11-09-2010, 02:53 PM | #1 |
Supreme Allied Commander
3886
Rep 54,510
Drives: F80 M3
HP Autosport Quick Change Rear Spring Kit with Swift Springs and Trust Sheets
This kit allows the user to change spring rates at home or the track in minutes, without disconnecting the lower control arm and without performing another wheel alignment as long as the ride height remains the same.
This kit not only allows you to change your springs very quickly, it also allows you to adjust the ride height of the vehicle with the springs installed. YES! With the springs installed. No need to remove the springs! Most E82/9X coilover kits on the market today, you must unload the spring tension to adjust the rear ride height, but not ours! What is in the kit: TCKR Rear Ride Height Adjusters(HPA no longer available) BMW Sealed Radial Thrust Bearings(used on the top of the main spring) Swift Main and Helper springs Swift Thrust Sheets(use at the lower portion of the spring, between the helper and the control arm) $579.95 Last edited by HP Autosport; 04-19-2023 at 11:36 AM.. |
04-06-2011, 06:21 PM | #2 |
3886
Rep 54,510
Drives: F80 M3
Track guys! This is the kit for you if you like to change spring rates at the track, no need to drop the rear control arm to swap your springs anymore and best of all no track side alignment. Spring swap can be done in seconds!
04-14-2011, 01:51 AM | #3 |
3886
Rep 54,510
Drives: F80 M3
The HPA Quick Change Rear Spring Kit will work on E82 and E9x M and none M.
04-14-2011, 01:23 PM | #4 |
Ex '87 Carrera
248
Rep 1,259
Interesting. How is the adjustment actually made? I mean the concept is simple, but I don't see any way a spanner or wrench could be attached to the blue collar to rotate it relative to the threaded shaft.
ianc
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
"I got 328 loaner and was impressed with performance. It feels much faster than my 135i." - MOCKBA |
04-27-2011, 02:44 AM | #5 |
3886
Rep 54,510
Drives: F80 M3
Don't need spanners, you can simply turn it by hand, it's that easy!
08-24-2011, 03:16 PM | #7 |
3886
Rep 54,510
Drives: F80 M3
Very convenient if you find yourself varying your spring rates.
-Tyler |
09-28-2011, 11:13 PM | #8 |
3886
Rep 54,510
Drives: F80 M3
Swift Springs
All components in stock and ready to ship with your desired spring rates.
07-24-2012, 09:47 PM | #9 |
3886
Rep 54,510
Drives: F80 M3
HPA 135i 1M M3 Rear Height Adjusters
Allow quick spring changes and height adjustments for your BMW 1M M3. Ready to ship!
04-14-2015, 08:08 AM | #11 |
Rep 1,623
Drives: Alpine White 128i Cabrio
Hi Harold,
Just wondering what do you have the helper spring seated on, on the control arm?
2008 128i E88 / Alpine White / Boston Leather Sport / 6AT / M3 Paddle Shifters / Bilstein B8 / H&R Springs / Dinan Fixed Camber Plates / BMW 335i Front Brakes / PIAA Xtreme White 4150K Angel Eyes / Rear Fogs Enabled / Cyba Air Scoops / Euro Airbox / BMW Performance Exhaust / Stubby BMW Antenna
04-14-2015, 10:53 AM | #12 |
3886
Rep 54,510
Drives: F80 M3
03-29-2016, 05:47 PM | #22 |
3886
Rep 54,510
Drives: F80 M3
Not sure if we have seen any reviews, but sold 2-30+ sets since 2009. We used this exact same up on our Redline Time Attack 335i back in the days. Many coilover over manufacturer actually copied this same exact setup on their higher end offerings.
