50 holds much more than 500nm, 340 has the same trans and with simple tune it has 600+ nm and no problems. I did 700+ hard launches (3000-4000 rpms) and everything is fine.
Daily usability is great! Comfort or aggressive when you need it.
Avaley735.00
      09-12-2020, 02:55 PM   #18
Avaley
Avaley's Avatar
735
Also...
Its also nearly a 10 year old data point and not a good comparison...since BMW went modular B series, B58 engine has won an award 5 out of last 6 years...B48 is the B58 with 2 less cylinders...
https://en.wikipedia.org/wiki/Ward%27s_10_Best_Engines
I'm trying to avoid a N20 vs B48 flame thread and focusing on B48 tuning specifically.
Drona, now that you have straight piped and did 12.4s before exhaust mods, I would dare to guess that the B48 stage 2, e50 with FBO is capable of a 12s 1/4 mile...you haven't done intake, charge pipe, spark plugs or methanol and what rims / tires?
In the 2021 G series this year, they up tuned the B48/B58 again and shaved another 0.2s off 0-60 and BMW is now claiming 255hp/400nm (5.3) in the B48 and 382hp/500nm (4.3) in the B58 from the factory so there is definitely so more potential to be had.
Any thoughts on changing your factory heat exchanger? Since going air-to-water and away from an intercooler, i dont think there are a ton of heat issues but CSF makes a upgraded radiator tested to keep temps cooler but the factory one has done great for me, esp with the max cool setting in BM3.
https://csfrace.com/bmw-b58-cooling/
      09-12-2020, 04:21 PM   #19
Dronamashina
64
Drives: Bmw 340ix
I have KN filter in factory airbox and I honestly think it’s best combo for the intake. Charge pipe doesn’t add any power. I have best plugs available for b48 - ngk 94201. As for meth, no I don’t have it and I think meth could be worth a try actually. I have stock m 18’’ rims and normal non run flat tires but nothing special.
I think 12.4 is very close to max performance with stock turbo. Maybe 12.3 but that would be very hard to do without cheats))
Don’t think couple of degrees decrease in iat is worth the price of a tuned heat exchanger.
      09-13-2020, 10:43 PM   #20
Luverse
Luverse's Avatar
Indonesia
179
Drives: BMW F30
standard factory airbox is the best for now
the car feel more responsive than using open billet intake
      09-14-2020, 09:55 PM   #21
eff32fl
eff32fl's Avatar
1074
Drives: 2019 440i M Sport THP MPPSK
Do you happen to have any video/audio recordings of the sound of your exhaust? Specifically wondering if you're getting decent burbles with BM3 Stage 1 with B48.
      09-15-2020, 11:26 AM   #22
RMMAGA
73
Drives: 120i
damn those are some good times, best I got was 12.65 at 110.4mph, out here in southern china my DA is 2200ft, and with a 2.03 60ft that is about best case with RWD
running 26 psi, with my own tune, which I think is the most I am comfortable to run without building the engine
for the run above I turned off the meth, to monitor my turbo efficiency, got 350 deg F out with about 90 deg ambient air, at 26psi that works out to 66%, so still very reasonable, with 90% WGDC, I only have a modified compressor wheel, so i guess your efficiency is lower, but the DA would likely more then make up for that, and the that the inter cooler is really good
on a 0 to 120 run, with meth turned off my IAT only increases by about 8 to 10 degrees, for example on the run about it started at 120 deg and ended at 128 deg F
meth is odd, as it does not appear to gain any power, or gain much in IAT, maybe 4 to 5 deg based on my logs, the inter-cooler looks very good, I can see a little better timing with meth, and i run about e90 in the meth tank, if you can get good fuel like e30 that i am running, i dont think meth will do anything for you, do not bother if you do not have it already
330i, 430i, b46, b48, bootmod3, f30, modification, stage 2, tuning
